10 黑币
仿真图
void GPIO_Configuration()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB , ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3
|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11| GPIO_Pin_10 | GPIO_Pin_12;
GPIO_Init(GPIOA, &GPIO_InitStructure);
void delay_us(unsigned long n)
unsigned long j;
while(n--)
j=8;
while(j--);
* Function Name : delay_nms
* Description : delay n ms
void delay_ms1(unsigned long n)
while(n--)
delay_us(1100);
void Write_Command_LCM(u8 com)
GPIO_ResetBits(GPIOA,GPIO_Pin_11);
GPIO_ResetBits(GPIOA,GPIO_Pin_12);
GPIO_Write(GPIOB, com);
GPIO_ResetBits(GPIOA,GPIO_Pin_10);
delay_ms1(5);
GPIO_SetBits(GPIOA,GPIO_Pin_10);
delay_ms1(5);
void Write_Data_LCM(u8 info)
GPIO_Write(GPIOB, info);
GPIO_SetBits(GPIOA,GPIO_Pin_12);
delay_ms1(5);
delay_ms1(5);
oˉêyÃû£oLCM_Init()
1| Äü£o¶ÔLCD 16023õê¼»ˉ
void LCM_Init(void)
Write_Command_LCM(0x38);
Write_Command_LCM(0x08);
Write_Command_LCM(0x06);
Write_Command_LCM(0x01);
Write_Command_LCM(0x0C);
void Set_xy_LCM(unsigned char x, unsigned char y)
unsigned char address;
if( x == 0 )
address = 0x80+y;
if( x == 1 )
address = 0xC0+y;
Write_Command_LCM(address);
void Display1(unsigned int x, unsigned int y, unsigned char *s)
Set_xy_LCM(x,y);
while(*s)
Write_Data_LCM(*s);
s++;
int main(void)
void GPIO_Configuration();
Display1(0, 0, "www*szopen*cn");
while(1);
我来回答
