这是最近做的自动浇花系统,用atmega16内部定时器做的。
- #include <iom16v.h>
- #include <macros.h>
- #define key_bz 0b00000111
- #define uchar unsigned char
- #define uint_16 unsigned short
- char smg_zx[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d, 0x7d,0x07,0x7f,0x6f,0x37};// 全局变量
- char smg_wx[]={0B00000001,0B00000010,0B00000100,0b00001000};
- char smg_oFF[]={0x3f,0X71,0X71};
- unsigned int flag_10ms=0,flag_1s=0,on=0,buff[]={0,0,0},mode=0;
- unsigned int jh_hour1=2,u=0,count=0,count1=2,on_sec=0;
- unsigned int jh_sec1=5,jh_hour=0,jh_sec=0,flag=0;
- unsigned long int jishi_sec=0;
- void delay_ms(unsigned int k)
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<570;j++);
- // 用定时器实现定时
- void T0_init(void)// 端口初始化函数
- TIFR=0XFF;
- TCCR0=0X0B; //64FENPIN, CTC MODE
- TCNT0=0;
- OCR0=250;
- TIMSK=0X02;
- void port_init(void)// 端口初始化函数
- DDRC|=0b10001111; // PC4 5 OUT PUT
- PORTC=0b11110000; //m103 output only
- PORTD= 0xFF;
- DDRD= 0xff;
- DDRB&= 0b11111000;
- PORTB|=0B00000111;
- void init_devices(void)
- CLI(); //disable all interrupts
- port_init();//smg_zx[0]=1;
- T0_init();
- SEI(); //re-enable interrupts
- ////多位数拆分函数///////*/
- void xs_buff(uchar va1, uchar va2)
- buff[0]=va1/10;
- buff[1]=va1%10;
- buff[2]=va2/10;
- buff[3]=va2%10;
- void xs_buff_on( uchar va2)
- buff[0]=0;
- buff[1]=10;
- buff[2]=va2/10;
- buff[3]=va2%10;
- void xs_smg()
- {//char smg_zx[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,
- // 0x7d,0x07,0x7f,0x6f};// 局部变量
- static unsigned char posit=0;
- PORTC&=0X80; // turn off
- PORTC|=smg_wx[posit];//selecting led 7-segment
- PORTD=~smg_zx[buff[posit]]; //
- if(posit++>=3)posit=0;
- void smg_xs(void)
- if((count<=20)||(flag==1))
- if((on!=1)&&(on!=2))
- xs_buff(jh_hour,jh_sec);
- xs_smg();
- else
- if((on==1))
- { xs_buff_on(on_sec);
- xs_smg();
- else if(on==2)
- {PORTC&=0X80;on_sec=0;
- PORTD=~smg_oFF[u];
- PORTC|=smg_wx[u];if(u++>=2)u=0;
- else
- {PORTC&=0X80;count1=0;}
- void motor(void)
- if(on==1)
- {PORTC|=0X80;flag=1;
- else
- on_sec=0;
- if(on==2){PORTC&=0X7F;flag=0;}//off状态下关闭电机
- else if((jishi_sec>jh_hour1*3600)&&(jishi_sec<=jh_hour1*3600+jh_sec1))//大于设定的时间间隔和浇花时长
- {PORTC|=0X80;//开电机
- flag=1;}
- else
- PORTC&=0X7F;flag=0;
- if(jishi_sec>jh_hour1*3600+jh_sec1)
- jishi_sec=0;
- /// 按键子程序,实现按键值返回
- uchar key(void)
- { static uchar key_zt=1, key_value;
- uchar returnvalue=100; // 100表示无按键对应的一个数值
- switch(key_zt) // 0b00000111 /0b00000110 //0b00000110
- case 1:if((PINB&key_bz)!=key_bz)
- {key_value=PINB&key_bz;
- key_zt=2;}
- break;
- case 2: if((PINB&key_bz)==key_value)
- {key_zt=3;
- switch(key_value)
- case 0b00000110:
- returnvalue=1; //切换模式
- break;
- case 0b00000101:
- returnvalue=2;//在时分之间切换
- break;
- case 0b00000011:
- returnvalue=3;//在时分之间切换
- break;
- }else key_zt=1;
- break;
- case 3:
- if((PINB&key_bz)==key_bz)
- key_zt=1;
- break;
- return returnvalue;
- // 根据按键子程序返回的按键值去执行相应的功能
- void key_process(void)
- switch(key())
- { case 1:count=0;count1++;if(count1>1){count1=2;if(on==0)/*只有on=0,回归正常显示界面才能加*/{if(jh_hour++>=99)jh_hour=0;}}break; //mode:0-计时,1,校准,2闹钟 // 模式切换
- case 2:count=0;count1++;if(count1>1){count1=2;if(on++>=2){on=0;jishi_sec=0;}}break;//每手动开启电机,jishi_sec就赋零
- case 3:count=0;count1++;if(count1>1){count1=2;if(on==0)/*只有on=0,回归正常显示界面才能加*/{if(jh_sec++>=99)jh_sec=0;}}break;
- void sj_lj(void)
- jishi_sec++;
- if(jishi_sec%3600==0&&jishi_sec!=0)jh_hour--;
- if(jh_hour==0){if(jh_sec--<=0){jh_hour=jh_hour1;jh_sec=jh_sec1;}}
- //主函数////////////////////////////////////////////////////////////////////////////////////
- void main(void)
- jh_hour=jh_hour1;
- jh_sec=jh_sec1;
- init_devices();
- while(1)
- motor();
- smg_xs();
- if(flag_1s==1)
- {flag_1s=0;
- sj_lj();}
- if(flag_10ms==1)
- {flag_10ms=0;
- key_process();}
- //T0中断服务程序 // 2ms 进入中断
- #pragma interrupt_handler timer0_ocf_isr:20
- void timer0_ocf_isr(void)
- {static uint_16 count_1s=0,count_10ms=0,count_5s=0;
- if(++count_10ms>=5)
- { count_10ms=0;
- flag_10ms=1;
- if(++count_1s>=100)
- {count_1s=0;
- flag_1s=1;
- count++;
- if(on==1)
- on_sec++;
新建文件夹.rar
(32.6 KB, 下载次数: 115)
