#include<STC12C5A60S2.H>
#define uint unsigned int
sbit CS=P2^0; //LCD12864串行通信片选
sbit SID=P2^1; //LCD12864串行通信数据口
sbit SCLK=P2^2; //LCD12864串行通信同步时钟信号
sbit PSB=P2^5; //LCD12864并/串选择:H并行 L串行
unsigned int temp1,sh1,ge1,n1,m1;
unsigned char ad_result_data[10]; //AD转换高八位
unsigned char ad_result_low2[10]; //AD转换低八位
unsigned char ad_result_total[10]; //AD转换总十位
unsigned char ad_average_result; //AD转换十次的平均值
unsigned char Ain,Vin;
unsigned char b,t,R;
char tp=0;
unsigned char code ma1[6]={0xb5,0xe7,0xd1,0xb9,0xa1,0xc3}; //电压:
unsigned char code ma2[]={"."};
uchar code disp1[]={"提示: 按1 键进入"};
uchar code disp2[]={"功能选择界面. "};
unsigned char code num0[]={0xa3,0xb0};
unsigned char code num1[]={0xa3,0xb1};
unsigned char code num2[]={0xa3,0xb2};
unsigned char code num3[]={0xa3,0xb3};
unsigned char code num4[]={0xa3,0xb4};
unsigned char code num5[]={0xa3,0xb5};
unsigned char code num6[]={0xa3,0xb6};
unsigned char code num7[]={0xa3,0xb7};
unsigned char code num8[]={0xa3,0xb8};
unsigned char code num9[]={0xa3,0xb9};
//-------模块延时程序---------------------------- 1ms
void delay1ms(uint delay1ms) //STC11F60XE,22.1184M,延时1ms
uint i,j;
for(;delay1ms>0;delay1ms--)
for(i=0;i<7;i++)
for(j=0;j<210;j++);
void delay(uint delay) //STC11F60XE,22.1184M,延时170us
uint i,j;
for(;delay>0;delay--)
for(i=0;i<124;i++);
for(j=0;j<124;j++);
AD转换程序
void AD_initiate() //初始化函数
ES=0;
TMOD=0x21; //定时计数器方式控制寄存器,"自动重装,16位计数器".
SCON=0x50; //串行控制寄存器,方便在串口助手那观察
TH1=0xfa;
TL1=0xfa;
TR1=1;
void ADC_Power_On() //AD转换电
ADC_CONTR|=0x80;
delay(5); //必要的延时
void get_ad_result() //取AD结果函数,它是十位AD转换,每十次平均,最后取低八位作为AD采样数据
uint i,q=0;
for(i=0;i<10;i++)
tp=0;
ADC_RES=0; //高八位数据清零,STC12C5A60S2 AD数据寄存名与STC12C54××系列不同
ADC_RESL=0; //低两位清零
ADC_CONTR|=0x08; //启动AD转换
while(!tp) //判断AD转换是否完成
tp=0x10;
tp&=ADC_CONTR;
ADC_CONTR&=0xe7;
ad_average_result=ADC_RES;
q=q+ad_average_result;
ad_average_result=q/10;
//ad_average_result=ad_average_result*4*5000/1024;
/************************AD转换结束***********************/
void send_ad_result() //取AD结果函数发送到串口,方便调试
SBUF=n1;
while(TI==0) ;
TI=0;
delay1ms(100);
//SBUF=R>>4;
//---------------------电压采样程序-------------------------
void caiyangP10() //测电压
P1M0|=0x01; //设P1_0为开漏模式 如: P1_0= #00000000B
P1M1|=0x01;
ADC_CONTR=0xe0; //设置P1.0为输入AD转换口
delay(2);
get_ad_result(); //取转换数据
Vin=ad_average_result;
R=Vin;
/*-----------写控制字到LCD12864------------*/
void write_cmd(uchar cmd)
uchar i;
uchar i_data;
i_data=0xf8; //命令控制字:11111000写指令 11111010写数据 11111100读状态 11111110读数据
CS=1; //片选置高,才能进行读写操作
SCLK=0;
/*----------写命令控制字-----------------*/
for(i=0;i<8;i++) //循环八次,每次读取一位数据
SID=(bit)(i_data&0x80); //bit表示取其最高位
SCLK=0;
SCLK=1; //正跳变写入指令
i_data=i_data<<1; //左移一位
/*----------写指令高四位-----------------*/
i_data=cmd;
i_data=i_data&0xf0; //把低四位置0
SCLK=0;
SCLK=1; //正跳变写入指令
/*----------写指令低四位-----------------*/
i_data=cmd;
i_data=i_data<<4; //左移四位,把低四位的数据移到高四位,再把低四位置0
SCLK=0;
SCLK=1; //正跳变写入指令
CS=0; //把片选置低
delay1ms(5); //延时是因为没有进行忙检测,适当的延时可以不进行忙检测
/*------------写数据到LCD12864-------------*/
void write_dat(uchar dat)
uchar i;
uchar i_data;
i_data=0xfa;
CS=1;
for(i=0;i<8;i++)
SCLK=0;
SCLK=1;
i_data=i_data<<1;
i_data=dat;
i_data=i_data&0xf0;
for(i=0;i<8;i++)
SCLK=0;
SCLK=1;
i_data=i_data<<1;
i_data=dat;
i_data=i_data<<4;
for(i=0;i<8;i++)
SCLK=0;
SCLK=1;
i_data=i_data<<1;
CS=0;
delay1ms(5);
/*--------------显示坐标-------------------*/
void lcd_pos(uchar x,uchar y) //汉字显示坐标,x为哪一行,y为哪一列
uchar pos;
if(x==0)
x=0x80; //第一行
else if(x==1)
x=0x90; //第二行
else if(x==2)
x=0x88; //第三行
else if(x==3)
x=0x98; //第四行
pos=x+y; //显示哪一行(总共有4行)哪一竖(总共有8竖,每16列为1竖)
write_cmd(pos);
/*--------------显示8个汉字-------------------*/
void disp_hanzi(uchar code *chn)
uchar i;
write_cmd(0x30); //基本指令操作方式
for(i=0;i<16;i++) //16列*8个汉字=128(刚好)
write_dat(chn[i]);
/*--------------显示数字-------------------*/
void disp_num(uchar code *chn)
uchar i;
for(i=0;i<2;i++) //1个数字
write_dat(chn[i]);
void disp_number(uchar num)
switch(num)
case 0: disp_num(num0);break;
case 1: disp_num(num1);break;
case 2: disp_num(num2);break;
case 3: disp_num(num3);break;
case 4: disp_num(num4);break;
case 5: disp_num(num5);break;
case 6: disp_num(num6);break;
case 7: disp_num(num7);break;
case 8: disp_num(num8);break;
case 9: disp_num(num9);break;
default: break;
/*----------- --LCD初始化------------------*/
void lcd_init()
PSB=0;
write_cmd(0x02); //地址归位
write_cmd(0x06); //游标右移
write_cmd(0x0c); //整体显示
write_cmd(0x01); //清屏
void displayP10()
float ad1;
//unsigned int temp1,sh1,ge1,n1,m1;
//uchar code dis2[]={0x01,0x02,0x00};
//ad1=x*7.8125; //电压修正
uchar i;
ad1=Vin*3.9608; //具体线性参数由输入电压值调整,该值的测量范围为0-10.00V,5V左右的测量比较准确,
//两端的最大误差为70mv,其他一般在40mv以内
temp1=(int)ad1;
sh1=temp1/1000; //十位
ge1=(temp1%1000)/100; //个位
n1=((temp1%1000)%100)/10; //小数点后一位
m1=((temp1%1000)%100)%10; //小数点后二位
//write_cmd(0x01);
lcd_pos(0,0);
for(i=0;i<6;i++) write_dat(ma1[i]);
lcd_pos(0,3);
disp_number(sh1);
lcd_pos(0,4);
disp_number(ge1);
lcd_pos(0,5);
for(i=0;i<2;i++) write_dat(ma2[i]);
lcd_pos(0,6);
disp_number(n1);
lcd_pos(0,7);
disp_number(m1);
/*lcd_pos(2,0);
disp_hanzi(disp1);
lcd_pos(3,0);
disp_hanzi(disp2);*/
EA=1;
AD_initiate(); //初始化
ADC_Power_On(); //开AD电源
//init();
lcd_init();
delay(10);
caiyangP10(); //测电压
send_ad_result();
//Vin=Vin*4007;
displayP10();
delay(10);
