查看: 919|回复: 0
找单片机大神帮忙,不会啊自己写不出来头疼
#include "reg52.h        "
#define uint unsigned int
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit k1=P3^0;
sbit k3=P3^3;
sbit k2=P3^2;
sbit  key=P3^1;
sbit beep=P1^5;
uchar code table[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x67};
uint  num;
void keyscan();
void display();
void delay(uint i)
        while(i--);
void DigDisplay(uchar  i)
        for(i=0;i<2;i++)
                switch(i)
                        case(0):
                                LSA=0;LSB=0;LSC=0; break;
                        case(1):
                                LSA=1;LSB=0;LSC=0; break;
                P0=table[num];
                delay(100);
                P0=0x00;
        void display()
                                                DigDisplay(0);
                                                P0=table[num%10];
                                                delay(10);
                                                P0=0x00;
                                                DigDisplay(1);
                                                P0=table[num/10];
                                                delay(10);
                                                P0=0x00;
void Int1Init()
        IT1=1;
        EX1=1;
        EA=1;
void Int1()        interrupt 2
        delay(1000);
        if(k3==0)
                delay(10);
         if(k3==0)
                                                        P0=table[num];
                                                        num++;
                                delay(1000);//Ñóê±ò»Ãë
                                if(k3==0)
                                        num+=2;
//                                                        if(num==0)
//                                                        {num=9;}
                                                        while(!k3);
        void Int0Init()
        IT0=1;
        EX0=1;
        EA=1;
void Int0()        interrupt 0
        delay(1000);
        if(k2==0)
                delay(10);
         if(k2==0)
                                                         P0=table[num];
                                                        num--;
                                                        if(num==0)
                                                        {num=9;}
                                                        while(!k2);
        void keyscan()
                                 if(k1==0)
                                                 delay(50);
                                         if(k1==0)
                                                        P0=table[num];
                                                        num=0;
                if(key==0)
                                delay(20);
                                        if(key==0)
                                   long   uint m;
                                                        P0=0x00;
                                        for(m=0;m<=9;m++)
                                                        P0=table[m];
                                                        P2=0xf1;
                                                        delay(19505);
        beep=~beep;
        Int0Init();
        Int1Init();
        DigDisplay();
        keyscan ();
        display();
