查看: 4041|回复: 7
单片机+LCD12864与12生肖显示
#include <REG52.H>
#define uint  unsigned int
sbit  RS  = P2^6; //RS 控制引脚
sbit  RW  = P2^5; //RW 控制引脚
sbit  EN  = P2^7; //EN 控制引脚
sbit  PSB = P3^2; //模式选择引脚,
sbit  RST = P3^4;                           //复位端
void  LCD12864_init(void); //LCD12864 初始化函数
void  writwo(uchar dat,bit cemordat);
void  busy(void);// 忙检测函数
void  delay(uint c);
void  disp(uchar code *utupian);
uchar   code shengxiao1[]={
     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x24,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x48,0x00,0x00,
      0x00,0x00,0x00,0x00,0x08,0xF4,0x00,0x00,
      0x00,0x00,0x00,0x03,0xC0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x1C,0xF8,0x00,0x70,
      0x00,0x00,0x00,0x3F,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x1F,0xFC,0x01,0xFC,
      0x00,0x00,0x00,0x3F,0x60,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x7F,0xFF,0x07,0xFE,
      0x00,0x00,0x00,0x03,0xFF,0xFF,0xC7,0xFF,
      0x00,0x00,0x00,0x00,0xEF,0xFF,0xED,0xFF,
      0x00,0x00,0x00,0x37,0xA0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x01,0x0F,0xFF,0xFC,0xBF,
      0x80,0x00,0x02,0x7F,0xF0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x02,0x0F,0xFF,0xFC,0x5F,
      0x80,0x00,0x07,0xFF,0xF0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x0F,0xFF,0xFC,0x3F,
      0x00,0x00,0x0F,0xFF,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x0F,0xFF,0xFE,0x3F,
      0x00,0x00,0x7F,0xCF,0xF0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x8F,0xFB,0xFF,0x7E,
      0x00,0x00,0xFF,0xBB,0xD0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x0F,0xFB,0xFF,0x3C,
      0x00,0x00,0xFF,0x67,0x88,0x00,0x00,0x00,
      0x00,0x00,0x00,0x2D,0x1F,0xFC,0x7F,0xF8,
      0x00,0x00,0xFD,0xDF,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x6F,0xB7,0xE0,0xFF,0xE0,
      0x00,0x01,0xFF,0xFF,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x6F,0xE7,0xC1,0xFF,0xE0,
      0x00,0x01,0xFB,0x7F,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x6F,0xE3,0xF7,0xFF,0xF0,
      0x00,0x03,0xFE,0xE3,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x7F,0xC3,0xFF,0xB7,0xF8,
      0x00,0x07,0xF6,0xC3,0xCC,0x00,0x00,0x00,
      0x00,0x00,0x00,0x7F,0x83,0xFF,0xDF,0xFC,
      0x00,0x03,0xF6,0xC3,0xFC,0x00,0x00,0x00,
      0x00,0x00,0x00,0x7F,0x81,0xFF,0xEB,0xFE,
      0x00,0x01,0xF5,0xC7,0x82,0x00,0x00,0x00,
      0x00,0x00,0x00,0x3F,0x81,0xEF,0xE9,0xFE,
      0x00,0x00,0x7D,0xC5,0xFA,0x00,0x00,0x00,
      0x00,0x00,0x00,0x3F,0x00,0xFF,0xF5,0xFF,
      0x00,0x00,0x7D,0xEB,0xFE,0x00,0x00,0x00,
      0x00,0x00,0x00,0x3F,0x00,0x7F,0xDD,0xFF,
      0x80,0x00,0x7D,0xF3,0xFA,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0x00,0x72,0xC9,0xFF,
      0xC0,0x00,0x75,0xF9,0xF4,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0x80,0xFA,0xA9,0xAF,
      0xC0,0x00,0x77,0xFF,0xFC,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0x81,0xEA,0x9B,0xAF,
      0xE0,0x00,0xF6,0xFF,0xF8,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1E,0xE3,0xF6,0xE7,0xCF,
      0xE0,0x20,0xF6,0xFF,0xE8,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1E,0xFF,0xF8,0x0F,0xFF,
      0xF0,0x7F,0xFE,0xFF,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0xEF,0xFC,0x7F,0xFE,
      0xF8,0x6F,0xFE,0xFF,0xF0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0xBF,0xFF,0xFF,0xFE,
      0xB8,0x61,0xFE,0xFF,0xF0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0xFF,0xE7,0xFF,0xFF,
      0xBB,0xBF,0xFF,0xBF,0x70,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0xFF,0xC7,0xFF,0x85,
      0xFE,0x7F,0xFF,0x8E,0xC0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x1F,0xFF,0x8F,0xCF,0xC3,
      0xFE,0xFF,0xFF,0x8E,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x0F,0xFB,0x3F,0xFB,0xE2,
      0xFE,0xFF,0xF9,0x8E,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x0F,0x8E,0xFF,0xFC,0xFE,
      0xFE,0xFF,0xF1,0x8D,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x07,0xF9,0xFF,0xFE,0xFF,
      0x7E,0xFF,0xE1,0x8A,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xF1,0xFF,0xFF,0x7F,
      0x7E,0xFF,0xE1,0x9E,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x43,0xFB,0xFF,0xBF,
      0x7F,0xFF,0xFF,0xF4,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x03,0xF8,0xFF,0xFF,
      0x7E,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x03,0xF8,0x7F,0xF3,
      0x00,0x00,0x00,0x00,0x03,0xFC,0x79,0xC3,
      0xFE,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x03,0xF9,0x61,0xC3,
      0x3E,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x03,0xFD,0xE1,0xE2,
      0x3E,0x1F,0xFF,0xBC,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x03,0xFF,0xE3,0xEA,
      0x0E,0x0F,0xFD,0xBE,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x01,0xFF,0xF4,0x1F,
      0x1E,0x0F,0xFF,0xFF,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x01,0xFC,0x7E,0x73,
      0xFE,0x1F,0xFF,0xFF,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x01,0xF8,0xAE,0x3E,
      0x7C,0x3F,0xFF,0xFF,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0xFC,0x37,0x7F,
      0x3C,0x7F,0xFF,0xFF,0xE0,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x78,0x78,0x6E,
      0x1E,0x00,0x1E,0x07,0xF8,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x71,0x7F,0xC2,
      0x3F,0x00,0x7C,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x83,
      0x3F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xF7,
      0xF9,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x06,0xFF,0xFF,0xFF,0xFF,
      0xF0,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x3D,0xFF,0xFF,0xFF,0xFF,
      0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x06,0x03,0xFF,0xFF,0xFF,
      0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
      0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
uchar   code shengxiao8[]={
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xF0,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0xFF,
      0xFF,0xE0,0xFC,0x7F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF0,0x01,0xFF,0xFF,
      0xFF,0xC0,0x07,0xBF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0xFF,0xFF,
      0xFF,0xC0,0x01,0xDF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x00,0x70,0x7F,0xFF,
      0xFF,0x80,0x30,0xCF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFE,0x00,0x18,0x3F,0xFF,
      0xFF,0x00,0xFE,0x6F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xE0,0x00,0x0C,0x1F,0xFF,
      0xFF,0x01,0xFF,0xBF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF8,0x04,0x1F,0xFF,
      0xFF,0x01,0xDF,0x97,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x02,0x0F,0xFF,
      0xFF,0x03,0x9F,0xD7,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x0F,0xFF,
      0xFF,0x03,0x1F,0xEF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x07,0xFF,
      0xFC,0x01,0x1F,0xEF,0xFF,0xFF,0xFF,0xFF,
      0xFC,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x05,0xFF,
      0xFC,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x01,0xFF,
      0xF8,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0xFF,
      0xF0,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x7F,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x7F,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x7F,
      0xFC,0x40,0x0F,0xF0,0x00,0x1F,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x3F,
      0xFC,0x40,0x00,0x00,0x00,0x03,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x3F,
      0xFC,0x60,0x00,0x00,0x00,0x00,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x7F,
      0xFC,0x60,0x00,0x00,0x00,0x00,0x7F,0xFF,
      0xFF,0xFF,0x83,0xF8,0x00,0x00,0x00,0xFF,
      0xFC,0x60,0x00,0x00,0x00,0x00,0x3F,0xFF,
      0xFF,0xFE,0x00,0x00,0x00,0x00,0x07,0xFF,
      0xF8,0xE0,0x00,0x00,0x00,0x00,0x1F,0xFF,
      0xFF,0xFC,0x00,0x00,0x00,0x00,0x07,0xFF,
      0xFF,0xE0,0x00,0x00,0x00,0x00,0x0F,0xFF,
      0xFF,0xF8,0x00,0x00,0x00,0x00,0x07,0xFF,
      0xFF,0xF0,0x00,0x00,0x00,0x00,0x0F,0xFF,
      0xFF,0xF0,0x00,0x00,0x00,0x00,0x07,0xFF,
      0xFF,0xE0,0x00,0x00,0x00,0x00,0x03,0xFF,
      0xFF,0xE0,0x00,0x00,0x00,0x00,0x23,0xFF,
      0xFF,0xF8,0x00,0x00,0x00,0x00,0x0F,0xFF,
      0xFF,0xC0,0x00,0x00,0x00,0x00,0x63,0xFF,
      0xFF,0xC0,0x00,0x00,0x00,0x00,0x73,0xFF,
      0xFF,0xFC,0x00,0x00,0x00,0x00,0x0F,0xFF,
      0xFF,0xC0,0x00,0x00,0x00,0x00,0x7F,0xFF,
      0xFF,0xFE,0x00,0x00,0x00,0x00,0x0F,0xFF,
      0xFF,0x80,0x00,0x00,0x00,0x00,0x7F,0xFF,
      0xFF,0x80,0x00,0x00,0x00,0x00,0xFF,0xFF,
      0xFF,0xFF,0x00,0x00,0x00,0x00,0x1F,0xFF,
      0xFF,0xFF,0x80,0x00,0x00,0x00,0x1F,0xFF,
      0xFF,0xC0,0x00,0x00,0x00,0x00,0xFF,0xFF,
      0xFF,0xC0,0x00,0x00,0x00,0x01,0xFF,0xFF,
      0xFF,0xFF,0xC0,0x00,0x00,0x00,0x1F,0xFF,
      0xFF,0xFF,0xE0,0x06,0x00,0xF0,0x0F,0xFF,
      0xFF,0xFF,0xFC,0x07,0xFF,0xF0,0x07,0xFF,
      0xFF,0xC0,0x07,0x1E,0x00,0x01,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x03,0xFF,0xF8,0x03,0xFF,
      0xFF,0x80,0x07,0xFF,0xC0,0x00,0x7F,0xFF,
      0xFF,0xFF,0xFF,0x83,0xFF,0xF8,0x01,0xFF,
      0xFF,0x01,0x0F,0xFF,0xE0,0x40,0x3F,0xFF,
      0xFF,0xFF,0xFF,0x83,0xFF,0xFC,0x01,0xFF,
      0xFF,0x07,0x0F,0xFF,0xF0,0xF8,0x1F,0xFF,
      0xFF,0xFF,0xFF,0x83,0xFF,0xFE,0x01,0xFF,
      0xFE,0x0F,0x0F,0xFF,0xF0,0xFE,0x1F,0xFF,
      0xFE,0x1F,0x8F,0xFF,0xF0,0xFF,0x3F,0xFF,
      0xFF,0xFF,0xFF,0x83,0xFF,0xFF,0x09,0xFF,
      0xFE,0x3F,0xC7,0xFF,0xF0,0xFE,0x7F,0xFF,
      0xFF,0xFF,0xFF,0x83,0xFF,0xFF,0x08,0xFF,
      0xFE,0x3F,0xE7,0xFF,0xF0,0xFE,0x7F,0xFF,
      0xFF,0xFF,0xFF,0x93,0xFF,0xFF,0x18,0xFF,
      0xFE,0x3F,0xE3,0xFF,0xF1,0xFC,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x93,0xFF,0xFF,0x1C,0xFF,
      0xFE,0x3F,0xF1,0xFF,0xF9,0xF8,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x91,0xFF,0xFF,0x1C,0xFF,
      0xFE,0x3F,0xF0,0xFF,0xF9,0xF0,0xFF,0xFF,
      0xFE,0x3F,0xF8,0x7F,0xF9,0xE1,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x91,0xFF,0xFF,0x3C,0xFF,
      0xFE,0x3F,0xF8,0x7F,0xF8,0xC3,0xFF,0xFF,
      0xFE,0x3F,0xFC,0x3F,0xF8,0x8F,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x91,0xFF,0xFE,0x38,0xFF,
      0xFE,0x3F,0xFE,0x3F,0xF8,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x11,0xFF,0xFE,0x38,0xFF,
      0xFE,0x1F,0xFF,0xBF,0xF8,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x33,0xFF,0xFC,0x79,0xFF,
      0xFE,0x1F,0xFF,0xFF,0xFC,0x7F,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x79,0xFF,
      0xFF,0x1F,0xFF,0xFF,0xFC,0x7F,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFF,0xFF,
  uchar   code shengxiao9[]={
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,
      0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,
      0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,
      0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,
      0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE3,0xF8,
      0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0xFC,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xFE,
      0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xFF,
      0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0x8F,
      0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0x57,
      0x80,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFA,0xB7,
      0x80,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF6,0xEF,
      0x80,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0x1F,
      0x00,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFF,0xFC,
      0x00,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xFF,0xF8,
      0x00,0x8F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xEF,0xF0,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xDF,0xE0,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x80,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xFF,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0xFE,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,
      0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0x00,
      0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFE,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x03,0xFE,0x00,
      0x00,0x78,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x01,0xFC,0x08,
      0x00,0x3C,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0xFC,0x18,
      0xFF,0xFF,0xFF,0xFF,0xFC,0x70,0x38,0x3C,
      0x00,0x18,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF8,0xF8,0x18,0x3C,
      0xFF,0xFF,0xFF,0xFF,0xF8,0xFE,0x00,0x7C,
      0x00,0x11,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x00,0x7C,
      0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0x80,0x7C,
      0x00,0x01,0xFC,0x3F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xC1,0x7E,
      0x00,0x01,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xF3,0xFE,
      0x00,0x01,0xE7,0xE7,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFC,0x7F,0xFF,0xFE,
      0x00,0x01,0xCF,0xF3,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,
      0x00,0x01,0x9F,0xF9,0xFF,0xFF,0xFF,0xFF,
      0x00,0x01,0x9F,0xFC,0xFF,0xFF,0xFF,0xFF,
      0x00,0x01,0xFF,0xFC,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x01,0xFC,
      0x00,0x01,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x04,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x00,
      0x00,0x03,0xFF,0xFC,0xFF,0xFF,0xFF,0xFF,
      0x00,0x07,0xFF,0xFC,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0xC0,
      0x00,0x0F,0xFF,0xFD,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xE0,
      0x00,0x07,0xFF,0xF9,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x98,
      0x00,0x33,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x1E,
      0x00,0x11,0xFF,0xE7,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,
      0x80,0x18,0xFF,0x8F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,
      0xFF,0x0E,0x3E,0x1F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x03,0x8F,
      0xFF,0x8F,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x0F,
      0xE0,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x0F,
      0xC0,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7C,0x0F,
      0x87,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,
  uchar   code shengxiao10[]={
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x03,0xFF,
      0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xF0,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x78,0xFF,
      0xA0,0x63,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0x9E,0x7F,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE2,0x02,0x3E,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC4,0x01,0x3E,
      0x08,0xCF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xCA,0x00,0x3E,
      0x11,0x47,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC4,0x00,0x00,
      0x21,0xCF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xD1,0x80,0x20,
      0x50,0x8F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC4,0x00,0x31,
      0xD8,0x47,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC8,0xF8,0x3F,
      0x9F,0x23,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC3,0xDE,0x1F,
      0x8F,0x83,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x8C,0x01,0x1F,
      0x9E,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x91,0xC0,0x1F,
      0x88,0x17,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x27,0x00,0x1F,
      0x80,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x48,0x00,0x1F,
      0x82,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x90,0xC0,0x1F,
      0x85,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFD,0x06,0x00,0x1F,
      0x8D,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFC,0x08,0x00,0x1F,
      0x9B,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF8,0x10,0x00,0x3F,
      0x92,0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF8,0xA0,0x00,0x3F,
      0x80,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF1,0x00,0x00,0x7F,
      0x80,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF3,0x00,0xF0,0x7F,
      0x92,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF6,0x01,0x00,0x7F,
      0x92,0xA7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xE4,0x42,0x00,0x7F,
      0xA2,0xB7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xEC,0x84,0x00,0x7F,
      0x2A,0x97,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF9,0x01,0x00,0x3F,
      0x7A,0xB7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xD3,0x00,0x00,0x3C,
      0x16,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF2,0x00,0x03,0x00,
      0x80,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF6,0x08,0x1F,0x87,
      0x04,0x93,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xE6,0x04,0x32,0xF2,
      0x21,0xA3,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xEC,0x00,0x7D,0xB8,
      0xC9,0x23,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xED,0x08,0x7B,0xDC,
      0x1B,0x67,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xED,0x44,0xE7,0xBC,
      0x37,0x47,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xE9,0x00,0xC6,0x1C,
      0x26,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFB,0x88,0xCF,0x3C,
      0x04,0xCF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFB,0xC0,0xCE,0x0C,
      0x09,0x8F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x9E,0x34,
      0x61,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x1D,0x34,
      0x72,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x7C,0x20,
      0x78,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x3E,0x48,
      0x71,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x1F,0x00,
      0x47,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x07,0xC0,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x1F,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0A,0xAF,
      0x92,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF4,0x39,0xA4,
      0x94,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7E,0x62,
      0x84,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x7F,0x88,
      0x09,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x3F,0xE4,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x3F,0x93,
      0xF4,0xDF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xC7,
      0xF8,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0x0F,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x03,0xEF,
      0xF0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x03,0x0F,
      0xE4,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x03,0xC7,
      0x82,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x03,0xC0,
      0x09,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x03,0xC2,
      0xA5,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x03,0xEA,
      0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x03,0xFE,
      0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x03,0xFF,
      0xFF,0xFF,0xFE,0x00,0x00,0x00,0x03,0xFF,
uchar   code shengxiao11[]={
      0xFF,0xFF,0xFF,0xFE,0x3F,0xFF,0xFB,0xFF,
      0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xF3,0xFF,
      0xFF,0xFF,0xFF,0xFE,0x0F,0xFF,0xC3,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0x33,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x80,0x3C,0xF7,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x17,0xFF,
      0xFF,0xFF,0xFF,0xFC,0xC0,0x60,0x17,0xFF,
      0xFF,0xFF,0xFF,0xFE,0x60,0x90,0x2F,0xFF,
      0xFF,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xF7,0x10,0x90,0x0F,0xFF,
      0xFF,0xFF,0xF7,0xEF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xF3,0x88,0xF0,0x1F,0xFF,
      0xFF,0xFF,0xF1,0xE7,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xF8,0xC0,0x00,0x1F,0xFF,
      0xFF,0xFF,0xF0,0xC7,0xBF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xF8,0x60,0x00,0x3F,0xFF,
      0xFF,0xFF,0xF8,0x43,0x3F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFC,0x18,0x00,0x3F,0xFF,
      0xFF,0xFE,0x00,0x02,0x3F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x1F,0xFF,
      0xFF,0xFE,0x00,0x00,0x1F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x1F,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x1F,0xFF,
      0xFF,0xFC,0x00,0x00,0x13,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x1F,0xFF,
      0xFF,0xF0,0x00,0x00,0x03,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x2F,0xFF,
      0xFF,0xE0,0x00,0x00,0x03,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0xEF,0xFF,
      0xFF,0xC0,0x03,0xC0,0x07,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x02,0xEF,0xFF,
      0xFF,0xFC,0x1F,0xF0,0x07,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x0C,0xC7,0xFF,
      0xFF,0xF8,0x7F,0xF8,0x07,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x3F,0x07,0xFF,
      0xFF,0xF8,0xFF,0xFC,0x07,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x4C,0x0B,0xFF,
      0xFF,0xF1,0xFF,0xFE,0x0F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF0,0xF0,0x2B,0xFF,
      0xFF,0xF3,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xE2,0xC0,0x19,0xFF,
      0xFF,0xF7,0xFF,0xFF,0x01,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xEA,0x05,0x00,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x03,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF1,0x04,0x80,0x7F,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x2C,0x02,0x0F,
      0xFF,0xFF,0xFF,0xFF,0xFE,0xA4,0x0A,0x01,
      0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0xA0,0x06,0x40,
      0x07,0xFF,0xFF,0xFF,0x01,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x40,0x20,0x00,
      0x00,0x1F,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x60,0xE3,
      0x18,0x01,0xFF,0xFE,0x07,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x02,0x00,0x20,
      0x86,0x20,0x1F,0xFC,0x0F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x01,0x01,0x07,
      0x0C,0x18,0x07,0xF8,0x3F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x07,0x01,0x00,
      0x00,0x30,0xC3,0xE0,0x07,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x11,0x03,0x84,
      0x00,0x00,0x61,0x80,0x0F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x50,0x00,0x02,
      0x04,0x01,0x00,0x00,0x3F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x30,0x08,0x07,
      0x0C,0x10,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x04,0x00,
      0x00,0x18,0x60,0x00,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x0C,0x08,
      0x00,0x00,0x10,0x00,0x7F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x04,
      0x0C,0x00,0x60,0x3F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x01,0x20,0x1C,
      0x06,0x30,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x60,0x80,
      0x0C,0x08,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x40,
      0x00,0x30,0x10,0x1F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x01,0xC0,
      0x00,0x00,0x18,0x1F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x00,
      0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xE0,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x03,0xFF,
      0xFF,0xFE,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x07,0xFF,
      0xFF,0xFF,0xC0,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x0F,0xFF,
      0xFF,0xFF,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x1F,0xFF,
      0xFF,0xFF,0xF8,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x3F,0xFF,
      0xFF,0xFF,0xFC,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0xFF,
      0xFF,0xFF,0xFE,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0xFF,0xFF,
      0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF1,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xC3,0xFF,0xFF,
      0xFF,0xFF,0xFE,0x07,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFC,0x1F,0xFF,0xFF,0xFF,0xFF,
uchar   code shengxiao12[]={
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFD,0x1F,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x8F,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x4F,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x47,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x23,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x07,0xF0,0x21,0xFF,
      0xFF,0xFF,0xFF,0xFE,0xC1,0xF0,0x21,0xFF,
      0xFF,0xFF,0xFF,0xFE,0x20,0x70,0x20,0xFF,
      0xFE,0x00,0x1F,0xFF,0x7F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x11,0x80,0x30,0xFF,
      0xF0,0x00,0x03,0xFE,0x7F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x86,0x00,0x10,0x7F,
      0xC0,0x00,0x00,0xFE,0x37,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xCC,0x04,0x10,0x3F,
      0x00,0x00,0x00,0x3E,0x2F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xD0,0x04,0x00,0x8C,
      0x00,0x00,0x00,0x1E,0x7F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xC1,0xC2,0x01,0x00,
      0x00,0x00,0x00,0x0F,0x3F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x81,0x43,0x01,0x00,
      0x00,0x00,0x00,0x07,0x7F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x80,0x01,0xC6,0x00,
      0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x38,0x00,
      0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0x00,0xC0,0x00,0x00,
      0xFF,0xFF,0xFF,0xFE,0x01,0xC0,0x00,0x00,
      0xFF,0xFF,0xFF,0xFC,0x01,0xC0,0x00,0x00,
      0xFF,0xFF,0xF8,0x40,0x01,0xF0,0x00,0x00,
      0xFF,0xFF,0xE0,0x54,0x01,0xF0,0x00,0x00,
      0xFF,0xFF,0xE0,0x2C,0x01,0xE0,0x00,0x00,
      0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xC0,0x28,0x00,0xE0,0x00,0x00,
      0xFF,0xFF,0xD8,0x20,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xDB,0x20,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0x9B,0x20,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0x83,0x20,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xC3,0x20,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xE0,0x40,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xF0,0xC0,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xE0,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,
      0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x00,
      0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,
      0x00,0x00,0x38,0x03,0xFF,0xFF,0xFF,0xFF,
      0x00,0x00,0x38,0x07,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x00,
      0x00,0x00,0x78,0x07,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,
      0x00,0x00,0x70,0x0F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x18,0x00,
      0x00,0x00,0xF0,0x1F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x3C,0x00,
      0x00,0x60,0xE8,0x3F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x7C,0x00,
      0x03,0xE9,0xE4,0x7F,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xE4,0xF8,0x0F,
      0xFF,0xE5,0xC8,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFA,0xF8,0x1F,
      0xFF,0xC3,0xD9,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xF4,0x3F,
      0xFF,0xFB,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF2,0x3F,
      0xFF,0xFF,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x7F,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEE,0xFF,
      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,
void main(void)
        LCD12864_init(); //初始化液晶
        disp(shengxiao1);
        delay(200);
        disp(shengxiao2);
        delay(200);
        disp(shengxiao3);
        delay(200);
        disp(shengxiao4);
        delay(200);
        disp(shengxiao5);
        delay(200);
        disp(shengxiao6);
        delay(200);
        disp(shengxiao7);
        delay(200);
        disp(shengxiao8);
        delay(200);
        disp(shengxiao9);
        delay(200);
        disp(shengxiao10);
        delay(200);
        disp(shengxiao11);
        delay(200);
        disp(shengxiao12);
        delay(200);
void  writwo(uchar dat,  bit cemordat) // 向LCD12864 写入命令或者数据
        busy();         // 忙检测
        RW = 0;         // 拉低RW
        RS = cemordat;  // 判断写入的是命令还是数据  1:数据   0:命令
        P0 = dat;       // 将数据送至数据端口
        EN = 1;         // 使能信号
        EN = 0;         // 按照时序来操作
        PSB = 1;       //8 位并口工作模式
        writwo(0x36,0); // 基本指令集
        writwo(0x36,0); //显示设置
        writwo(0x3E,0);// 光标设置
        writwo(0x0c,0);// 游标设置
        writwo(0x01,0); //清屏
void  busy(void)  // 忙检测
        uchar i = 250;// 局部变量
        RS = 0; //拉低
        RW = 1; //拉高
        EN = 1; //使能
        while((i > 0) && (P0 & 0x80))i--; //判断忙标志位
        EN = 0; //释放
void  delay(uint c)
    uchar a,b;
        for(; c>0; c--)
                for(b=200; b>0; b--)
                        for(a=60; a>0; a--);
原资料放的位置不对,现己改回来 十二生肖图片.rar (8.3 KB, 下载次数: 60)
参与人数 7黑币 +136 收起 理由
站着说话不腰疼 + 8
钻牛尖滴刘尖尖 + 10
areyouok + 35 很给力!
shuisheng + 15 赞一个!
#include51.h + 8 绝世好帖!
Sawardeakar + 10 一级棒!
收藏收藏6 分享淘帖 顶 踩
ID:469932 发表于 2019-2-2 19:00 | 只看该作者
也再研究这个板子
参与人数 1黑币 +12 收起 理由
找人PK + 12
ID:472325 发表于 2019-2-6 05:32 | 只看该作者
还好,我也是用的普中
参与人数 2黑币 +50 收起 理由
zhengchong60 + 15
yoxi + 35
ID:472268 发表于 2019-2-13 16:42 | 只看该作者
普中的正好用
ID:478073 发表于 2019-2-19 19:20 | 只看该作者
好,我也是用的普中
参与人数 2黑币 +30 收起 理由
sheng7533967 + 15
zhengchong60 + 15
ID:461428 发表于 2019-2-24 18:46
下载的竟然是HEX文件。。浪费我黑比。。。
ID:116400 发表于 2019-6-26 08:52 | 只看该作者
大哥你这就不太地道了,怎么是HEX文档呢,好歹你也把图片给搞上来我们自己取模也行啊
ID:21069 发表于 2019-8-22 18:54 | 只看该作者
原C的代码不是就在这里么?是你没有好好看!
ID:602921 发表于 2019-8-23 07:32 | 只看该作者
谢谢分享!
