查看: 5032|回复: 8
用pic16f630 MCU實現的315MHZ无线軟件解碼和編碼.代替PT2272和pt2262
ID:86688 发表于 2019-3-8 14:16 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
  1. #include <pic.h>
  2. //#include <pic16630.h>
  4. #define uint unsigned int
  5. #define PORTAIT(adr,bit) ((unsigned)(&adr)*8+(bit)) ///絕對尋址位操作指令
  6. #define PORTCIT(adr,bit)((unsigned)(&adr)*8+(bit)) ///絕對尋址位操作指令
  7. static bit KEY1 @ PORTAIT(PORTA,0);
  8. static bit KEY2 @ PORTAIT(PORTA,1);
  9. static bit KEY3 @ PORTAIT(PORTA,4);
  10. static bit KEY4 @ PORTAIT(PORTA,5);
  11. static bit DECODE_POWER_ON_OFF @ PORTCIT(PORTC,0);
  12. static bit LED1 @ PORTCIT(PORTC,1);
  13. static bit LED2 @ PORTCIT(PORTC,5);
  14. static bit BEEP @ PORTCIT(PORTC,2);
  15. static bit DIN  @ PORTCIT(PORTC,3);
  16. static bit DOUT @ PORTCIT(PORTC,4);
  17. uint i;
  18. uchar keyCode;
  19. bit sign_key;
  20. #define Err 0xFF                //當解碼程序發現接收的數據是無效數據時返回此值
  21. char DeviceAddr[9]="1010ffff";  //報警器的地址,1 接高電平,0 接低電平(地), F 為懸空.(人可讀)
  22. uchar AddrH,AddrL;              //產品地址(機可讀)
  23. void delay_150us(uchar t)
  24. {   uchar k;
  25.     uchar j;
  26.       for(k=t;k>0;k--)
  27.       for(j=50;--j;);
  28. }
  29. void delay_50us(uchar t)
  30. {
  31.       uchar k;
  32.       uchar i;
  33.       for(k=t;k>0;k--)
  34.       for(i=14;--i;);
  35. }
  36. void Convert()          //人可讀地址轉換為MCU可讀
  37. {
  38.     uchar i;
  39.     for(i=0;i<4;i++){
  40.         if(DeviceAddr[i]=='0')
  41.         {   AddrH<<=2;
  42.             AddrH|=0;
  43.         }
  44.         if(DeviceAddr[i]=='1')
  45.         {
  46.             AddrH<<=2;
  47.             AddrH|=3;
  48.         }
  49.         if(DeviceAddr[i]=='f')
  50.         {
  51.             AddrH<<=2;
  52.             AddrH|=1;
  53.         }
  54.     }
  55.         for(i=4;i<8;i++){
  56.         if(DeviceAddr[i]=='0')
  57.         {
  58.             AddrL<<=2;
  59.             AddrL|=0;
  60.         }
  61.         if(DeviceAddr[i]=='1')
  62.         {
  63.             AddrL<<=2;
  64.             AddrL|=3;
  65.         }
  66.         if(DeviceAddr[i]=='f')
  67.         {
  68.             AddrL<<=2;
  69.             AddrL|=1;
  70.         }
  71.     }
  72. }
  73. void Send(uchar *DAddr,uchar SendData)
  74. {       uchar temp,i;
  75.         DOUT=1;
  76.         delay_150us(2);
  77.         DOUT=0;
  78.         delay_150us(60);
  79.         for(i=0;i<8;i++)//Send AddrCode
  80.         {   temp=*DAddr++;
  81.             if(temp=='1')
  82.             {   DOUT=1;
  83.                 delay_150us(6);
  84.                 DOUT=0;
  85.                 delay_150us(2);
  86.                 DOUT=1;
  87.                 delay_150us(6);
  88.                 DOUT=0;
  89.                 delay_150us(2);
  90.             }
  91.             if(temp=='f')
  92.             {   DOUT=1;
  93.                 delay_150us(2);
  94.                 DOUT=0;
  95.                 delay_150us(6);
  96.                 DOUT=1;
  97.                 delay_150us(6);
  98.                 DOUT=0;
  99.                 delay_150us(2);
  100.             }
  101.             if(temp=='0')
  102.             {   DOUT=1;
  103.                 delay_150us(2);
  104.                 DOUT=0;
  105.                 delay_150us(6);
  106.                 DOUT=1;
  107.                 delay_150us(2);
  108.                 DOUT=0;
  109.                 delay_150us(6);
  110.             }
  111.         }
  112.         for(i=0;i<4;i++)///Send Data
  113.         {   if(SendData&(8>>i))
  114.             {
  115.                 DOUT=1;
  116.                 delay_150us(6);
  117.                 DOUT=0;
  118.                 delay_150us(2);
  119.                 ////////////////////
  120.                 DOUT=1;
  121.                 delay_150us(6);
  122.                 DOUT=0;
  123.                 delay_150us(2);
  124.             }
  125.             else
  126.             {
  127.                 DOUT=1;
  128.                 delay_150us(2);
  129.                 DOUT=0;
  130.                 delay_150us(6);
  131.                 ///
  132.                 DOUT=1;
  133.                 delay_150us(2);
  134.                 DOUT=0;
  135.                 delay_150us(6);
  136.             }
  137.         }
  138. }
  139. uchar GetData()//解碼程序
  140. {
  141.          uchar i,j,k;
  142.          uchar ReadCode[3],GetCode;
  143.          //------------------------找同步頭-------------------------
  144.          if(!DIN)return Err;
  145.          delay_150us(3);
  146.          for(i=0;i<28;i++)
  147.          {
  148.             if(DIN)return Err;
  149.             delay_150us(2);
  150.          }
  151.          for(i=0;i<30;i++)
  152.          {
  153.             if(DIN)break;
  154.             delay_50us(1);
  155.             if(i>25)return Err;//如果超時則返回
  156.          }
  157.         //-----------------------接收地址碼和數據碼-----------------
  158.          for(j=0;j<3;j++)
  159.          {
  160.             for(i=0;i<8;i++)
  161.             {
  162.                 delay_150us(2);
  163.                 delay_50us(1);
  164.                 ReadCode[j]=ReadCode[j]<<1;
  165.                 ReadCode[j]=ReadCode[j]|DIN;
  166.                 if(DIN)
  167.                 {       //while(DIN);//等待0出現
  168.                         for(k=0;k<255;k++)
  169.                          {  delay_50us(2);
  170.                             if(DIN==0)break;
  171.                             if(k>12)return Err;//超時,返回錯誤代碼
  172.                          }
  173.                 }
  174.                 //while(!DIN);//等待1出現
  175.                 for(k=0;k<255;k++)
  176.                  {  delay_50us(2);
  177.                     if(DIN==1)break;
  178.                     if(k>12)return Err;//超時,返回錯誤代碼
  179.                  }
  180.             }
  181.          }
  182.         //-------------------校驗地址及運算數據---------------------
  183.               if(ReadCode[0]!=AddrH)return Err;
  184.               if(ReadCode[1]!=AddrL)return Err;//校驗地址
  185.               GetCode=ReadCode[2]&0x01;
  186.               GetCode|=(ReadCode[2]&0x04)>>1;
  187.               GetCode|=(ReadCode[2]&0x10)>>2;
  188.               GetCode|=(ReadCode[2]&0x40)>>3;
  189.               return GetCode;
  190. }
  191. void delay(){ for(i=6553;i!=0;i--)continue;}
  192. void beep(void)
  193. {   uchar i;
  194.     for(i=0;i<0xff;i++)
  195.     {   delay_150us(5);
  196.         BEEP=!BEEP;
  197.     }
  198.     BEEP=0;
  199. }
  200. void interrupt ISR(void) //中斷服務程序
  201. {
  202.     if(RAIE && RAIF)
  203.     {   RAIF = 0;
  204.         delay();
  205.         if(KEY1==0){sign_key=1;keyCode=1;}
  206.         if(KEY2==0){sign_key=1;keyCode=2;}
  207.         if(KEY3==0){sign_key=1;keyCode=3;}
  208.         if(KEY4==0){sign_key=1;keyCode=4;}
  209.         //PORTA = PORTA;
  210.     }
  211. /* if(T0IE && T0IF) //判TMR0 中斷
  212.     {
  213.         T0IF = 0; //清除TMR0 中斷標誌
  214.     }
  215.     if(TMR1IE && TMR1IF) //判TMR1 中斷
  216.     {
  217.         TMR1IF = 0; //清除TMR1 中斷標誌
  218.     }*/
  219. }
  220. void main()
  221. {
  222. uchar mydata;
  223.     DOUT=0; //發送數據端口上電為低電平
  224.     CMCON=0x07;     //關閉比較器
  225.     TRISA=0x33;     //PORTA_1為輸入。
  226.     OPTION=0x7f;    //弱上拉全局控制位使能
  227.     WPUA=0xFF;      //PORTA弱上拉控制位使能
  228.     TRISC=0x08;     //設置C口輸入輸出
  229.   RAIF=0;           //中斷標誌位清零
  230.   PORTA=0x00;       //配合  PORTA = PORTA 給電平中斷做準備
  231.   RAIE=1;           //A口電平中斷允許
  232.   IOCA=0x33;        //A口各個中斷允許
  233.   GIE =1;           //總中斷允許
  234.   PORTA = PORTA;
  235.   Convert();
  236.   Send("1010ffff",1);
  237. for(;;){
  238.     if(sign_key)
  239.         {   switch(keyCode){
  240.             case 1:
  241.                 LED1=0;
  242.                 Send(DeviceAddr,1);
  243.                 Send(DeviceAddr,1);
  244.                 Send(DeviceAddr,1);
  245.                 Send(DeviceAddr,1);
  246.                 break;
  247.             case 2:
  248.                 Send(DeviceAddr,2);
  249.                 Send(DeviceAddr,2);
  250.                 Send(DeviceAddr,2);
  251.                 Send(DeviceAddr,2);
  252.                 LED1=1;
  253.                 break;
  254.             case 3:
  255.                 Send(DeviceAddr,4);
  256.                 Send(DeviceAddr,4);
  257.                 Send(DeviceAddr,4);
  258.                 Send(DeviceAddr,4);
  259.                 LED2=1;
  260.                 DECODE_POWER_ON_OFF=1;
  261.                 break;
  262.             case 4:
  263.                 Send(DeviceAddr,8);
  264.                 Send(DeviceAddr,8);
  265.                 Send(DeviceAddr,8);
  266.                 Send(DeviceAddr,8);
  267.                 DECODE_POWER_ON_OFF=0;
  268.                 LED2=0;
  269.                 break;
  270.             }
  271.             sign_key=0;
  272.             //beep();
  273.         }
  274.         mydata=GetData();
  275.             if(mydata!=Err)
  276.             {
  277.                 if(mydata==1)LED1=0;
  278.                 if(mydata==2)LED1=1;
  279.                 if(mydata==4)LED2=0;
  280.                 if(mydata==8)LED2=1;
  281.             }
  282. }
  283. }
收藏收藏9 分享淘帖 顶1 踩
ID:1108700 发表于 2024-1-9 21:30 | 只看该作者
用一,两毛的能做吗
ID:103411 发表于 2023-11-7 16:16 | 只看该作者
学习一下解码方法,感谢楼主分享。
ID:1088608 发表于 2023-7-16 00:42 | 只看该作者
有没有流程图看看
ID:935260 发表于 2021-7-2 09:53 | 只看该作者
XSBCL 发表于 2021-1-29 16:40
你说的那些1.2.毛的芯片吗
使用过PIC的和国产,台席的芯片,PIC的性能确实好一些,输出波形稳定。
ID:745362 发表于 2021-1-29 16:40 来自手机 | 只看该作者
nanfuB 发表于 2020-11-15 17:34
630代2262有点得不偿失
你说的那些1.2.毛的芯片吗
ID:851448 发表于 2020-11-30 00:45 | 只看该作者
可以的,不用浪费钱了
ID:582276 发表于 2020-11-15 17:34 | 只看该作者
630代2262有点得不偿失
ID:300165 发表于 2020-9-26 19:13 | 只看该作者
稳定就好,省钱了
