查看: 1557|回复: 2
单片机门禁系统仿真不出来 求帮助
回帖奖励 5 黑币 回复本帖可获得 1 黑币奖励! 每人限 1 次
#include<reg52.h>
#include<intrins.h>
#define uintunsigned int
#define ucharunsigned char
ucharnum,count,wordbuf[4],pwbuf[4],pw[4],i,flag,tt,a,k;
uchartemp,mima,j,key,key1,key2,key3,key4,key5,key6,key7,key8,key9,key10,key11,key12,key13,key14,key15,key16;
uchar codetable[]={0x79,0x77,0x77,0x3f,0x77,0x3f,0x73,0x79,0x37,0x40,0x76};
uchar codetable1[]={0x3f,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x67};
bit pwflag;
bit enterflag;
bit removeflag;
bit zhuhuflag;
bit fangkeflag;
sbit sda=P2^7;
sbit scl=P2^6;
void dylen(uintz);
void init();
voidwrite_add(uchar address,uchar date);
ucharread_add(uchar address);
voidxianshierror();
voidxianshiopen();
voidxianshigang();
voidxianshimima();
voidxianshishuzi();
void jzkey();
void zhuhu();
void fangke();
void mmbj();
void hujiao();
main()
   P1=0X00;
   P1=0x04;
   //初始密码
   pw[0]=1;
   pw[1]=2;
   pw[2]=3;
   pw[3]=4;
   enterflag=0;
   removeflag=0;
   //定时中断
   tt=0;
   TMOD=0X01;
   TH0=(65536-50000)/256;
   TL0=(65536-50000)%256;
   EA=1;
   ET0=1;
   TR0=1;
   init();//24c02初始化
   for(k=0;k<4;k++)                   //写入AT24C02
               write_add(23+k,pw[k]);
               dylen(1000);
          pw[k]=read_add(23+k);
         jzkey();
         zhuhu();
         fangke();
         mmbj();
         hujiao();
         if(removeflag==1)
              count=0;
               flag=3;
               P1=0X04;
               key14=0;
               xianshigang();
void hujiao()           //呼叫子程序
   if(key14==1)
     a=pwbuf[count]+pwbuf[count-1]+pwbuf[count-2]-1;
   switch(a)
      case 2:
               P1=0x12;
            break;
        case 3:
               P1=0x22;
               break;
        case 4:
               P1=0x32;
               break;
        case 5:
               P1=0x42;
               break;
        case 6:
               P1=0x52;
            break;
        case 7:
               P1=0x62;
               break;
        case 8:
               P1=0x72;
               break;
void mmbj()           //密码比较子程序
        if(enterflag==1)
                count=0;
                 enterflag=0;
                 for(i=0;i<4;i++)
             if(pw==pwbuf)
                   flag=1;
                   flag=2;
                            P1=0x01;//同speaker=1报警声;
                   i=4;
         if(flag==1)
              xianshiopen();
               P1=0x08;
              if(flag==2)
              xianshierror();
void fangke()           //访客子程序
   if(key15==1)
        fangkeflag=1;
       xianshigang();
     if(fangkeflag==1)
        xianshishuzi();
        zhuhuflag=0;
void zhuhu()           //住户子程序
    if(key16==1)
        zhuhuflag=1;
        xianshigang();
       if(zhuhuflag==1)
        xianshimima();
        fangkeflag=0;
voidxianshierror()           //显示错误提示
   P2=0xfe,P0=table[9],dylen(5),P2=0xff;
   P2=0xfd,P0=table[0],dylen(5),P2=0xff;
   P2=0xfb,P0=table[1],dylen(5),P2=0xff;
   P2=0xf7,P0=table[2],dylen(5),P2=0xff;
   P2=0xef,P0=table[3],dylen(5),P2=0xff;
   P2=0xdf,P0=table[4],dylen(5),P2=0xff;
voidxianshiopen()
   P2=0xfd,P0=table[9],dylen(5),P2=0xff;
   P2=0xfb,P0=table[5],dylen(5),P2=0xff;
   P2=0xf7,P0=table[6],dylen(5),P2=0xff;
   P2=0xef,P0=table[7],dylen(5),P2=0xff;
   P2=0xdf,P0=table[8],dylen(5),P2=0xff;
voidxianshigang()
   P2=0xfb,P0=table[9],dylen(5),P2=0xff;
   P2=0xf7,P0=table[9],dylen(5),P2=0xff;
   P2=0xef,P0=table[9],dylen(5),P2=0xff;
   P2=0xdf,P0=table[9],dylen(5),P2=0xff;
voidxianshimima()         //显示密码保护
   if(count==1)
         P2=0xdf,P0=table[10],dylen(5),P2=0xff;
   if(count==2)
         P2=0xef,P0=table[10],dylen(5),P2=0xff;
   if(count==3)
         P2=0xf7,P0=table[10],dylen(5),P2=0xff;
    if(count==4)
         P2=0xfb,P0=table[10],dylen(5),P2=0xff;
voidxianshishuzi()    //显示数字门号
   if(count==1)
         P2=0xdf,P0=table1[pwbuf[count]],dylen(5),P2=0xff;
   if(count==2)
         P2=0xdf,P0=table1[pwbuf[count-1]],dylen(5),P2=0xff;
         P2=0xef,P0=table1[pwbuf[count]],dylen(5),P2=0xff;
   if(count==3)
         P2=0xef,P0=table1[pwbuf[count-2]],dylen(5),P2=0xff;
         P2=0xf7,P0=table1[pwbuf[count-3]],dylen(5),P2=0xff;
void dylen(uintz)
   uint x,y;
   for(x=z;x>0;x--)
     for(y=110;y>0;y--);
void jzkey()   //矩阵键盘
   P3=0xfe;
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
       dylen(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
              temp=P3;
               switch(temp)
                    case0xee:
                      pwbuf[count]=0,count++,key16=2,key15=2,removeflag=0;
                       break;
                     case 0xde:
                      pwbuf[count]=1,count++,key16=2,key15=2,removeflag=0;
                       break;
                     case 0xbe:
                       pwbuf[count]=2,count++,key16=2,key15=2,removeflag=0;
                       break;
                   case 0x7e:
                      pwbuf[count]=3,count++,key16=2,key15=2,removeflag=0;
                       break;
               while(temp!=0xf0)
                    temp=P3;
                      temp=temp&0xf0;
   P3=0xfd;
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
       dylen(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
              temp=P3;
               switch(temp)
                    case0xed:
                      pwbuf[count]=4,count++,key16=2,key15=2,removeflag=0;
                       break;
                     case 0xdd:
                       pwbuf[count]=5,count++,key16=2,key15=2,removeflag=0;
                       break;
                     case 0xbd:
                      pwbuf[count]=6,count++,key16=2,key15=2,removeflag=0;
                       break;
                   case 0x7d:
                      pwbuf[count]=7,count++,key16=2,key15=2,removeflag=0;
                       break;
               while(temp!=0xf0)
                    temp=P3;
                      temp=temp&0xf0;
   P3=0xfb;
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
       dylen(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
              temp=P3;
               switch(temp)
                    case0xeb:
                       pwbuf[count]=8,count++,key16=2,key15=2,removeflag=0;
                       break;
                     case 0xdb:
                      pwbuf[count]=9,count++,key16=2,key15=2,removeflag=0;
                       break;
                     case 0xbb:
                       enterflag=1,key16=2,key15=2;
                       break;
                   case 0x7b:
                       removeflag=1,key16=2,key15=2;
                       break;
               while(temp!=0xf0)
                    temp=P3;
                      temp=temp&0xf0;
   P3=0xf7;
   temp=P3;
   temp=temp&0xf0;
   if(temp!=0xf0)
       dylen(10);
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
              temp=P3;
               switch(temp)
                    case0xe7:
                       key13=12,key16=2,key15=2;
                       break;
                     case 0xd7:
                       key14=1,key16=2,key15=2;
                       break;
                     case 0xb7:
                       key15=1,key16=2;
                       break;
                   case 0x77:
                       key16=1,key15=2;
                       break;
               while(temp!=0xf0)
                    temp=P3;
                      temp=temp&0xf0;
void zd()interrupt 1
   tt++;
//-------------------------------------------//AT24C02
uchar a;
void delay()
void start()  //开始信号
       sda=1;
       delay();
       scl=1;
       delay();
       sda=0;
       delay();
void stop()   //停止
       sda=0;
       delay();
       scl=1;
       delay();
       sda=1;
       delay();
voidrespons()  //应答
       uchar i;
       scl=1;
       delay();
       while((sda==1)&&(i<250))i++;
       scl=0;
       delay();
void init()
       sda=1;
       delay();
       scl=1;
       delay();
voidwrite_byte(uchar date)
       uchar i,temp;
       temp=date;
       for(i=0;i<8;i++)
              temp=temp<<1;
              scl=0;
          delay();
              sda=CY;
              delay();
              scl=1;
              delay();
       //     scl=0;
     //  delay();
       scl=0;
       delay();
       sda=1;
       delay();
uchar read_byte()
       uchar i,k;
       scl=0;
       delay();
       sda=1;
       delay();
       for(i=0;i<8;i++)
              scl=1;
              delay();
              k=(k<<1)|sda;
              scl=0;
              delay();
       return k;
void delay1(ucharx)
       uchar a,b;
       for(a=x;a>0;a--)
        for(b=100;b>0;b--);
void write_add(ucharaddress,uchar date)
       start();
       write_byte(0xa0);
       respons();
       write_byte(address);
       respons();
       write_byte(date);
       respons();
       stop();
       uchar date;
       start();
       write_byte(0xa0);
       respons();
       respons();
       start();
       write_byte(0xa1);
       respons();
       date=read_byte();
       stop();
       return date;
数码管显示不出
数码管显示不出
ID:303383 发表于 2019-1-10 21:49 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:446674 发表于 2019-2-11 12:36 | 只看该作者
资料不够详细
