查看: 1433|回复: 0
小白(LCD电子时钟可调)
#include<reg51.h>
int i=0,s=0,f=0,z=0;ri=21,k=0,n=0;//最多只能调到日月年我没加上去
sbit E=P2^7;
sbit RW=P2^5;
sbit RS=P2^6;
sbit k1=P2^0;
sbit k2=P2^1;
sbit k3=P2^2;
sbit k4=P2^3;
sbit k5=P2^4;
sbit beep=P1^5;
//uchar sz[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar sz[]="TIME ";
uchar table2[]="DATE  2019-4-";
void Lcd1602_Delay1ms(int c)   //误差 0us
    uchar a,b;
        for (; c>0; c--)
                 for (b=199;b>0;b--)
                          for(a=1;a>0;a--);
LCDWriteCom(uchar com)
        E=0;
        RW=0;
        RS=0;
        P0=com;
        E=1;
                Lcd1602_Delay1ms(1);
        E=0;
                Lcd1602_Delay1ms(5);
LCDWriteDat(uchar dat)
        E=0;
        RW=0;
        RS=1;
        P0=dat;
        E=1;
        E=0;
LCDInit()
        LCDWriteCom(0x38);
        LCDWriteCom(0x0c);
        LCDWriteCom(0x06);
        LCDWriteCom(0x01);
zd() interrupt 1
            TH0=0x3c;
     TL0=0xb0;
        i++;
        if(i==20)
         i=0;
         s++;
            if(s==60) //秒
          s=0;
          f++;
         if(f==60) //分
          f=0;
          z++;
          if(z==24)        //时
          z=0;ri++;//日
main()
  TMOD=0x01;        //定时器T0中断
  TH0=0x3c;
  TL0=0xb0;
  ET0=1;
  EA=1;
  TR0=1;
        LCDInit();
        LCDWriteCom(0xc0);
        for(i=0;i<13;i++)
            LCDWriteDat(table2[i]);
           LCDWriteCom(0x80);
           for(i=0;i<6;i++)
           LCDWriteDat(sz[i]);
          if(k1==0)//按钮k1 小时+1
           Lcd1602_Delay1ms(100);
           if(k1==0)
                   z++;
                if(z==24)
                z=0;
         if(k2==0)
           Lcd1602_Delay1ms(100);//按钮k2 分+1
           if(k2==0)
                   f++;
                if(f==60)
                 f=0;z++;
          if(k3==0)
           Lcd1602_Delay1ms(100); //按钮k3 秒+1
                   if(k3==0)
                s++;
                 if(s==60)
                 s=0;f++;
            if(k4==0)
                Lcd1602_Delay1ms(10);
                if(k4==0)
              k++;
                  if(k==24)
                  k=0;
                  LCDWriteCom(0x85);
                  LCDWriteDat(0x30+(k/10));
                   LCDWriteCom(0x86);
                    LCDWriteDat(0x30+(k%10));
                  Lcd1602_Delay1ms(500);
            if(k5==0)
                if(k5==0)
              n++;
                  if(n==60)
                  n=0;
                  LCDWriteCom(0x88);
                  LCDWriteDat(0x30+(n/10));
                   LCDWriteCom(0x89);
                    LCDWriteDat(0x30+(n%10));
        if((z==k)&&(f==n))
          beep=~beep;
          LCDWriteCom(0x85);
          LCDWriteDat(0x30+(z/10));
          LCDWriteCom(0x86);
          LCDWriteDat(0x30+(z%10));
          LCDWriteCom(0x87);
          LCDWriteDat(':');
          LCDWriteCom(0x88);
          LCDWriteDat(0x30+(f/10));
          LCDWriteCom(0x89);
          LCDWriteDat(0x30+(f%10));
          LCDWriteCom(0x8a);
          LCDWriteDat(':');
          LCDWriteCom(0x8b);
          LCDWriteDat(0x30+(s/10));
          LCDWriteCom(0x8c);
          LCDWriteDat(0x30+(s%10));
          LCDWriteCom(0xcc);
          LCDWriteDat(0x30+(ri/10));
          LCDWriteDat(0x30+(ri%10));
根据开发板自己做的电子时钟
根据开发板自己做的电子时钟
