查看: 2719|回复: 5
为什么我的程序会跳出while(1)?
ID:328334 发表于 2019-5-11 22:49 | 显示全部楼层 |阅读模式
#include "reg52.h"
#include "stdio.h"
#include "string.h"
#define uint unsigned int
void send_byte(uchar by);
void send_string(uchar *p);
void delay(uint n);
uchar rst[]="AT+RST\r\n";
uchar mod[]="AT+CWMODE=3\r\n";
uchar wico[]="AT+CWJAP=\"Nick\",\"qweasdzxc\"\r\n";
uchar sev[]="AT+CIPSTART=\"TCP\",\"192.168.43.31\",8080\r\n";
uchar mods[]="AT+CIPMODE=1\r\n";
uchar sen[]="AT+CIPSEND\r\n";
uchar kk[]="Here is light\r\n";
uint g,y,r;
uint str1;
sbit ght=P2^0;
sbit yht=P2^1;
sbit rht=P2^2;
void UsartInit()
                SCON=0X50;
                T2CON=0X34;
                PCON=0X80;
                RCAP2H=(65536-39)/256;
    RCAP2L=(65536-39)%256;
    ES=0;
    EA=1;
                ET0=1;
                ET1=1;
                EX0=1;
                IT0=1;
                EX1=1;
                IT1=1;
        UsartInit();
        send_string(rst);
        delay(1);
        send_string(mod);
        delay(1);
        send_string(wico);
        delay(10);
        send_string(sev);
        delay(10);
        send_string(mods);
        delay(5);
        send_string(sen);
        delay(3);
        ES=1;
        str1=53;
        g=5;
        y=2;
        r=5;
                g=str1-48;
                ght=0;
                yht=1;
                rht=1;
                delay(g);
                ght=1;
                yht=0;
                rht=1;
                delay(y);
                ght=1;
                yht=1;
                rht=0;
                delay(r);
                SBUF = by;
    while(!TI);
    TI = 0;
    while(*p!= '\0')
        send_byte(*p);
        p++;
void delay(uint n)
        unsigned int i=0;
  for(i=0;i<n;i++)
                #pragma asm
                DEL3:MOV R0,#100
                DEL2:MOV R1,#100
                DEL1:MOV R2,#25
          DEL0:NOP
               NOP
               DJNZ R2,DEL0
               DJNZ R1,DEL1
               DJNZ R0,DEL2
        #pragma endasm
void Usart() interrupt 4
        str1=SBUF;
        RI = 0;//
ID:511890 发表于 2019-5-12 02:35 | 显示全部楼层
把delay(g)的g改为数值试试。感觉应该是抛exception退出来的。
ID:535899 发表于 2019-5-12 08:17 | 显示全部楼层
是自动跳出来吗?
ID:52944 发表于 2019-5-12 11:45 | 显示全部楼层
自动跳出的,还是串口中断时跳出的
ID:328334 发表于 2019-5-23 10:41 | 显示全部楼层
自动跳出来,编译0错误0警告,学长提醒应该是看门狗没关,想问一下怎么关看门狗
exception是啥
