自己刚比赛完发现了很多不会的东西
现在好多东西都需要重新学习一下
因此上传写基础的代码代表自己学习的进度
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f4xx_hal.h"
- #include "gpio.h"
- /* USER CODE BEGIN Includes */
- /* USER CODE END Includes */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- /* USER CODE BEGIN 2 */
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- HAL_GPIO_WritePin(led1_GPIO_Port, led1_Pin, GPIO_PIN_RESET);
- HAL_GPIO_WritePin(led0_GPIO_Port, led0_Pin, GPIO_PIN_SET);
- HAL_Delay(100);
- HAL_GPIO_WritePin(led0_GPIO_Port, led0_Pin, GPIO_PIN_RESET);
- HAL_GPIO_WritePin(led1_GPIO_Port, led1_Pin, GPIO_PIN_SET);
- HAL_Delay(100);
- /* USER CODE END 3 */
- /** System Clock Configuration
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- __HAL_RCC_PWR_CLK_ENABLE();
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.HSICalibrationValue = 16;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
- HAL_RCC_OscConfig(&RCC_OscInitStruct);
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
LED1.7z
(277.07 KB, 下载次数: 5)
