查看: 2982|回复: 2
基于uCosII的WIFI巡检机器人程序设计
ID:215520 发表于 2019-3-13 11:31 | 显示全部楼层 |阅读模式
正面
正面
背面
背面
  1.         APP_Init();     //板子底层初始化
  2.         OSTick_Init();  //初始化滴答时钟
  3.
  4.         /* 创建信号量 */
  5.         Moto_Sem = OSSemCreate(1);//创建信号量(数量1)
  6.         Sound_Sem = OSSemCreate(1);//创建信号量(数量1)
  7.         /* 创建消息邮箱 */
  8.         Wifi_Box = OSMboxCreate((void*)0);//创建消息邮箱
  9.
  10.         /* 创建语音播报任务 */
  11.         OSTaskCreateExt((void (*)(void *)) SoundTask,
  12.                                   (void           *) 0,
  13.                                   (OS_STK         *)&SoundTask_Stk[SOUNDTASK_STK_SIZE - 1],
  14.                                   (INT8U           ) SOUNDTASK_PRIO,
  15.                                   (INT16U          ) SOUNDTASK_PRIO,
  16.                                   (OS_STK         *)&SoundTask_Stk[0],
  17.                                   (INT32U          ) SOUNDTASK_STK_SIZE,
  18.                                   (void           *) 0,
  19.                                   (INT16U          )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
  20.         /* 创建电机运动任务 */
  21.         OSTaskCreateExt((void (*)(void *)) MotoTask,
  22.                                   (void           *) 0,
  23.                                   (OS_STK         *)&MotoTask_Stk[MOTOTASK_STK_SIZE - 1],
  24.                                   (INT8U           ) MOTOTASK_PRIO,
  25.                                   (INT16U          ) MOTOTASK_PRIO,
  26.                                   (OS_STK         *)&MotoTask_Stk[0],
  27.                                   (INT32U          ) MOTOTASK_STK_SIZE,
  28.                                   (void           *) 0,
  29.                                   (INT16U          )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
  30.         /* 创建雷达任务 */
  31.         OSTaskCreateExt((void (*)(void *)) RadarTask,
  32.                                   (void           *) 0,
  33.                                   (OS_STK         *)&RadarTask_Stk[RADARTASK_STK_SIZE - 1],
  34.                                   (INT8U           ) RADARTASK_PRIO,
  35.                                   (INT16U          ) RADARTASK_PRIO,
  36.                                   (OS_STK         *)&RadarTask_Stk[0],
  37.                                   (INT32U          ) RADARTASK_STK_SIZE,
  38.                                   (void           *) 0,
  39.                                   (INT16U          )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
  40.         /* 创建wifi任务 */
  41.         OSTaskCreateExt((void (*)(void *)) WifiTask,
  42.                                   (void           *) 0,
  43.                                   (OS_STK         *)&WifiTask_Stk[WIFITASK_STK_SIZE - 1],
  44.                                   (INT8U           ) WIFITASK_PRIO,
  45.                                   (INT16U          ) WIFITASK_PRIO,
  46.                                   (OS_STK         *)&WifiTask_Stk[0],
  47.                                   (INT32U          ) WIFITASK_STK_SIZE,
  48.                                   (void           *) 0,
  49.                                   (INT16U          )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
  50.         /* 创建显示任务 */
  51.         OSTaskCreateExt((void (*)(void *)) DisplayTask,
  52.                                   (void           *) 0,
  53.                                   (OS_STK         *)&DisplayTask_Stk[DISPLAYTASK_STK_SIZE - 1],
  54.                                   (INT8U           ) DISPLAYTASK_PRIO,
  55.                                   (INT16U          ) DISPLAYTASK_PRIO,
  56.                                   (OS_STK         *)&DisplayTask_Stk[0],
  57.                                   (INT32U          ) DISPLAYTASK_STK_SIZE,
  58.                                   (void           *) 0,
  59.                                   (INT16U          )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
全部资料51hei下载地址:
Run_Check_Robot(ucos)_Release.7z (938.49 KB, 下载次数: 37)
ID:481884 发表于 2020-5-14 16:27 | 显示全部楼层
没有东西啊
ID:752551 发表于 2020-5-15 14:28 | 显示全部楼层
黑科技即视感,下载学习学习!!
