查看: 1688|回复: 3
基于STM3240X的无线传输电子秤的代码实现
ID:134542 发表于 2019-4-21 22:01 | 显示全部楼层 |阅读模式
附件是我的电子秤的实现程序,还加有关于32的无线传输是如何进行传输的。
[code]#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "lcd.h"
#include "spi.h"
#include "key.h"
#include "24l01.h"
#include "HX711.h"
#include "dht11.h"
//程序需要学习,学习永无止境
//要写入到W25Q16的字符串数组
const u8 TEXT_Buffer[]={"Explorer STM32F4 SPI TEST"};
#define SIZE sizeof(TEXT_Buffer)
        void Send_Name();
        char *itoa(); //
//  int d=500; //
   char buff[];
int main(void)
        u8 humidity;
        u8 jiage;
        u8 temperature;
        u8 key;
  float mode;
        u8 tmp_buf[33];
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
        delay_init(168);  //初始化延时函数
        uart_init(115200);        //初始化串口波特率为115200
        Init_HX711pin();
        LED_Init();                                        //初始化LED
        LCD_Init();                                        //LCD初始化
        KEY_Init();                                        //按键初始化
        NRF24L01_Init();                    //初始化NRF24L01
        Get_Maopi();                                //称毛皮重量
        delay_ms(1000);
        delay_ms(1000);
        Get_Maopi();                                //重新获取毛皮重量
        POINT_COLOR=RED;//设置字体为红色
        LCD_ShowString(30,50,200,16,16,"Explorer STM32F4");
            DHT11_Read_Data(&temperature,&humidity);                //读取温湿度值
                        LCD_ShowString(30,230,200,16,16,"temperature");
      LCD_ShowNum(130,230,temperature,7,16);//显示温度
//        LCD_ShowString(30,70,200,16,16,"NRF24L01 TEST");
        LCD_ShowString(30,110,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(30,130,200,16,16,"2014/5/9");
                key=KEY_Scan(0);
                if(key==KEY0_PRES)
                        delay_ms(5);
                        mode=0.8;
                        break;
                }else if(key==KEY1_PRES)
                        delay_ms(5);
                        mode=0.5;
                        break;
                break;
                Get_Weight();
//                LCD_ShowNum(30,70,(u8)Weight_Shiwu,7,16);
//////////                printf("净重量 = %d g\r\n",Weight_Shiwu); //打印
//////////                delay_ms(500);
//////////    LCD_ShowString(30,70,200,16,16,"food weight");
    Weight_Shiwu=Weight_Shiwu*0.25;
//////////    LCD_Fill(130,70,lcddev.width,170+16*3,WHITE);
//////////                LCD_ShowNum(130,70,Weight_Shiwu,7,16);
                jiage=Weight_Shiwu*mode;
////                LCD_ShowString(30,90,200,16,16,"food price");
                LCD_ShowNum(130,90,jiage,7,16);
    itoa(jiage, buff, 10);
          Send_Name(buff);//"buff"
    delay_ms(50);
void Send_Name(u8 tmp_buf[36])
        while(NRF24L01_Check())
                LCD_ShowString(30,150,200,16,16,"NRF24L01 Error");
                delay_ms(200);
                LCD_Fill(30,150,239,130+16,WHITE);
                delay_ms(200);
        LCD_ShowString(30,150,200,16,16,"NRF24L01 OK");
        LCD_Fill(10,170,240,166,WHITE);//清空上面的显示
        POINT_COLOR=BLUE;//设置字体为蓝色
                LCD_ShowString(30,170,200,16,16,"NRF24L01 TX_Mode");
                NRF24L01_TX_Mode();
                        if(NRF24L01_TxPacket(tmp_buf)==TX_OK)
                                LCD_Fill(0,210,lcddev.width,170+16*3,WHITE);//清空显示
                                LCD_ShowString(30,190,239,32,16,"Sended DATA:");
                                LCD_ShowString(30,210,lcddev.width-1,32,16,tmp_buf);
                        }else
                                LCD_Fill(0,190,lcddev.width,170+16*3,WHITE);//清空显示
                                LCD_ShowString(30,190,lcddev.width-1,32,16,"Send Failed ");
                        LED0=!LED0;
                        delay_ms(300);
      break;
        char *itoa(int value, char *string, int radix)
                radix=10 ???10??        ????,?????0;
            ?:d=-379;
                ??        itoa(d, buf, 10); ?
                buf="-379"
    int     i, d;
    int     flag = 0;
    char    *ptr = string;
    /* This implementation only works for decimal numbers. */
    if (radix != 10)
        *ptr = 0;
        return string;
    if (!value)
        *ptr++ = 0x30;
        *ptr = 0;
        return string;
    /* if this is a negative value insert the minus sign. */
    if (value < 0)
        *ptr++ = '-';
        /* Make the value positive. */
        value *= -1;
    for (i = 10000; i > 0; i /= 10)
        d = value / i;
        if (d || flag)
            *ptr++ = (char)(d + 0x30);
            value -= (d * i);
            flag = 1;
    /* Null terminate the string. */
    *ptr = 0;
    return string;
int atoi_my(const char *str)
    int s=0;
    int falg=0;
    while(*str==' ')
        str++;
    if(*str=='-'||*str=='+')
        if(*str=='-')
        falg=1;
        str++;
    while(*str>='0'&&*str<='9')
        s=s*10+*str-'0';
…………限于本文篇幅 余下代码请从51黑下载附件…………
[/code]
智能电子秤.7z (350.78 KB, 下载次数: 12)
ID:134542 发表于 2019-4-21 22:04 | 显示全部楼层
楼主自己先顶一下
ID:134542 发表于 2019-4-21 22:05 | 显示全部楼层
希望各位小伙伴踊跃提出自己宝贵的建议,我很期待哦
ID:1 发表于 2019-4-28 16:45 | 显示全部楼层
回帖奖励 +1
