//包含头文件
#include <REG51.h>
#include<intrins.h>
//宏定义
#define LCM_Data P0 //将P0口定义为LCM_Data
#define uint unsigned int
//1602的控制脚
sbit lcd1602_rs=P2^5;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^7;
sbit Scl=P3^4; //24C02串行时钟
sbit Sda=P3^5; //24C02串行数据
sbit ALAM = P2^1; //报警
sbit KEY = P3^6; //开锁
bit pass=0; //密码正确标志
bit ReInputEn=0; //重置输入允许标志
bit s3_keydown=0; //3秒按键标志位
bit key_disable=0; //锁定键盘标志
unsigned char countt0,second; //t0中断计数器,秒计数器
void Delay5Ms(void); //声明延时函数
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盘扫描控制表
//液晶显示数据数组
unsigned char code start_line[] = {"password: "};
unsigned char code name[] = {"===Coded Lock==="}; //显示名称
unsigned char code Correct[] = {" correct "}; //输入正确
unsigned char code Error[] = {" error "}; //输入错误
unsigned char code codepass[] = {" pass "};
unsigned char code LockOpen[] = {" open "}; //OPEN
unsigned char code SetNew[] = {"SetNewWordEnable"};
unsigned char code Input[] = {"input: "}; //INPUT
unsigned char code ResetOK[] = {"ResetPasswordOK "};
unsigned char code initword[] = {"Init password..."};
unsigned char code Er_try[] = {"error,try again!"};
unsigned char code again[] = {"input again "};
unsigned char InputData[6]; //输入密码暂存区
unsigned char CurrentPassword[6]={0,0,0,0,0,0}; //读取EEPROM密码暂存数组
unsigned char TempPassword[6];
unsigned char N=0; //密码输入位数记数
unsigned char ErrorCont; //错误次数计数
unsigned char CorrectCont; //正确输入计数
unsigned char ReInputCont; //重新输入计数
unsigned char code initpassword[6]={0,0,0,0,0,0}; //输入管理员密码后将密码初始为000000
unsigned char code adminpassword[6]={1,3,1,4,2,0}; //输入管理员密码后将密码初始为000000
//=====================5ms延时==============================
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//===================400ms延时==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延时
uchar i;
while(t--)
for(i=0;i<125;i++)
void Nop(void) //空操作
_nop_(); //仅作延时用一条语句大约1us
_nop_();
_nop_();
_nop_();
/*****24c02程序参照24c02时序图*****/
/*起始条件*/
void Start(void)
Sda=1;
Scl=1;
Nop();
Sda=0;
Nop();
/*停止条件*/
void Stop(void)
Sda=0;
Scl=1;
Nop();
Sda=1;
Nop();
/*应答位*/
void Ack(void)
Sda=0;
Nop();
Scl=1;
Nop();
Scl=0;
/*反向应答位*/
void NoAck(void)
Sda=1;
Nop();
Scl=1;
Nop();
Scl=0;
/*发送数据子程序,Data为要求发送的数据*/
void Send(uchar Data)
uchar BitCounter=8;
uchar temp;
do
temp=Data; //将待发送数据暂存temp
Scl=0;
Nop();
if((temp&0x80)==0x80) //将读到的数据&0x80
Sda=1;
Sda=0;
Scl=1;
temp=Data<<1; //数据左移
Data=temp; //数据左移后重新赋值Data
BitCounter--; //该变量减到0时,数据也就传送完成了
while(BitCounter); //判断是否传送完成
Scl=0;
/*读一字节的数据,并返回该字节值*/
uchar Read(void)
uchar temp=0;
uchar temp1=0;
uchar BitCounter=8;
Sda=1;
do
Scl=0;
Nop();
Scl=1;
Nop();
if(Sda) //数据位是否为1
temp=temp|0x01; //为1 temp的最低位为1(|0x01,就是将最低位变为1)
else //如果为0
temp=temp&0xfe; //temp最低位为0(&0xfe(11111110)最低位就是0)
if(BitCounter-1) //BitCounter减1后是否为真
temp1=temp<<1; //temp左移
temp=temp1;
BitCounter--; //BitCounter减到0时,数据就接收完了
while(BitCounter); //判断是否接收完成
return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Send(*(PData+i));
Ack();
Stop();
mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Start();
Send(0xa1);
Ack();
*(PData+i)=Read();
Scl=0;
NoAck();
Stop();
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
#define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
//----------------延时函数,后面经常调用----------------------
void delay(uint xms)//延时函数,有参函数
uint x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
//--------------------------写指令---------------------------
void write_1602com(uchar com)//****液晶写入指令函数****
lcd1602_rs=0;//数据/指令选择置为指令
lcd1602_rw=0; //读写选择置为写
P0=com;//送入数据
delay(1);
lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
delay(1);
lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
//-------------------------写数据-----------------------------
void write_1602dat(uchar dat)//***液晶写入数据函数****
lcd1602_rs=1;//数据/指令选择置为数据
P0=dat;//送入数据
delay(1);
lcd1602_en=1; //en置高电平,为制造下降沿做准备
delay(1);
lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
//-------------------------初始化-------------------------
void lcd_init(void)
write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
write_1602com(0x0c);//开显示不显示光标
write_1602com(0x06);//整屏不移动,光标自动右移
write_1602com(0x01);//清显示
//==============将按键值编码为数值=========================
unsigned char coding(unsigned char m)
unsigned char k;
switch(m)
case (0x11): k=1;break;
case (0x21): k=2;break;
case (0x41): k=3;break;
case (0x81): k='A';break;
case (0x12): k=4;break;
case (0x22): k=5;break;
case (0x42): k=6;break;
case (0x82): k='B';break;
case (0x14): k=7;break;
case (0x24): k=8;break;
case (0x44): k=9;break;
case (0x84): k='C';break;
case (0x18): k='*';break;
case (0x28): k=0;break;
case (0x48): k='#';break;
case (0x88): k='D';break;
return(k);
//=====================按键检测并返回按键值===============================
unsigned char keynum(void)
unsigned char row,col,i;
P1=0xf0;
if((P1&0xf0)!=0xf0)
Delay5Ms();
Delay5Ms();
if((P1&0xf0)!=0xf0)
row=P1^0xf0; //确定行线
i=0;
P1=a[i]; //精确定位
while(i<4)
if((P1&0xf0)!=0xf0)
col=~(P1&0xff); //确定列线
break; //已定位后提前退出
i++;
P1=a[i];
return 0;
while((P1&0xf0)!=0xf0);
return (row|col); //行线与列线组合后返回
else return 0; //无键按下时返回0
//=======================一声提示音,表示有效输入========================
void OneAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
//========================二声提示音,表示操作成功========================
void TwoAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//========================三声提示音,表示错误========================
void ThreeAlam(void)
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//=======================显示提示输入=========================
void DisplayChar(void)
unsigned char i;
if(pass==1)
//DisplayListChar(0,1,LockOpen);
write_1602com(er); //在二行开始显示
for(i=0;i<16;i++)
write_1602dat(LockOpen[i]); //显示open 开锁成功
if(N==0)
//DisplayListChar(0,1,Error);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(Error[i]); //显示错误
//DisplayListChar(0,1,start_line);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(start_line[i]);//显示开始输入
//========================重置密码==================================================
void ResetPassword(void)
unsigned char i;
unsigned char j;
if(pass==0)
pass=0;
DisplayChar(); //显示错误
ThreeAlam(); //没开锁时按下重置密码报警3声
else //开锁状态下才能进行密码重置程序
if(ReInputEn==1) //开锁状态下,ReInputEn置1,重置密码允许
if(N==6) //输入6位密码
ReInputCont++; //密码次数计数
if(ReInputCont==2) //输入两次密码
for(i=0;i<6;)
if(TempPassword[i]==InputData[i]) //将两次输入的新密码作对比
i++;
else //如果两次的密码不同
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Error[j]); //显示错误Error
ThreeAlam(); //错误提示
pass=0; //关锁
ReInputEn=0; //关闭重置功能,
ReInputCont=0;
DisplayChar();
break;
if(i==6)
//DisplayListChar(0,1,ResetOK);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(ResetOK[j]); //密码修改成功,显示
TwoAlam(); //操作成功提示
WrToROM(TempPassword,0,6); //将新密码写入24C02存储
ReInputEn=0;
ReInputCont=0;
CorrectCont=0;
else //输入一次密码时
OneAlam();
//DisplayListChar(0, 1, again); //显示再次输入一次
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(again[j]); //显示再输入一次
for(i=0;i<6;i++)
TempPassword[i]=InputData[i]; //将第一次输入的数据暂存起来
N=0; //输入数据位数计数器清零
//=======================输入密码错误超过三过,报警并锁死键盘======================
void Alam_KeyUnable(void)
P1=0x00;
ALAM=~ALAM; //蜂鸣器一直闪烁鸣响
Delay5Ms();
//=======================取消所有操作============================================
void Cancel(void)
unsigned char i;
unsigned char j;
//DisplayListChar(0, 1, start_line);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(start_line[j]); //显示开机输入密码界面
TwoAlam(); //提示音
for(i=0;i<6;i++)
InputData[i]=0; //将输入密码清零
KEY=1; //关闭锁
ALAM=1; //报警关
pass=0; //密码正确标志清零
ReInputEn=0; //重置输入充许标志清零
ErrorCont=0; //密码错误输入次数清零
CorrectCont=0; //密码正确输入次数清零
ReInputCont=0; //重置密码输入次数清零
s3_keydown=0;
key_disable=0; //锁定键盘标志清零
N=0; //输入位数计数器清零
//==========================确认键,并通过相应标志位执行相应功能===============================
void Ensure(void)
unsigned char i,j;
RdFromROM(CurrentPassword,0,6); //从24C02里读出存储密码
if(N==6)
if(ReInputEn==0) //重置密码功能未开启
for(i=0;i<6;)
if(CurrentPassword[i]==InputData[i]) //判断输入密码和24c02中的密码是否相同
i++; //相同一位 i就+1
else //如果有密码不同
ErrorCont++; //错误次数++
if(ErrorCont==3) //错误输入计数达三次时,报警并锁定键盘
write_1602com(er);
for(i=0;i<16;i++)
do
Alam_KeyUnable();
while(1);
else //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
TR0=1; //开启定时
key_disable=1; //锁定键盘
pass=0; //pass位清零
break; //跳出
if(i==6) //密码输入对时
if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
WrToROM(initpassword,0,6); //强制将初始密码写入24C02存储
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(initword[j]); //显示初始化密码
TwoAlam(); //成功提示音
Delay400Ms(); //延时400ms
TwoAlam(); //成功提示音
N=0; //输入位数计数器清零
CorrectCont++; //输入正确变量++
if(CorrectCont==1) //正确输入计数,当只有一次正确输入时,开锁
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(LockOpen[j]); //显示open开锁画面
TwoAlam(); //操作成功提示音
KEY=0; //开锁
pass=1; //置正确标志位
TR0=1; //开启定时
for(j=0;j<6;j++) //将输入清除
InputData[i]=0; //开锁后将输入位清零
else //当两次正确输入时,开启重置密码功能
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(SetNew[j]); //显示重置密码界面
TwoAlam(); //操作成功提示
ReInputEn=1; //允许重置密码输入
CorrectCont=0; //正确计数器清零
else //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
write_1602com(er);
for(j=0;j<16;j++)
TwoAlam(); //成功提示音
TwoAlam(); //成功提示音
N=0; //输入位数计数器清零
else //密码输入错误
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Error[j]); //显示错误信息
ThreeAlam(); //错误提示音
pass=0;
else //当已经开启重置密码功能时,而按下开锁键,
//DisplayListChar(0,1,Er_try);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Er_try[j]); //错误,请重新输入
else //密码没有输入到6位时,按下确认键时
write_1602com(er);
for(j=0;j<16;j++)
pass=0;
N=0; //将输入数据计数器清零,为下一次输入作准备
//==============================主函数===============================
void main(void)
unsigned char KEY,NUM;
unsigned char i,j;
P1=0xFF; //P1口复位
TMOD=0x11; //定义工作方式
TL0=0xB0;
TH0=0x3C; //定时器赋初值
EA=1; //打开中断总开关
ET0=1; //打开中断允许开关
TR0=0; //打开定时器开关
Delay400Ms(); //启动等待,等LCM讲入工作状态
lcd_init(); //LCD初始化
write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
for(i=0;i<16;i++)
write_1602dat(name[i]);//向液晶屏写开机画面
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(start_line[i]);//写输入密码等待界面
write_1602com(er+9); //设置光标位置
write_1602com(0x0f); //设置光标为闪烁
Delay5Ms(); //延时片刻(可不要)
N=0; //初始化数据输入位数
while(1) //进入循环
if(key_disable==1) //锁定键盘标志为1时
Alam_KeyUnable(); //报警键盘锁
ALAM=1; //关报警
KEY=keynum(); //读按键的位置码
if(KEY!=0) //当有按键按下时
second=0; //秒清零
else //没有锁定键盘时
NUM=coding(KEY); //根据按键的位置将其编码,编码值赋值给NUM
switch(NUM) //判断按键值
case ('A'): ; break;
case ('B'): ; break;
case ('C'):
for(i=0;i<16;i++)
if(N>=1) N--; OneAlam(); //按键提示音
//DisplayOneChar(6+N,1,'*');
for(j=N;j<16;j++)
write_1602com(er+6+j);
write_1602dat(' ');
for(j=0;j<N;j++)
write_1602com(er+6+j); //显示位数随输入增加而增加
write_1602dat('*'); //但不显示实际数字,用*代替
InputData[N]=N+4;
break; //ABC是无定义按键
case ('D'): ResetPassword(); break; //重新设置密码
case ('*'): Cancel(); break; //取消当前输入
case ('#'): Ensure(); break; //确认键,
default: //如果不是功能键按下时,就是数字键按下
//DisplayListChar(0,1,Input);
if(N<6) //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(Input[i]); //显示输入画面
OneAlam(); //按键提示音
for(j=0;j<=N;j++)
InputData[N]=NUM; //将数字键的码赋值给InputData[]数组暂存
N++; //密码位数加
else //输入数据位数大于6后,忽略输入
N=6; //密码输入大于6位时,不接受输入
break;
//*********************************中断服务函数**************************************
void time0_int(void) interrupt 1 //定时器T0
TL0=0xB0;
TH0=0x3C; //定时器重新赋初值
//TR0=1;
countt0++; //计时变量加,加1次时50ms
if(countt0==20) //加到20次就是1s
countt0=0; //变量清零
second++; //秒加
if(pass==1) //开锁状态时
if(second==1) //秒加到1s时
TR0=0; //关定时器
TL0=0xB0;
TH0=0x3C; //再次赋初值
second=0; //秒清零
else //不在开锁状态时
if(second==3) //秒加到3时
TR0=0; //关闭定时器
second=0; //秒清零
key_disable=0; //锁定键盘清零
s3_keydown=0;
TL0=0xB0;
TH0=0x3C; //重新赋初值
TR0=1; //打开定时器
