查看: 3501|回复: 2
error C267: 'ConfigTimer0': requires ANSI-style prototype单片机程序编译错误
ID:540208 发表于 2019-5-16 21:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg51.h"
#include "intrins.h"
typedef unsigned char uchar;
typedef unsigned int WORD;
/*Declare SFR associated with the ADC */
sfr ADC_CONTR = 0xBC; //ADC control register
sfr ADC_RES = 0xBD; //ADC high 8-bit result register
sfr ADC_LOW2 = 0xBE; //ADC low 2-bit result register
sfr P1ASF = 0x9D; //P1 secondary function control register
/*Define ADC operation const for ADC_CONTR*/
#define ADC_POWER 0x80 //ADC power control bit
#define ADC_FLAG 0x10 //ADC complete flag
#define ADC_START 0x08 //ADC start control bit
#define ADC_SPEEDLL 0x00 //420 clocks
#define ADC_SPEEDL 0x20 //280 clocks
#define ADC_SPEEDH 0x40 //140 clocks
#define ADC_SPEEDHH 0x60 //70 clocks
Software delay function
void Delay(WORD n)
WORD x;
while (n--)
x = 5000;
while (x--);
Initial ADC sfr
void InitADC()
P1ASF = 0xff; //Open 8 channels ADC function
ADC_RES = 0; //Clear previous result
ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
Delay(2); //ADC power-on and delay
Get ADC result
void GetADCResult(uchar ch)
InitADC();
ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
_nop_(); //Must wait before inquiry
_nop_();
_nop_();
_nop_();
while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
ADC_CONTR &= ~ADC_FLAG; //Close ADC
void main ()
EA = 1; //开总中断
ConfigTimer0(1); //配置 TO 定时 1ms
ConfigUART(9600); //配置波特率为 9600
UartDriver();
38
void ConfigTimer0(unsigned int ms) //T0 配置函数
unsigned long tmp;
tmp = 11059200 / 12; //定时器技术频率
tmp = (tmp * ms) / 1000; //计算所需的计数值
tmp = 65536 - tmp; //计算定时器重载值
tmp = tmp + 34; //修正终端相应延时造成的误差
T0RH = (unsigned char)(tmp >> 8); //定时器重载值拆分为高低字节
T0RL = (unsigned char)tmp;
TMOD &= 0xF0; //清零 TO 的控制位
TMOD |= 0x01; //配置 TO 为模式 1
TH0 = T0RH; //加载 TO 重载值
TL0 = T0RL;
39
ET0 = 1; //使能 TO 中断
TR0 = 1; //启动 TO
void InterruptTimer0() interrupt 1 //T0 中断服务函数
TH0 = T0RH; //定时器重新加载重载值
TL0 = T0RL;
if (flagBuzzOn) //蜂鸣器鸣叫或失败
BUZZ = ~BUZZ;
BUZZ = 1;
UartRxMonitor(1);
错为1111.C(63): error C267: 'ConfigTimer0': requires ANSI-style prototype
ID:10947 发表于 2019-5-17 14:47 | 只看该作者
ET0 = 1;
这里的上面一行,有个数字39是什么东东?
ID:155507 发表于 2019-5-18 15:34 | 只看该作者
给你改了一下试试。
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. typedef unsigned char uchar;
  4. typedef unsigned int WORD;
  5. /*Declare SFR associated with the ADC */
  6. sfr ADC_CONTR = 0xBC; //ADC control register
  7. sfr ADC_RES = 0xBD; //ADC high 8-bit result register
  8. sfr ADC_LOW2 = 0xBE; //ADC low 2-bit result register
  9. sfr P1ASF = 0x9D; //P1 secondary function control register
  10. /*Define ADC operation const for ADC_CONTR*/
  11. #define ADC_POWER 0x80 //ADC power control bit
  12. #define ADC_FLAG 0x10 //ADC complete flag
  13. #define ADC_START 0x08 //ADC start control bit
  14. #define ADC_SPEEDLL 0x00 //420 clocks
  15. #define ADC_SPEEDL 0x20 //280 clocks
  16. #define ADC_SPEEDH 0x40 //140 clocks
  17. #define ADC_SPEEDHH 0x60 //70 clocks
  18. /*----------------------------
  19. Software delay function
  20. ----------------------------*/
  21. void Delay(WORD n)
  22. {
  23.         WORD x;
  24.         while (n--)
  25.         {
  26.                 x = 5000;
  27.                 while (x--);
  28.         }
  29. }
  30. /*----------------------------
  31. Initial ADC sfr
  32. ----------------------------*/
  33. void InitADC()
  34. {
  35.         P1ASF = 0xff; //Open 8 channels ADC function
  36.         ADC_RES = 0; //Clear previous result
  37.         ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
  38.         Delay(2); //ADC power-on and delay
  39. }
  40. /*----------------------------
  41. Get ADC result
  42. ----------------------------*/
  43. void GetADCResult(uchar ch)
  44. {
  45.         InitADC();
  46.         ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
  47.         _nop_(); //Must wait before inquiry
  48.         _nop_();
  49.         _nop_();
  50.         _nop_();
  51.         while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
  52.         ADC_CONTR &= ~ADC_FLAG; //Close ADC
  53. }
  54. void ConfigTimer0(unsigned int ms) //T0 配置函数
  55. {
  56.         unsigned long tmp;
  57.         tmp = 11059200 / 12; //定时器技术频率
  58.         tmp = (tmp * ms) / 1000; //计算所需的计数值
  59.         tmp = 65536 - tmp; //计算定时器重载值
  60.         tmp = tmp + 34; //修正终端相应延时造成的误差
  61.         T0RH = (unsigned char)(tmp >> 8); //定时器重载值拆分为高低字节
  62.         T0RL = (unsigned char)tmp;
  63.         TMOD &= 0xF0; //清零 TO 的控制位
  64.         TMOD |= 0x01; //配置 TO 为模式 1
  65.         TH0 = T0RH; //加载 TO 重载值
  66.         TL0 = T0RL;
  67.         //39
  68.         ET0 = 1; //使能 TO 中断
  69.         TR0 = 1; //启动 TO
  70. }
  71. void main ()
  72. {
  73.         EA = 1; //开总中断
  74.         ConfigTimer0(1); //配置 TO 定时 1ms
  75.         ConfigUART(9600); //配置波特率为 9600
  76.         while(1)
  77.         {
  78.                 UartDriver();
  79.         }
  80.         //38
  81. }
  82. void InterruptTimer0() interrupt 1 //T0 中断服务函数
  83. {
  84.         TH0 = T0RH; //定时器重新加载重载值
  85.         TL0 = T0RL;
  86.         if (flagBuzzOn) //蜂鸣器鸣叫或失败
  87.         BUZZ = ~BUZZ;
  88.         else
  89.         BUZZ = 1;
  90.         UartRxMonitor(1);
  91. }
  92. //错为1111.C(63): error C267: 'ConfigTimer0': requires ANSI-style prototype
