查看: 5067|回复: 6
网上买51开发板,自学单片机,写了一个蜂鸣器发声的程序,下载进去蜂鸣器不响。程....
#include<reg52.h>
sbit BUZZ =P1^6;
unsigned int code NoteFrequ[]={523,587,659,698,784,880,988,1047,1175,1319,1397,1568,1760,1976};
unsigned int code NoteReload[]={
   65536-(11059200/12)/(523*2),
  65536-(11059200/12)/(587*2),
  65536-(11059200/12)/(659*2),
  65536-(11059200/12)/(698*2),
  65536-(11059200/12)/(784*2),
  65536-(11059200/12)/(880*2),
  65536-(11059200/12)/(988*2),
  65536-(11059200/12)/(1047*2),
  65536-(11059200/12)/(1175*2),
  65536-(11059200/12)/(1319*2),
  65536-(11059200/12)/(1397*2),
  65536-(11059200/12)/(1568*2),
  65536-(11059200/12)/(1760*2),
  65536-(11059200/12)/(1976*2),
bit enable =1;
  bit tmrflag=0;
  unsigned char T0RH=0xFF;
unsigned char T0RL=0x00;
void PlayTwoTiger();
unsigned int i;
EA=1;
TMOD=0x01;
TH0=T0RH;
TL0=T0RL;
ET0=1;
TR0=1;
  PlayTwoTiger();
  for(i=0;i<40000;i++);
void PlayTwoTiger()
unsigned char beat;
unsigned char note;
unsigned int time=0;
unsigned int beatTime=0;
unsigned int soundTime=0;
unsigned char code  TwoTigerNote[]={
     1, 2, 3, 1,   1, 2, 3, 1,   3,4,5,  3,4,5,
     5,6,5,4,3,1,  5,6,5,4,3,1,  1,5,1,  1,5,1,
unsigned char code  TwoTigerBeat[]={4,  4 , 4  ,4,      4 , 4 , 4 , 4,     4,4,8,      4,4,8,
                                    3,1,3,1 ,4, 4,       3,1,3,1,4,4,     4,4,8,      4,4,8,
  for(beat=0;beat<sizeof(TwoTigerNote); )
while(!tmrflag);
beep=0;
delay(1);
beep=1;
delay(1);
tmrflag=0;
if(time==0)
   note = TwoTigerNote[beat] - 1;
  T0RH = NoteReload[note]>> 8;
  T0RL = NoteReload[note];
  beatTime = (TwoTigerBeat[beat] * NoteFrequ[note])>>2;
  soundTime = beatTime - (beatTime>>2);
  enable = 1;
  time++;
  if(time >=beatTime)
   time =0;
   beat++;
   time++;
   if(time==soundTime)
    enable=0;
void InterruptTimer0() interrupt 1
TH0=T0RH;
TL0=T0RL;
tmrflag=1;
if(enable)
  BUZZ=~BUZZ;
  BUZZ=1;
ID:467499 发表于 2019-1-13 18:04 | 只看该作者
有懂的大神帮忙看下啊,谢谢。
ID:379933 发表于 2019-1-14 00:10 | 只看该作者
定时器那里貌似有问题,我建议新手干脆用STC下载器里的软件延时计算器算出来,我是这个学期才开的单片机课如果说错了请多包涵。
参与人数 7黑币 +245 收起 理由
刀刀见红 + 35
shuisheng60 + 35 很给力!
yoxi + 35 很给力!
找人PK + 35 很给力!
areyouok + 35 赞一个!
jinsheng7533967 + 35
#include51.h + 35 说出自己的想法这很好
ID:454000 发表于 2019-1-14 01:56 | 只看该作者
给一个能发声音的程式你烧进去看看,看是外围电路没接好还是程式本声的问题,曼慢来,别急!
#include<reg52.h>
sbit SPK=P1^6;    //定义喇叭端口
unsigned char frq;
void DelayUs2x(unsigned char t);//函数声明
void DelayMs(unsigned char t);
void Init_Timer0(void)
TMOD |= 0x01;          //使用模式1,16位定时器,
EA=1;            //总中断打开
ET0=1;           //定时器中断打开
TR0=1;           //定时器开关打开
main()
unsigned char i;
Init_Timer0(); //初始化定时器
   frq=0;
   for(i=0;i<60;i++)//播放1s左右一种频率
      DelayMs(10);
   frq=100;
   for(i=0;i<60;i++)//播放1s左右另外一种频率
      DelayMs(10);
while(--t);
while(t--)
     //大致延时1mS
     DelayUs2x(245);
         DelayUs2x(245);
               //  定时器中断子程序
void Timer0_isr(void) interrupt 1
TH0=0xfe;                  //重新赋值
TL0=frq;         //低8位值在主程序中不断累加
SPK=!SPK;        //端口电平取反
参与人数 5黑币 +82 收起 理由
还有谁? + 15
zhengchong60 + 15
Sawardeakar + 10
yoxi + 12 赞一个!
admin + 30 回帖助人的奖励!
ID:21069 发表于 2019-2-13 20:49 | 只看该作者
呵呵公园 发表于 2019-1-14 00:10
定时器那里貌似有问题,我建议新手干脆用STC下载器里的软件延时计算器算出来,我是这个学期才开的单片机课 ...
说出自己的想法这很好
参与人数 1黑币 +8 收起 理由
嘉立创AAA + 8 很给力!
ID:213173 发表于 2019-2-14 13:52 | 只看该作者
1.你首先确认开发板上是无源蜂鸣器,否则响了也不是你想要的音乐声。
2.你的程序不能通过编译,蜂鸣器端口定义名称与程序中指令不符,delay延时程序漏写。修改后经仿真可以发出音乐声。
#include<reg52.h>
sbit BUZZ =P1^6;
bit enable =1;
bit tmrflag=0;
void delay(unsigned int k)
        unsigned int i,j;
        for(i=k;i>0;i--)
                for(j=110;j>0;j--);
        unsigned int i;
        EA=1;
        TMOD=0x01;
        TH0=T0RH;
        TL0=T0RL;
        ET0=1;
        TR0=1;
                PlayTwoTiger();
void PlayTwoTiger()
        unsigned char beat;
        unsigned char note;
        5,6,5,4,3,1,  5,6,5,4,3,1,  1,5,1,  1,5,1,};
        3,1,3,1 ,4, 4,       3,1,3,1,4,4,     4,4,8,      4,4,8,};
                while(!tmrflag);
                        BUZZ=0;
                        delay(1);
                        BUZZ=1;
                        delay(1);
                tmrflag=0;
                if(time==0)
                        enable = 1;
                        time++;
                        if(time >=beatTime)
                                time =0;
                                beat++;
                                time++;
                                if(time==soundTime)
                                        enable=0;
        TH0=T0RH;
        TL0=T0RL;
        tmrflag=1;
        if(enable)
          BUZZ=~BUZZ;
          BUZZ=1;
ID:476644 发表于 2019-2-15 13:27 | 只看该作者
会不会是硬件的问题啊?
