查看: 1408|回复: 2
单片机掉电保护程序的BUG
ID:480106 发表于 2019-2-24 20:48 | 显示全部楼层 |阅读模式
我在打万年历,给时间进行赋值,加入掉电保护后,虽然能够保护,但显示的时间和我赋的值完全不一样,哪位大神能帮我看看?
#include <reg52.h>
#define uint unsigned int
bit write=0;        //д24C02??????
sbit sda=P2^0;
sbit scl=P2^1;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit key4=P3^3;
sbit BEEP=P3^7;
sbit beep=P3^7;
uint code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uint code table1[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x80};
uint num,num0,miao=30,fen=28,shi=11,fen1=30,shi1=16,s1,s2,m1,m2,m3,m4,h1,h2,h3,h4,r=23,y=2,n=2019,z,a,b,c,d,e,X,nian,yue,ri;
uchar i,j;
  void shijian();                           //???
  void riqi();                              //????
  void keyscan();                           //????
  void xingqi();       //????
// void naozhong();
void delayms(uint xms)//????????
uint i,j;
for(i=xms;i>0;i--)
     for(j=248;j>0;j--);
void shijian()   //???????????
s2=miao/10;
    s1=miao%10;
    m2=fen/10;
    m1=fen%10;
    h2=shi/10;
    h1=shi%10;
   P2=0x00;
   P0=table[s1];
   delayms(1);
   P0=0X0;
   P2=0x04;
   P0=table[s2];
   delayms(1);
   P0=0X0;
   P2=0x08;
   P0=0x40;
   delayms(1);
   P0=0X0;
   P2=0x0c;
   P0=table[m1];
   delayms(1);
   P0=0X0;
   P2=0x10;
   P0=table[m2];
   delayms(1);
   P0=0X0;
   P2=0x14;
   P0=0x40;
   delayms(1);
   P0=0X0;
   P2=0x18;
   P0=table[h1];
   delayms(1);
   P0=0X0;
   P2=0x1c;
   P0=table[h2];
   delayms(1);
   P0=0X0;
void riqi()    //????????????
   P2=0x00;
   P0=table1[r%10];
   delayms(1);
   P0=0X0;
   P2=0x04;
   P0=table1[r/10];
   delayms(1);
   P0=0X0;
   P2=0x08;
   P0=0x80;
   delayms(1);
   P0=0X0;
   P2=0x08;
   P0=table1[y%10];
   delayms(1);
   P0=0X0;
   P2=0x0c;
   P0=table1[y/10];
   delayms(1);
   P0=0X0;
   P2=0x10;
   P0=0x80;
   delayms(1);
   P0=0X0;
   P2=0x10;
   P0=table1[n%10];
   delayms(1);
   P0=0X0;
   P2=0x14;
   P0=table1[n%1000%100/10];
   delayms(1);
   P0=0X0;
   P2=0x18;
   P0=table1[n%1000/100];
   delayms(1);
   P0=0X0;
   P2=0x1c;
   P0=table1[n/1000];
   delayms(1);
   P0=0X0;
void xingqi()       //????????????
   int yue=y ;
   int nian=n  ;
   int ri=r;
   if(yue==2||yue==1)
     nian-=1;
  yue+=12;
   num0=(ri+2*yue+3*(yue+1)/5+nian+nian/100+yue/400)%7-1;
   switch(num0)
      case 0:P0=table[2];P2=0x04;break;
   case 1:P0=table[3];P2=0x04;break;
   case 2:P0=table[4];P2=0x04;break;
   case 3:P0=table[5];P2=0x04;break;
   case 4:P0=table[6];P2=0x04;break;
   case 5:P0=table[7];P2=0x04;break;
      case 6:P0=table[8];P2=0x04;break;
void delay0(){;;}
void start()  //??????
sda=1;
delay0();
scl=1;
delay0();
sda=0;
delay0();
void stop()   //??
sda=0;
delay0();
scl=1;
delay0();
sda=1;
delay0();
void respons()  //???
uchar i;
scl=1;
delay0();
while((sda==1)&&(i<250))i++;
scl=0;
delay0();
void init()//IIC?????????
sda=1;
delay0();
scl=1;
delay0();
void write_byte(uchar date)//д?????????
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
  temp=temp<<1;
  scl=0;
     delay0();
  sda=CY;
  delay0();
  scl=1;
  delay0();
scl=0;
delay0();
sda=1;
delay0();
uchar read_byte()//???????????
uchar i,k;
scl=0;
delay0();
sda=1;
delay0();
for(i=0;i<8;i++)
  scl=1;
  delay0();
  k=(k<<1)|sda;
  scl=0;
  delay0();
return k;
void write_add(uchar address,uchar date)//??????д??????
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
char read_add(uchar address)//??????????????
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
/*void naozhong()
    if(miao==0)
   if(fen==0)
     if(shi==0||1||2||3||4||5||6||7||8||9||10||11||12||13||14||15||16||17||18||19||20||21||22||23||24)
    beep=~beep;
if(miao==0)
   if(fen==1)
    beep=0;
void keyscan()     //????????????
if(key1==0)
delayms(10);
if(key1==0)        //???K1??????
  z=1;      //???
    while(!key1)    //??????
   riqi();
  while(z)         //?????????????????????
   riqi();
if(key1==0)
delayms(10);
if(key1==0)
     z=1;
  while(!key1)
      xingqi();
  while(z)        //?л?????
      xingqi();
   if(key1==0)
       delayms(10);
    if(key1==0)
        z=0;
     while(!key1)
      xingqi();
   if(key1==0)      //??????K1????????????
    delayms(10);
    if(key1==0)
     z=0;
               riqi();
if(key1==0)
     delayms(10);
  if(key1==0)
      X=1;
   while(!key1);
       xingqi();
   while(X)
       xingqi();
    if(key1==0)
    delayms(10);
    if(key1==0)
        X=0;
     while(!key1);
     xingqi();
   if(key2==0)         //????????K2?????????л?
   delayms(10);        //????
   if(key2==0)        //???K2??????
      c=1;          //???
      while(!key2);       //??????
       riqi();
     while(c)         //?????????????????????
     riqi();
      delayms(10);
      if(key1==0)
        c=0;
     while(!key1);     //??????
      riqi();
         if(key3==0)                                //????key3????
     delayms(10);
       if(key3==0)           //??Ρ?????
          r++;
           while(!key3)
           riqi();
    if(key4==0)                             //????key4????
       delayms(10);
       if(key4==0)
          r--;
        if(r==0)
         r=30;      //???????ж?28??29??30??31
            while(!key4)
             riqi();
   delayms(10);        //????
      d=1;          //???
       riqi();
     while(d)         //?????????????????????
     riqi();
     if(key1==0)      //??????K1??????μ???
      delayms(10);
      if(key1==0)
        d=0;
      riqi();
     delayms(10);
          y++;
           while(!key3)
           riqi();
       delayms(10);
       if(key4==0)
      if(y==1)
          y=12;
      y--;
            while(!key4)
             riqi();
   delayms(10);        //????
      e=1;          //???
       riqi();
     while(e)         //?????????????????????
     riqi();
      delayms(10);
      if(key1==0)
        e=0;
      riqi();
     delayms(10);
          n++;
           while(!key3)
           riqi();
       delayms(10);
       if(key4==0)
          n--;
            while(!key4)
             riqi();
///////////////-------------???仯-------????---------------------////////////////////////////////////////////////////
   delayms(10);
       miao++;
   write_add(1,miao);
        while(!key3)
        shijian();
  if(key4==0)                             //????key4??????
   delayms(10);
     if(key4==0)
        miao--;
   write_add(1,miao);
      if(miao==-1)
     miao=59;
         while(!key4)
           shijian();
///////////////-------------???仯-----????-----------------------////////////////////////////
if(key2==0)         //????????K2??????????л?
   delayms(10);        //????
      a=1;          //???
       shijian();
     while(a)         //???????????????????
     shijian();
      delayms(10);
      if(key1==0)
        a=0;
      shijian();
     delayms(10);
          fen++;
      write_add(2,fen);
           while(!key3)
           shijian();
       delayms(10);
       if(key4==0)
          fen--;
      write_add(2,fen);
        if(fen==-1)
         fen=59;
            while(!key4)
             shijian();
///////////////////-----------???仯-------С?-------------///////////////////////////
      delayms(10);        //????
         b=1;          //???
         while(!key2)       //??????
         shijian();
        while(b)         //???????????????????
        shijian();
          delayms(10);
         if(key1==0)
           b=0;
         shijian();
         delayms(10);
            shi++;
        write_add(3,shi);
             while(!key3)
             shijian();
           delayms(10);
           if(key4==0)
           shi--;
       write_add(3,shi);
         if(shi==-1)
           shi=23;
              while(!key4)
               shijian();
void main()   //??????
    init();
miao=read_add(1);
if(miao>60)
miao=0;
fen=read_add(2);
shi=read_add(3);
  TMOD=0x01;      //????????0????????1
    TH0=(65536-45872)/256;
    TL0=(65536-45872)%256;
EA=1;      //???ж??????
    ET0=1;      //????????ж?
TR0=1;      //????????
    xingqi();
shijian();
keyscan();
//naozhong();
   /* if(shi1==shi,fen1=fen)
BEEP=~BEEP;
    if(fen1=31)
   BEEP=0;
void T0_time()interrupt 1  //??????ж?
    num++;
    if(num==20)       //1????
     num=0;
    miao++;
    write_add(1,miao);
if(miao==60)            //????60s??????1min????
    miao=0;       //??????0
    write_add(1,miao);
    fen++;         //??????
    write_add(2,fen);
   if(fen==60)      //????60min??????1h????
      fen=0;       //??????0
   write_add(2,fen);
      shi++;       //??????
   write_add(3,shi);
        if(shi==24)      //????24h???????????
        shi=0;       //?????0
     write_add(3,shi);
        r++;         //??????
       if(y==1||y==3||y==5||y==7||y==8||y==10||y==12)
        if(r==32)      //????32?????????μ???
           r=1;       //???????1
           y++;        //??????
    if(y==13)      // ???12?
       y=1;         //???μ???1
    n++;      //????
             if(y==4||y==6||y==9||y==11) //???y?4,6,9,11
            if(r==31)     //????31?????????μ???
               r=1;      //???????1
               y++;      //??????
               if(n%4==0||n%400==0||n%100!=0)     //????????4????
                if(y==2)      //???μ???2 ????29??
                  if(r==30)     //????29?
               r=1;     //???????1
               y++;     //??????
                      if(n%4!=0)   //????????4????
                    if(y==2)    //???μ???2 ????28??
                  if(r==29)   //????28?
                  r=1;    //???????1
                  y++;    //??????
ID:123289 发表于 2019-2-25 07:57 | 显示全部楼层
需要硬件支持,求图。
ID:480106 发表于 2019-3-3 14:26 | 显示全部楼层
yzwzfyz 发表于 2019-2-25 07:57
需要硬件支持,求图。
   int yue=y ;
   int nian=n  ;
   int ri=r;
   if(yue==2||yue==1)
     nian-=1;
  yue+=12;
   switch(num0)
用这个算法输入年月日计算星期,本年的一月和二月算上一年的十三月和十四月,但是数码管的月份显示13,14,有什么建议吗?
