查看: 2935|回复: 8
keil编译1602滚动显示程序,总是有一处语法错误
ID:454913 发表于 2018-12-25 21:47 | 显示全部楼层 |阅读模式
我这个打的有问题吗,为什么总是有一处语法错误,求大佬指教。
main.c
#include"main.h"
        init_lcd();
        while(1);
                display();
1602. C
#include"1602.h"
unsigned char code t0[]="Welcome to the";
unsigned char code t1[]="world of MCU!!!";
unsigned char code t2[]="Fighting!!!!!";
void delay(unsigned int time)
        unsigned int i,j;
        for(i=0;i<time;i++)
                for(j=0;j<200;j++);
void write_com(unsigned char com)
        lcdrs=0;
        P0=com;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void write_date(unsigned char date)
        lcdrs=1;
        P0=date;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void init_lcd()
        lcden=0;
        lcdrw=0;
        write_com(0x0f);
        write_com(0x38);
        write_com(0x01);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x80);
void display()
        unsigned int i;
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t0);
        delay(500);
        write_com(0x80+0x40);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
        delay(500);
        write_com(0x01);
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
         delay(500);
        for(i=0;i<16;i++);
                write_date(t2);
        delay(500);
        write_com(0x01);
Main.h
#include"reg52.h"
#include"1602.h"
1602.H
#include"reg52.h"
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
void delay(unsigned int time);
void write_com(unsigned char com);
void write_com(unsigned char date);
void init_lcd();
void display();
Build target 'Target 1'
compiling main.c...
compiling 1602.c...
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?DISPLAY?1602
Program Size: data=11.0 xdata=0 code=329
creating hex file from "main"...
"main" - 0 Error(s), 1 Warning(s).
ID:446654 发表于 2018-12-25 22:51 | 显示全部楼层
是不是要这样啊write_data(t0[i]);
ID:371527 发表于 2018-12-26 07:29 | 显示全部楼层
不是错误,是警告,编译可运行,有1个子程序在main内未使用
ID:164602 发表于 2018-12-26 08:10 | 显示全部楼层
新手的典型错误!!!!!
警告是说,你的display()函数没有用上,我一看你的程序,果然是这个错误:
while(1);
这里不能有那个分号啊!!!!!
ID:213173 发表于 2018-12-26 08:44 | 显示全部楼层
        init_lcd();
        while(1);//多了分号
                display();
整理后的程序
#include"reg52.h"
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
void init_lcd();
void display();
        init_lcd();
                display();
        unsigned int i,j;
        for(i=0;i<time;i++)
                for(j=0;j<200;j++);
        lcdrs=0;
        P0=com;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
        lcdrs=1;
        P0=date;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void init_lcd()
        lcden=0;
        lcdrw=0;
        write_com(0x0f);
        write_com(0x38);
        write_com(0x01);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x80);
void display()
        unsigned int i;
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t0);
        delay(500);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
        delay(500);
        write_com(0x01);
        write_com(0x80);
        for(i=0;i<16;i++)
                write_date(t1[ i]);
        delay(500);
        for(i=0;i<16;i++);
                write_date(t2);
        delay(500);
        write_com(0x01);
ID:134430 发表于 2018-12-26 09:35 | 显示全部楼层
while(1);  这里的分号造成了{}里的delay函数不运行,程序在分号处死循环,也就是停在这里,什么也不干。
ID:357520 发表于 2018-12-26 11:49 | 显示全部楼层
语法错误应该不能编译成功吧,看到楼主写的代码,就想起自己写的了,感同身受,我们要努力学习
ID:455797 发表于 2018-12-26 19:55 | 显示全部楼层
只是一个警告,不是错误,编译就行
ID:134430 发表于 2018-12-26 22:33 | 显示全部楼层
wulin 发表于 2018-12-26 08:44
        init_lcd();
        init_lcd();
                display();
5楼兄台,这里整理完还是有问题的吧?while(1),永远跳不出这个循环,这里除了显示其他什么都不做,而且显示也不能调控,有什么意思吗?想跳出来就应该加break;
