查看: 1982|回复: 5
用30个按键来控制5个电平输出,单片机程序哪里出错了?
ID:213173 发表于 2019-3-14 13:51 | 显示全部楼层
你的显示程序和数组写的都有问题,4*8矩阵键盘扫描程序也繁琐,不是很清楚你的用途,
给你改了一下,不影响P1高4位另做他用,直接用P0短暂显示键值1~32,经仿真无误。你可
以按需自行修改。
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. /*
  6. uchar code tab[]={0xfe,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,
  7.                   0xf6,0xf5,0xf4,0xf3,0xf2,0xf1,0xf0,0xef,
  8.                   0xee,0xed,0xec,0xeb,0xea,0xfe9,0xe8,0xe7,
  9.                   0xe6,0xe5,0xe4,0xeb3,0xe2,0xe1,0xeff};//输出二进制库
  10.                   //输出为11110 11101 到00001
  11. */
  12. uint  temp=0;//计数变量
  13. uchar key=0xff;//键值变量
  14. bit key_yes=0;//
  15. //void display();
  16. //void keyscan();
  17. /*
  18. void delay(uchar z)
  19. {
  20.         uchar x,y;
  21.         for(x=z;x>0;x--)
  22.                 for(y=100;y>0;y--);
  23. }*/
  24. void keyscan()    //4*8矩阵键盘扫描程序
  25. {
  26.         static bit sign=0;                        //按键自锁标志
  27.         static uint count=0;                //消抖计数变量
  28.         uint num,num1;
  29.         P1|=0x0f;//保持P1高4位不变,操作低4位1111
  30.         P1&=0xf0;//保持P1高4位不变,操作低4位0000
  31.         P2=0xff;//P2全高
  32.         num=(P1&0x00)<<8|P2;
  33.         if(num!=0x00ff)//判断有键按下
  34.         {
  35.                 if((++count>=250)&&(sign==0))//消抖与判断自锁
  36.                 {
  37.                         sign=1;                        //按键自锁标志置1
  38.                         P1|=0x0f;                //保持P1高4位不变,操作低4位1111
  39.                         P2=0x00;                        //P2全低
  40.                         num1=(P1&0x0f)<<8|P2;
  41.                         num|=num1;
  42.                         switch(num)
  43.                         {
  44.                                 case 0x0efe: key= 1; break;
  45.                                 case 0x0efd: key= 2; break;
  46.                                 case 0x0efb: key= 3; break;
  47.                                 case 0x0ef7: key= 4; break;
  48.                                 case 0x0eef: key= 5; break;
  49.                                 case 0x0edf: key= 6; break;
  50.                                 case 0x0ebf: key= 7; break;
  51.                                 case 0x0e7f: key= 8; break;
  52.                                 case 0x0dfe: key= 9; break;
  53.                                 case 0x0dfd: key=10; break;
  54.                                 case 0x0dfb: key=11; break;
  55.                                 case 0x0df7: key=12; break;
  56.                                 case 0x0def: key=13; break;
  57.                                 case 0x0ddf: key=14; break;
  58.                                 case 0x0dbf: key=15; break;
  59.                                 case 0x0d7f: key=16; break;
  60.                                 case 0x0bfe: key=17; break;
  61.                                 case 0x0bfd: key=18; break;
  62.                                 case 0x0bfb: key=19; break;
  63.                                 case 0x0bf7: key=20; break;
  64.                                 case 0x0bef: key=21; break;
  65.                                 case 0x0bdf: key=22; break;
  66.                                 case 0x0bbf: key=23; break;
  67.                                 case 0x0b7f: key=24; break;
  68.                                 case 0x07fe: key=25; break;
  69.                                 case 0x07fd: key=26; break;
  70.                                 case 0x07fb: key=27; break;
  71.                                 case 0x07f7: key=28; break;
  72.                                 case 0x07ef: key=29; break;
  73.                                 case 0x07df: key=30; break;
  74.                                 case 0x07bf: key=31; break;
  75.                                 case 0x077f: key=32; break;
  76.                         }
  77.                         key_yes=1;
  78.                 }
  79.         }
  80.         else                                                //键抬起
  81.         {
  82.                 sign=0;                                        //按键自锁标志清0
  83.                 count=0;                                //消抖计数清0
  84.         }
  85. }
  86. /*
  87. void display()
  88. {
  89.         {
  90.                 P0=tab[n1];
  91.         }
  92. }
  93. */
  94. void main()
  95. {
  96.         while(1)
  97.         {
  98.                 keyscan();
  99.                 if(key_yes==1)
  100.                 {
  101.                         P0=key;//读键值P0显示
  102.                         temp++;
  103.                         if(temp>=10000)//延时时间可调
  104.                         {
  105.                                 temp=0;
  106.                                 key_yes=0;
  107.                                 P0=0xff;
  108.                         }
  109.                 }
  110.         }
  111. }
