查看: 1902|回复: 1
单片机16*16点阵点亮+proteus+文档
ID:517378 发表于 2019-4-20 20:25 | 显示全部楼层 |阅读模式
这是我的程序:
#include<reg51.h>
#include<intrins.h>
#define data1 P0
#define data2 P2
sbit s1=P3^6;
sbit s2=P3^7;
bit fangxiang;
uint alt=0,net=0,sl=128;
bit mode;
uchar code tab[]={
0x20,0x08,0x24,0x10,0x22,0x60,0x21,0x80,0x26,0x41,0x39,0x32,0x02,0x04,0x0C,0x18,
0xF0,0x60,0x13,0x80,0x10,0x60,0x10,0x18,0x14,0x04,0x18,0x02,0x00,0x01,0x00,0x00,/*"欢",2*/
0x02,0x00,0x02,0x02,0x42,0x04,0x33,0xF8,0x00,0x04,0x00,0x02,0x3F,0xF2,0x20,0x22,
0x40,0x42,0x00,0x02,0x3F,0xFE,0x20,0x42,0x20,0x22,0x3F,0xC2,0x00,0x02,0x00,0x00,/*"迎",3*/
0x00,0x80,0x01,0x00,0x06,0x00,0x1F,0xFF,0xE0,0x00,0x02,0x08,0x04,0x30,0x18,0xC0,
0xF0,0x02,0x10,0x01,0x13,0xFE,0x10,0x00,0x10,0x80,0x14,0x60,0x18,0x18,0x00,0x00,/*"你",4*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",5*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",6*/
void delay(uint z)    //延时子函数
   uchar x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void xianshi()   //显示
uchar aa,i;
for(i=0;i<16;i++)
  P1=i; //列扫描
  data1=tab[net+aa]; //取出上8行数据输出
  aa++;
  data2=tab[net+aa]; //取出下8行数据输出
  aa++;
  delay(5); //延时
  data1=0;  //清屏
  data2=0;  //清屏
  P1=0x00;  //消除余辉
  if(aa>30) aa=0;  //字模地址
void main()  //主函数
   ET1=1;  //使能定时器0
   EA=1;  //开启总中断
   TR1=1; //开始计数
   while(1)  //无限循环
    xianshi();  //显示
    if(s1==0)   //检测按键
       delay(30);  //延时消抖
    TR1=~TR1;   //按下暂停  ,暂按继续
    while(!s1)xianshi();
    delay(30);
    if(s2==0) //检测按键
        delay(30);   //延时消抖
     fangxiang=~fangxiang;  //方向取反
     while(!s2)xianshi();
     delay(30);
void timer1() interrupt 3
   alt++;
   if(alt==10)     //到一定的时间加以实现左移
     alt=0;
  if(fangxiang==0)  //如果是正向 正向移动
   net=net+2;
      if(net>sl)  //字移动数量
      net=0;
  else      //否则反向移动
      net=net-2;
   if(net<2)
   net=sl;   //字移动数量
全部资料51hei下载地址:
111.zip (525.24 KB, 下载次数: 34)
ID:532069 发表于 2019-5-12 21:36 | 显示全部楼层
自定义文字乱码怎么解决啊
