查看: 2442|回复: 2
51单片机驱动NRF24l01程序卡在IRQ一直高电平
ID:317765 发表于 2019-5-12 21:46 | 显示全部楼层 |阅读模式
1黑币
用普中的51开发板,用的代码如下: 卡死在while(IRQ);上:
#include <reg51.h>
#define TX_ADR_WIDTH   5  // 5字节宽度的发送/接收地址
#define TX_PLOAD_WIDTH 4  // 数据通道有效数据宽度
sbit LED = P2^7;
sbit KEY1 = P3^0;
sbit KEY2 = P3^1;
//uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};  // 定义一个静态发送地址
uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x11,0x22,0x33,0x44,0x55};  // 定义一个静态发送地址
uchar RX_BUF[TX_PLOAD_WIDTH];
uchar TX_BUF[TX_PLOAD_WIDTH];
uchar flag;
uchar DATA = 0x01;
uchar bdata sta;
sbit  RX_DR     = sta^6;
sbit  TX_DS     = sta^5;
sbit  MAX_RT = sta^4;
sbit CE =  P1^0;
sbit CSN=  P3^7;
sbit SCK=  P3^6;
sbit MOSI= P2^2;
sbit MISO= P2^0;
sbit IRQ = P3^3;
// SPI(nRF24L01) commands
#define READ_REG    0x00  // Define read command to register
#define WRITE_REG   0x20  // Define write command to register
#define RD_RX_PLOAD 0x61  // Define RX payload register address
#define WR_TX_PLOAD 0xA0  // Define TX payload register address
#define FLUSH_TX    0xE1  // Define flush TX register command
#define FLUSH_RX    0xE2  // Define flush RX register command
#define REUSE_TX_PL 0xE3  // Define reuse TX payload register command
#define NOP         0xFF  // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG      0x00  // 'Config' register address
#define EN_AA       0x01  // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR   0x02  // 'Enabled RX addresses' register address
#define SETUP_AW    0x03  // 'Setup address width' register address
#define SETUP_RETR  0x04  // 'Setup Auto. Retrans' register address
#define RF_CH       0x05  // 'RF channel' register address
#define RF_SETUP    0x06  // 'RF setup' register address
#define STATUS      0x07  // 'Status' register address
#define OBSERVE_TX  0x08  // 'Observe TX' register address
#define CD          0x09  // 'Carrier Detect' register address
#define RX_ADDR_P0  0x0A  // 'RX address pipe0' register address
#define RX_ADDR_P1  0x0B  // 'RX address pipe1' register address
#define RX_ADDR_P2  0x0C  // 'RX address pipe2' register address
#define RX_ADDR_P3  0x0D  // 'RX address pipe3' register address
#define RX_ADDR_P4  0x0E  // 'RX address pipe4' register address
#define RX_ADDR_P5  0x0F  // 'RX address pipe5' register address
#define TX_ADDR     0x10  // 'TX address' register address
#define RX_PW_P0    0x11  // 'RX payload width, pipe0' register address
#define RX_PW_P1    0x12  // 'RX payload width, pipe1' register address
#define RX_PW_P2    0x13  // 'RX payload width, pipe2' register address
#define RX_PW_P3    0x14  // 'RX payload width, pipe3' register address
#define RX_PW_P4    0x15  // 'RX payload width, pipe4' register address
#define RX_PW_P5    0x16  // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17  // 'FIFO Status Register' register address
void blink(char i);
函数: init_io()
描述:
    初始化IO
void init_io(void)
    CE  = 0;        // 待机
    CSN = 1;        // SPI禁止
    SCK = 0;        // SPI时钟置低
    IRQ = 1;        // 中断复位
    LED = 1;        // 关闭指示灯
函数:delay_ms()
描述:
    延迟x毫秒
void delay_ms(uchar x)
    uchar i, j;
    i = 0;
    for(i=0; i<x; i++)
       j = 250;
       while(--j);
       j = 250;
       while(--j);
函数:SPI_RW()
描述:
    根据SPI协议,写一字节数据到nRF24L01,同时从nRF24L01
    读出一字节
uchar SPI_RW(uchar byte)
    uchar i;
       for(i=0; i<8; i++)          // 循环8次
           MOSI = (byte & 0x80);   // byte最高位输出到MOSI
           byte <<= 1;             // 低一位移位到最高位
           SCK = 1;                // 拉高SCK,nRF24L01从MOSI读入1位数据,同时从MISO输出1位数据
           byte |= MISO;           // 读MISO到byte最低位
           SCK = 0;                // SCK置低
    return(byte);               // 返回读出的一字节
函数:SPI_RW_Reg()
描述:
    写数据value到reg寄存器
uchar SPI_RW_Reg(uchar reg, uchar value)
    uchar status;
      CSN = 0;                   // CSN置低,开始传输数据
      status = SPI_RW(reg);      // 选择寄存器,同时返回状态字
      SPI_RW(value);             // 然后写数据到该寄存器
      CSN = 1;                   // CSN拉高,结束数据传输
      return(status);            // 返回状态寄存器
函数:SPI_Read()
描述:
    从reg寄存器读一字节
uchar SPI_Read(uchar reg)
    uchar reg_val;
      reg_val = SPI_RW(0);        // 然后从该寄存器读数据
      return(reg_val);            // 返回寄存器数据
函数:SPI_Read_Buf()
描述:
    从reg寄存器读出bytes个字节,通常用来读取接收通道
    数据或接收/发送地址
uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
    uchar status, i;
      for(i=0; i<bytes; i++)
        pBuf[i] = SPI_RW(0);    // 逐个字节从nRF24L01读出
函数:SPI_Write_Buf()
描述:
    把pBuf缓存中的数据写入到nRF24L01,通常用来写入发
    射通道数据或接收/发送地址
uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
    uchar status, i;
        SPI_RW(pBuf[i]);        // 逐个字节写入nRF24L01
函数:RX_Mode()
描述:
    这个函数设置nRF24L01为接收模式,等待接收发送设备的数据包
void RX_Mode(void)
    CE = 0;
      SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 接收设备接收通道0使用和发送设备相同的发送地址
      SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);               // 使能接收通道0自动应答
      SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);           // 使能接收通道0
      SPI_RW_Reg(WRITE_REG + RF_CH, 0);                 // 选择射频通道0x40
      SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH);  // 接收通道0选择和发送通道相同有效数据宽度
      SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x0f);            // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
      SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);              // CRC使能,16位CRC校验,上电,接收模式
    delay_ms(150);
      CE = 1;                                            // 拉高CE启动接收设备
函数:TX_Mode()
描述:
    这个函数设置nRF24L01为发送模式,(CE=1持续至少10us),
    130us后启动发射,数据发送结束后,发送模块自动转入接收
    模式等待应答信号。
void TX_Mode(uchar * BUF)
    CE = 0;
      SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);     // 写入发送地址
      SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);  // 为了应答接收设备,接收通道0地址和发送地址相同
      SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH);                  // 写数据包到TX FIFO
      SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a);  // 自动重发延时等待250us+86us,自动重发10次
      SPI_RW_Reg(WRITE_REG + RF_CH, 40);         // 选择射频通道0x40
      SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);    // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
      SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);      // CRC使能,16位CRC校验,上电
    delay_ms(150);
    CE = 1;
函数:Check_ACK()
描述:
    检查接收设备有无接收到数据包,设定没有收到应答信
    号是否重发
uchar Check_ACK(bit clear)
        LED = 0;
    //delay_ms(200);
    while(IRQ);
        LED = 1;
    sta = SPI_RW(NOP);                    // 返回状态寄存器
    if(TX_DS)
        blink(3);
    //blink(5);
    if(MAX_RT)
        if(clear)                         // 是否清除TX FIFO,没有清除在复位MAX_RT中断标志后重发
            SPI_RW(FLUSH_TX);
    SPI_RW_Reg(WRITE_REG + STATUS, sta);  // 清除TX_DS或MAX_RT中断标志
    IRQ = 1;
    if(TX_DS)
        return(0x00);
        return(0xff);
函数:CheckButtons()
描述:
    检查按键是否按下,按下则发送一字节数据
void CheckButtons()
    if(KEY1 == 0)
        delay_ms(20);
        if(KEY1 == 0)
            TX_BUF[0] = 1;          // 数据送到缓存
            //TX_BUF[0] = 0xff;          // 数据送到缓存
            TX_Mode(TX_BUF);            // 把nRF24L01设置为发送模式并发送数据
            //LED = ~DATA;                // 数据送到LED显示
            Check_ACK(0);               // 等待发送完毕,清除TX FIFO
            delay_ms(250);
            delay_ms(250);
                        blink(2);
    if(KEY2 == 0)
        delay_ms(20);
        if(KEY2 == 0)
            TX_BUF[0] = 2;          // 数据送到缓存
            delay_ms(250);
            delay_ms(250);
                        blink(3);
void blink(char i)
    while(i--)
        LED = 1;
        delay_ms(500);
        LED = 0;
        delay_ms(500);
函数:main()
描述:
    主函数
void main(void)
    init_io();                      // 初始化IO
        CheckButtons();           // 按键扫描
ID:668601 发表于 2024-4-25 12:33 | 显示全部楼层
你好,请问一下你这个问题解决了吗
ID:402383 发表于 2024-4-25 14:27 | 显示全部楼层
函数:TX_Mode()
描述:
    模式等待应答信号。
    CE = 0;
    delay_ms(150);
    CE = 1;
这里还没配置完就发送数据了,明显是有误。
是需要配置完才执行发送数据的命令,发送数据包的命令最好跟判断是否发送完成放在同一个子函数。
