查看: 1364|回复: 1
单片机温度湿度测量连上位机
ID:461367 发表于 2019-1-12 15:21 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include "reg51.h"
#include "stdio.h"
#include "intrins.h"
#include "LCD1602.h"
#include "fmq.h"
#include "key.h"
sbit dq=P2^3;
uchar wenduh;
uchar wendul;
uchar shiduh;
uchar shidul;
uchar wendu;
uchar shidu;
uchar wendus;
uchar shidus;
uchar wendux;
uchar shidux;
uchar keyv;
uchar mode;
uchar n=0;
uchar x;
//uchar flag=2;
void delay1(uint n)
        uint i,j;
        for(i=0;i<n;i++)
          for(j=0;j<100;j++);
bit init_dht11()
        uchar num;
        bit flag;
        dq=0;
        delay1(20);
        dq=1;
        for(num=0;num<11;num++);
        for(num=0;num<12;num++);
        flag=dq;
        for(num=0;num<24;num++);
        return flag;
uchar dht11_rd_char()
        uchar byte=0;
        uchar num;
        uchar num1;
        while(dq==1);
        for(num1=0;num1<8;num1++)
                while(dq==0);
                byte<<=1;
                for(num=0;dq==1;num++);
                if(num<10)
                        byte|=0x00;
                        byte|=0x01;
        return byte;
void dht11_dushu()
        uchar num;
        if(init_dht11()==0)
                shiduh=dht11_rd_char();
                shidul=dht11_rd_char();
                wenduh=dht11_rd_char();
                wendul=dht11_rd_char();
                shidu=(shiduh*256+shidul)/10;
                wendu=(wenduh*256+wendul)/10;
                for(num=0;num<20;num++);
                dq=1;
                shidu=00;
                wendu=00;
void display()
          write_char(1,0,'w');
                write_char(1,1,'n');
                write_char(1,2,'d');
                write_char(1,3,'u');
                write_char(1,4,':');
                write_data(wendu/10%10+48);
                write_data(wendu%10+48);
                write_char(1,9,0xdf);
                write_char(1,10,'C');
                write_char(2,0,'s');
                write_char(2,1,'h');
                write_char(2,2,'i');
                write_char(2,3,'d');
                write_char(2,4,'u');
                write_char(2,5,':');
                write_data(shidu/10%10+48);
                write_data(shidu%10+48);
                write_char(2,10,'%');
        wendu=0;
        shidu=0;
        wendus=40;
        wendux=20;
        shidus=90;
        shidux=20;
  delay1(100);
        Init_LCD1602();
                dht11_dushu();
                delay1(300);
                if(n%2==0)
                        display();
                        delay1(300);
                else if(n%2==1)
                        write_str(1,0,"wMax:");
                        write_data(wendus/10%10+48);
                        write_data(wendus%10+48);
                        write_str(2,0,"wMin:");
                        write_data(wendux/10%10+48);
                        write_data(wendux%10+48);
                        write_str(1,8,"sMax:");
                        write_data(shidus/10%10+48);
                        write_data(shidus%10+48);
                        write_str(2,8,"sMin:");
                        write_data(shidux/10%10+48);
                        write_data(shidux%10+48);
                        if(k2==0)
                                write_com(0x01);
                                delay1(10);
                                if(k2==0)
                                        x++;
                        if(x%4==1)
                                write_char(1,7,'<');
                                if(k3==0)
                                        delay1(10);
                                        if(k3==0)
                                                wendus++;
                                else if(k4==0)
                                        delay1(10);
                                        if(k4==0)
                                                wendus--;
                        else if(x%4==2)
                                write_char(2,7,'<');
                                if(k3==0)
                                        delay1(10);
                                        if(k3==0)
                                                wendux++;
                                else if(k4==0)
                                        delay1(10);
                                        if(k4==0)
                                                wendux--;
                        else if(x%4==3)
                                write_char(1,15,'<');
                                if(k3==0)
                                        delay1(10);
                                        if(k3==0)
                                                shidus++;
                                else if(k4==0)
                                        delay1(10);
                                        if(k4==0)
                                                shidus--;
                        else if(x%4==0)
                                write_char(2,15,'<');
                                if(k3==0)
                                        delay1(10);
                                        if(k3==0)
                                                shidux++;
                                else if(k4==0)
                                        delay1(10);
                                        if(k4==0)
                                                shidux--;
                if(k1==0)
                        delay1(10);
                        if(k1==0)
                                n++;
                                write_com(0x01);
温度测量上下限.rar
51.1 KB, 下载次数: 8, 下载积分: 黑币 -5
ID:1 发表于 2019-1-12 17:27 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
