查看: 5360|回复: 12
单片机LCD1602程序上电后出现白色方块如何解决?
5黑币
如题,在导入程序后运行出现如下图所示的状况。求助如何解决
基于STC89C52的IC智能水卡程序设计问题
主程序
  1. #include "reg52.h"
  2. #include "main.h"
  3. #include "mfrc522.h"
  4. #include<intrins.h>         //函数处理头文件
  5. #include<string.h>          //字符串处理头文件
  6. #include<stdio.h>           // 输入输出函数头文件
  7. /********************************************************************************************/
  8. //数值类别
  9. typedef signed   char      int8;                 // 有符号8位整型变量
  10. typedef unsigned char      uint8;                // 无符号8位整型变量
  11. typedef signed   int       int16;                // 有符号16位整型变量
  12. typedef unsigned int       uint16;               // 无符号16位整型变量
  13. /********************************************************************************************/
  14. // 定义特殊寄存器
  15. sfr wdt_contr=0xe1;                                 //定义看门狗地址
  16. sfr isp_data =0xe2;                                 //定义ISP数据寄存器
  17. sfr isp_addrh=0xe3;                                 //定义ISP地址高8位
  18. sfr isp_addrl=0xe4;                                 //定义ISP地址低8位
  19. sfr isp_cmd  =0xe5;                                 //定义ISP命令模式寄存器
  20. sfr isp_trig =0xe6;                                 //定义ISP命令触发寄存器
  21. sfr isp_contr=0xe7;                                 //定义ISP控制模式寄存器
  22. //unsigned char code data1[16] = {0x64,0x00,0x00,0x00,0x1B,0xFF,0xFF,0xFF,0x64,0x00,0x00,0x00,0x01,0xFE,0x01,0xFE};//100
  23. unsigned char code data1[16] = {0xC8,0x00,0x00,0x00,0x37,0xFF,0xFF,0xFF,0xC8,0x00,0x00,0x00,0x01,0xFE,0x01,0xFE};//200
  24. //M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
  25. //4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
  26. unsigned char data2[4]  = {0x00,0x00,0x00,0x01};//存值减值金额
  27. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; //密码
  28. unsigned char TYPE_DATA[2];//类型
  29. unsigned char ID_DATA[4];  //ID地址
  30. unsigned char value_DATA[4];//卡里面的值
  31. unsigned char g_ucTempbuf[20];//
  32. unsigned char code dis0[] = {"Total:"};
  33. unsigned char code dis1[] = {" "};
  34. unsigned char code dis2[] = {"CardID:"};
  35. unsigned char code dis3[] = {"Met:"};
  36. unsigned char code dis4[] = {" Card:"};
  37.
  38. unsigned char code dis6[] = {"0123456789ABCDEF"};
  39. unsigned int tt=0,keyfalg,falg_pro;
  40. unsigned char mc;
  41. uint16 tot=0,mon=0,card=0;
  42. uint8  a=0,b=0,c=0,d=0;
  43. /********************************************************************************************/
  44. //EEPROM驱动开始
  45. /*********************************************************************************
  46. * 函数名称:eepromEraseSector (uint16 address)
  47. * 功    能:EEPROM擦除程序
  48. * 入口参数:address
  49. * 出口参数:无
  50. **********************************************************************************/
  51. //擦除片内EEPROM的一个扇区
  52. //擦除只能以扇区为最小单位进行,没法只擦除一个字节
  53. //一个扇区是512个字节
  54. //本函数参数里面的地址落在哪个扇区,则该扇区内数据都将被擦除
  55. //例如:STC89C51RC片内EEPROM第一扇区开始地址为0x2000,结束地址为0x21ff
  56. //如果调用 eepromEraseSector(0x2001),则第一扇区内数据都将被擦除
  57. //擦除成功后,该扇区内各字节都将变为0xff
  58. void eepromEraseSector (uint16 address)
  59. {
  60. uint8 i;
  61. isp_addrl=address;
  62. isp_addrh=address>>8;
  63. isp_contr=0x01;
  64. isp_contr=isp_contr|0x81; // 0x80 if SYSCLK<40MHz, 0x81 if SYSCLK<20MHz, 0x82 if SYSCLK<10MHz, 0x83 if SYSCLK<5MHz
  65. isp_cmd=0x03;   //送擦除扇区命令
  66. isp_trig=0x46;
  67. isp_trig=0xb9;  //触发寄存器
  68. for(i=0;i<3;i++);
  69. isp_contr=0x00;
  70. isp_cmd  =0x00;
  71. isp_trig =0x00;
  72. isp_addrl=0x0;
  73. isp_addrh=0x0;
  74. }
  75. /**********************************************************************************
  76. * 函数名称:eepromWrite(uint16 address, uint8 write_data)
  77. * 功    能:EEPROM写程序
  78. * 入口参数:address,write_data
  79. * 出口参数:无
  80. ***********************************************************************************/
  81. //对STC片内EEPROM的指定地址写入数据(即,字节编程)。
  82. //注意:字节编程是指将eeprom的1写成1或0,将0写成0,而无法将0写成1
  83. //所以,在写入数据前,一定要用扇区擦除将所有字节变为0xff
  84. void eepromWrite(uint16 address, uint8 write_data)
  85. {
  86. uint8 i;
  87. isp_data=write_data;
  88. isp_addrl=address;
  89. isp_addrh=address>>8;
  90. isp_contr=0x01;
  91. isp_contr=isp_contr|0x81; // 0x80 if SYSCLK<40MHz, 0x81 if SYSCLK<20MHz, 0x82 if SYSCLK<10MHz, 0x83 if SYSCLK<5MHz
  92. isp_cmd=0x02;  //送写数据命令
  93. isp_trig=0x46;
  94. isp_trig=0xb9;  //触发寄存器
  95. for(i=0;i<3;i++);
  96. isp_contr=0x00;
  97. isp_cmd  =0x00;
  98. isp_trig =0x00;
  99. isp_addrl=0x0;
  100. isp_addrh=0x0;
  101. }
  102. /***********************************************************************************
  103. * 函数名称:eepromRead(uint16 address)
  104. * 功    能:EEPROM读程序
  105. * 入口参数:address
  106. * 出口参数:z
  107. ************************************************************************************/
  108. //读取STC单片机内部EEPROM的一个字节
  109. //主要不同的STC单片机EEPROM起始地址不同
  110. //例如:STC89c52RC的片内EEPROM起始地址为0x2000
  111. uint8 eepromRead(uint16 address)
  112. {
  113. uint8 i,z;
  114. isp_addrl=address;
  115. isp_addrh=address>>8;
  116. isp_contr=0x01;
  117. isp_contr=isp_contr|0x81; // 0x80 if SYSCLK<40MHz, 0x81 if SYSCLK<20MHz, 0x82 if SYSCLK<10MHz, 0x83 if SYSCLK<5MHz
  118. isp_cmd=0x01;  //送读数据命令
  119. isp_trig=0x46;
  120. isp_trig=0xb9;  //触发寄存器
  121. for(i=0;i<3;i++);
  122. isp_contr=0x00;
  123. isp_cmd  =0x00;
  124. isp_trig =0x00;
  125. isp_addrl=0x0;
  126. isp_addrh=0x0;
  127. z=isp_data;
  128. return(z);
  129. }
  130. void wreeprom(void){
  131. a=tot/256;
  132. b=tot%256;
  133. c=mon/256;
  134. d=mon%256;
  135. eepromEraseSector (0x2000);//擦除eeprom
  136. eepromWrite(0x2000, a);//写入eeprom
  137. eepromWrite(0x2001, b);//写入eeprom
  138. eepromWrite(0x2002, c);//写入eeprom
  139. eepromWrite(0x2003, d);//写入eeprom
  140. }
  141. //中断程序
  142. /*********************************************************************************
  143. * 函数名称:int0_1_int()
  144. * 功    能:外部中断0/1初始化
  145. **********************************************************************************/
  146. void int0_1_int(void) {
  147. //    IT0=1;//下降沿触发
  148. //    EX0=1;//TF0中断开
  149. IT1=1;//下降沿触发
  150. EX1=1;//TF1中断开
  151. EA=1;//开中断
  152. }
  153. /*********************************************************************************
  154. * 函数名称:int1_fun()interrupt2
  155. * 功    能:外部中断1服务子程序
  156. *********************************************************************************/
  157. void int1_fun()interrupt 2 {
  158. mc++;
  159. if (mc>=10){
  160. mc=0;
  161. if (mon>0){mon--;tot++;}
  162. wreeprom();
  163. }
  164. }
  165. void main( )
  166. {
  167.      unsigned char status;
  168. int0_1_int();
  169.      InitializeSystem( );//初始化
  170.      PcdReset();        //复位RC522
  171.      PcdAntennaOff(); //关闭天线
  172.      PcdAntennaOn();  //开启天线
  173. a=eepromRead(0x2000);//从eeprom读
  174. b=eepromRead(0x2001);//从eeprom读
  175. c=eepromRead(0x2002);//从eeprom读
  176. d=eepromRead(0x2003);//从eeprom读
  177. if (a==0xff&b==0xff&c==0xff&d==0xff) {
  178. //        a=0,b=0,c=0,d=0;
  179. eepromEraseSector (0x2000);//擦除eeprom
  180. eepromWrite(0x2000, a);//写入eeprom
  181. eepromWrite(0x2001, b);//写入eeprom
  182. eepromWrite(0x2002, c);//写入eeprom
  183. eepromWrite(0x2003, d);}//写入eeprom
  184. tot=a*256+b;
  185. mon=c*256+d;
  186.      while ( 1 )
  187.      {
  188. if(key1==0){dcf=1;dcfzsd=1;fmq=0;kgbj=0;}else{fmq=1;kgbj=1;}//开盖检测到开启时关阀门、报警
  189.         status = PcdRequest(PICC_REQALL, g_ucTempbuf); //返回卡片类型#define PICC_REQIDL 0x26 寻天线区内未进入休眠状态
  190. if (status != MI_OK){TYPE_DATA[0]=0;TYPE_DATA[1]=0;
  191. ID_DATA[0]=0;ID_DATA[1]=0;ID_DATA[2]=0;ID_DATA[3]=0;
  192. value_DATA[0]=0;    value_DATA[1]=0;    value_DATA[2]=0;    value_DATA[3]=0;
  193. falg_pro=0;
  194. card=0;}//读不到卡,显示清0;
  195.         if (status == MI_OK){TYPE_DATA[0]=g_ucTempbuf[0];TYPE_DATA[1]=g_ucTempbuf[1];
  196. status = PcdAnticoll(g_ucTempbuf);       //防冲撞 ,返回卡片ID号 4字节
  197. if (status == MI_OK){status = PcdSelect(g_ucTempbuf);    //选定卡片  ,输入卡片ID号
  198. if (status == MI_OK){if(falg_pro==0){falg_pro=1;pro();}//声音提示标志
  199. ID_DATA[0]=g_ucTempbuf[0];
  200. ID_DATA[1]=g_ucTempbuf[1];
  201. ID_DATA[2]=g_ucTempbuf[2];
  202. ID_DATA[3]=g_ucTempbuf[3];
  203.                             //
  204. if (key2==0 ){init_k();}//初始化卡
  205. if (key2!=0 & mon<1000 & card>0){writek();}//写卡
  206. readk(); //读卡
  207. PcdHalt();//命令卡片进入休眠状态
  208. }
  209. }
  210. }
  211. if(key3==0){Delay(40);if (mon>0){mon--;tot++;}
  212. wreeprom();}//写入eeprom}
  213. if(mon>0&key1!=0){dcf=0;dcfzsd=0;}else{dcf=1;dcfzsd=1;}//有余额时开阀
  214. if(mon<10){kgbj=0;}else{kgbj=1;}//余额低于10时报警灯亮;
  215. if(mon<10&mon>0){fmq=0;}else{fmq=1;}
  216. if (falg_pro){LCD1206b();}else{LCD1206a();};//显示处理
  217. }
  218. }
  219. /////////////////////////////////////////////////////////////////////
  220. //系统初始化
  221. /////////////////////////////////////////////////////////////////////
  222. void InitializeSystem(void)
  223. {
  224.      P0 = 0xFF;P1 = 0xFF;P2 = 0xFF;P3 = 0xFF;
  225. fmq=0;
  226. lcd_init();                // 初始化LCD
  227. Delay(1);
  228. fmq=1;
  229. }
  230. void Delay(unsigned int time)
  231. {
  232.   unsigned int i,k  ;
  233.   for(i=0;i<255;i++)
  234.     for(k=0;k<time;k++)
  235.      _nop_();
  236. }
  237. ////////////////////////显示处理函数////////////////////////////////
  238. bit lcd_bz()                    // 测试LCD忙碌状态
  239. {
  240. bit result;
  241. rs = 0;rw = 1;ep = 1;
  242. _nop_();_nop_();_nop_();_nop_();
  243. result = (bit)(P0 & 0x80);
  244. ep = 0;
  245. return result;
  246. }
  247. lcd_wcmd(unsigned char cmd)// 写入指令数据到LCD
  248. {
  249. while(lcd_bz());
  250. rs = 0;rw = 0;ep = 0;
  251. _nop_();_nop_();
  252. P0 = cmd;
  253. _nop_();_nop_();_nop_();_nop_();
  254. ep = 1;
  255. _nop_();_nop_();_nop_();_nop_();
  256. ep = 0;
  257. }
  258. lcd_pos(unsigned char pos)
  259. {                            //设定显示位置
  260. lcd_wcmd(pos | 0x80);
  261. }
  262. lcd_wdat(unsigned char dat)
  263. {                            //写入字符显示数据到LCD
  264. while(lcd_bz());
  265. rs = 1;rw = 0;ep = 0;
  266. P0 = dat;
  267. _nop_();_nop_();_nop_();_nop_();
  268. ep = 1;
  269. _nop_();_nop_();_nop_();_nop_();
  270. ep = 0;
  271. }
  272. lcd_init(void)                     //LCD初始化设定
  273. {
  274. lcd_wcmd(0x38);Delay(1);    //
  275. lcd_wcmd(0x0c);Delay(1);    //
  276. lcd_wcmd(0x06);Delay(1);    //
  277. lcd_wcmd(0x01);Delay(1);    //清除LCD的显示内容
  278. }
  279. LCD1206a()
  280. {
  281. unsigned char i;
  282. TYPE_DATA[0]=0x04;
  283. lcd_pos(0x00);                // 设置显示位置为第一行的第0个字符
  284. i = 0;
  285. switch (TYPE_DATA[0])
  286. {
  287. case 0x04:
  288. lcd_wdat(dis0[0]);
  289. lcd_wdat(dis0[1]);
  290. lcd_wdat(dis0[2]);
  291. lcd_wdat(dis0[3]);
  292. lcd_wdat(dis0[4]);
  293. lcd_wdat(dis0[5]);
  294. break;
  295. case 0x02:
  296. lcd_wdat(dis1[0]);
  297. break;
  298. case 0x08:
  299. lcd_wdat(dis2[0]);
  300. break;
  301. case 0x44:
  302. lcd_wdat(dis3[0]);
  303. break;
  304. }
  305. lcd_wdat(dis6[tot/10000]);
  306. lcd_wdat(dis6[tot%10000/1000]);
  307. lcd_wdat(dis6[tot%10000%1000/100]);
  308. lcd_wdat(dis6[tot%10000%1000%100/10]);
  309. lcd_wdat(dis6[tot%10000%1000%100%10]);
  310. lcd_wdat(dis1[0]);
  311. lcd_wdat(dis1[0]);
  312. lcd_wdat(dis1[0]);
  313. lcd_wdat(dis1[0]);
  314. lcd_wdat(dis1[0]);
  315. lcd_pos(0x40);
  316. lcd_wdat(dis3[0]);
  317. lcd_wdat(dis3[1]);
  318. lcd_wdat(dis3[2]);
  319. lcd_wdat(dis3[3]);
  320. lcd_wdat(dis6[mon%10000%1000/100]);
  321. lcd_wdat(dis6[mon%10000%1000%100/10]);
  322. lcd_wdat(dis6[mon%10000%1000%100%10]);
  323. lcd_wdat(dis4[0]);
  324. lcd_wdat(dis4[1]);
  325. lcd_wdat(dis4[2]);
  326. lcd_wdat(dis4[3]);
  327. lcd_wdat(dis4[4]);
  328. lcd_wdat(dis4[5]);
  329. lcd_wdat(dis6[card%10000%1000/100]);
  330. lcd_wdat(dis6[card%10000%1000%100/10]);
  331. lcd_wdat(dis6[card%10000%1000%100%10]);
  332. }
  333. LCD1206b()
  334. {
  335. unsigned char i;
  336. TYPE_DATA[0]=0x04;
  337. lcd_pos(0x00);                // 设置显示位置为第一行的第0个字符
  338. i = 0;
  339. switch (TYPE_DATA[0])
  340. {
  341. case 0x04:
  342. lcd_wdat(dis2[0]);
  343. lcd_wdat(dis2[1]);
  344. lcd_wdat(dis2[2]);
  345. lcd_wdat(dis2[3]);
  346. lcd_wdat(dis2[4]);
  347. lcd_wdat(dis2[5]);
  348. lcd_wdat(dis2[6]);
  349. break;
  350. lcd_wdat(dis2[6]);
  351. break;
  352. lcd_wdat(dis2[7]);
  353. break;
  354. case 0x02:
  355. lcd_wdat(dis1[0]);
  356. break;
  357. case 0x08:
  358. lcd_wdat(dis2[0]);
  359. break;
  360. case 0x44:
  361. lcd_wdat(dis3[0]);
  362. break;
  363. }
  364. lcd_wdat(dis6[ID_DATA[0]%100/10]);
  365. lcd_wdat(dis6[ID_DATA[0]%10]);
  366. lcd_wdat(dis6[ID_DATA[1]%100/10]);
  367. lcd_wdat(dis6[ID_DATA[1]%10]);
  368. lcd_wdat(dis6[ID_DATA[2]%100/10]);
  369. lcd_wdat(dis6[ID_DATA[2]%10]);
  370. lcd_wdat(dis6[ID_DATA[3]%100/10]);
  371. lcd_wdat(dis6[ID_DATA[3]%10]);
  372. lcd_pos(0x40);
  373. lcd_wdat(dis3[0]);
  374. lcd_wdat(dis3[1]);
  375. lcd_wdat(dis3[2]);
  376. lcd_wdat(dis3[3]);
  377. lcd_wdat(dis6[mon%10000%1000/100]);
  378. lcd_wdat(dis6[mon%10000%1000%100/10]);
  379. lcd_wdat(dis6[mon%10000%1000%100%10]);
  380. lcd_wdat(dis4[0]);
  381. lcd_wdat(dis4[1]);
  382. lcd_wdat(dis4[2]);
  383. lcd_wdat(dis4[3]);
  384. lcd_wdat(dis4[4]);
  385. lcd_wdat(dis4[5]);
  386. lcd_wdat(dis6[card%10000%1000/100]);
  387. lcd_wdat(dis6[card%10000%1000%100/10]);
  388. lcd_wdat(dis6[card%10000%1000%100%10]);
  389. }
  390. void pro()//蜂鸣器滴一声
  391. {
  392. fmq=0;
  393. TMOD=0x11;//设置定时器0为工作方式1
  394. TH0=(65536-50000)/256;//给定时器装初值 高八位
  395. TL0=(65536-50000)%256;//给定时器装初值 低八位
  396. EA=1;   //开总中断
  397. ET0=1;  //开定时器0中断
  398. TR0=1;  //启动定时器0
  399. }
  400. void time0() interrupt 1// 中断服务子程序 声音时间一致
  401. {
  402. TH0=(65536-50000)/256;//给定时器装初值 高八位
  403. TL0=(65536-50000)%256;//给定时器装初值 低八位
  404. tt++;
  405. if(tt==3){tt=0;fmq=1;
  406. ET0=0;  //关定时器0中断
  407. TR0=0;  //关定时器0
  408. }
  409. }
  410. void readk()//读卡
  411. {
  412. unsigned char status;
  413. status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//PICC_AUTHENT1A 验证密码模式60A密码 61B密码,“1”块地址,DefaultKey初始密码,g_ucTempbuf ID号
  414. if (status == MI_OK) //验证密码
  415. {
  416.     status = PcdRead(1, g_ucTempbuf);//读块地址“1”的数据,返回值存在    g_ucTempbuf
  417.   if (status == MI_OK)
  418.   {
  419. value_DATA[0]=g_ucTempbuf[0];
  420. value_DATA[1]=g_ucTempbuf[1];
  421. value_DATA[2]=g_ucTempbuf[2];
  422. value_DATA[3]=g_ucTempbuf[3];
  423. card=value_DATA[0]+value_DATA[1]*256;
  424.   }
  425.      }
  426. }
  427. void writek()//写卡    存值或减值
  428. {
  429.     unsigned char status;
  430.     status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//PICC_AUTHENT1A 验证密码模式60A密码 61B密码,“1”块地址,DefaultKey初始密码,g_ucTempbuf ID号
  431.   if (status == MI_OK) //验证密码
  432.   {
  433. data2[1]=100/256;data2[0]=100%256;//扣款金额
  434. status = PcdValue(PICC_DECREMENT,1,data2);//扣款存值命令,钱包地址,金额 低位在前  PICC_INCREMENT 充值
  435. if (status == MI_OK)
  436. {
  437. pro();
  438. mon=mon+100;                                     //充值金额
  439. wreeprom();
  440.     }
  441. status = PcdBakValue(1, 2);              //备份钱包      “1”源地址“2”目标地址
  442. if(status == MI_OK){};
  443. }
  444. }
  445. void init_k()//初始化卡
  446. {
  447.     unsigned char status;
  448. if(key2==0)                              //充值
  449. {
  450.     status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//PICC_AUTHENT1A 验证密码模式60A密码 61B密码,“1”块地址,DefaultKey初始密码,g_ucTempbuf ID号
  451.   if (status == MI_OK) //验证密码
  452.   {
  453.   status = PcdWrite(1, data1);//4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
  454.   if (status == MI_OK)
  455. {
  456.       pro();
  457. }
  458. }
  459. }
  460. }
ID:213173 发表于 2019-3-30 08:09 | 只看该作者
这是典型的LCD初始化失败,并且对比度调整过大的现象。
ID:164602 发表于 2019-3-30 08:29 | 只看该作者
需要调对比度。
ID:451718 发表于 2019-3-30 09:15 | 只看该作者
你没有给1602搞一个背光调节电阻?
ID:481641 发表于 2019-3-30 11:04 | 只看该作者
调节对比度,可以加个电阻或者电位器,还有就是初始化,初始化可以清屏
ID:375092 发表于 2019-3-30 11:14 | 只看该作者
你这个是LCD1602硬件连接的问题吧,你看看是不是那个电阻不合适还是怎么的,也有可能是程序的原因,都可以网这些方面去检查一下。楼主现在在玩RC522吗,进展怎么样了,我现在也在搞,遇到一些问题,希望有机会能够交流
ID:338750 发表于 2019-3-30 21:32 | 只看该作者
1.调节对比度,就是那个可调电阻.
2.把RW端接地试一试.
ID:499770 发表于 2019-3-30 22:05 | 只看该作者
LCD初始化失败,对比度调整过大
ID:498978 发表于 2019-3-31 11:26 | 只看该作者
你需要一个滑动变阻器
ID:497899 发表于 2019-3-31 16:46 | 只看该作者
对比度调低一点啊姐妹!
ID:484674 发表于 2022-1-1 08:06 来自手机 | 只看该作者
好象没有对比电阻吧…
ID:484674 发表于 2022-1-1 08:14 来自手机 | 只看该作者
1602显示屏出现左边正常显示右边出现白格什么原因请教各位大神
ID:898921 发表于 2022-1-1 14:09 | 只看该作者
初始化失败,应该调节背光电阻,直到显示清楚你要写的字为止。
