查看: 3381|回复: 0
单片机自动洗碗机面板程序+PCB原理图设计
Altium Designer画的自动洗碗机原理图和PCB图如下:(51hei附件中可下载工程文件)
#include"STC15Wxx.h"
#define uint unsigned int
void delay_ms(uint z)
        uchar y=0;
        for(;z>0;z--)
        for(y=115;y>0;y--);
uint Flag_count=0;
uint Flag_Temp=0;
#include"DS18B20.h"
//#include"LCD1602.h"
sbit LED_FLAG=P1^0;
sbit jinshui=P1^1;//进水
sbit chushui=P1^2;//出水
sbit meng=P1^3;
sbit DJ=P1^4; //电机
sbit ZYB=P1^5;//增压泵
sbit JE=P1^6;//加热
sbit JEB=P1^7;//电源加热
sbit gao=P2^3;//水位高
sbit wu=P2^2; //水位低
sbit qidong=P3^2;
sbit tingzhi=P3^3;
bit FLAG_qidong=0,FLAG_tingzhi=0;
bit detecyion_Water()//检测水位
        if(gao==0&&wu==1)//水位高
        //        P1=P1|0x40;//进水关
                jinshui=0;
                chushui=0;//出水关
                return 0;
        else                         //水位低
        //        P1=P1&0xfd;//进水开
                jinshui=1;
                chushui=0;//出水关
                return 1;
bit detecyion_Temp() //检测温度
        static uchar FLAG=0;
        EA=0;
        Write_Inst();
//        delay_ms(1000);
        Read_RAM();
        EA=1;
//        display_Temp();
        if(Flag_Temp<=3200)//温度低于32°加热
        //        P1=P1|0xc0;
                FLAG=1;
                JE=1;
                JEB=1;
                return 1;
        else if((FLAG==1&&Flag_Temp>=3300)||FLAG==0)//加热温度超过34°或大于32°
        //        P1=P1&0x3f;
                FLAG=0;
                JE=0;
                JEB=0;
                return 0;
        delay_ms(1000);
/*        if(FLAG=0&&Flag_Temp>3200)
                JE=1;
                JEB=1;
                return 0;
void wash_dishes_open()//洗碗开2分钟
        TR0=1;
        while((!(Flag_count>300))&&(!FLAG_tingzhi))//一分钟
                DJ=1;
                ZYB=1;
        TR0=0;
void wash_dishes_cue()//洗碗关
        DJ=0;
        ZYB=0;
        Flag_count=0;
        TH0=(65536-46080)/256;//50ms
        TL0=(65536-46080)%256;
void drainage()//排水
        uchar i;
        while((!detecyion_Water())&&(!FLAG_tingzhi))chushui=1;//水排至低水位
        for(i=0;i<5;i++)
                if(FLAG_tingzhi)break;
                if(detecyion_Water())//低水位
                        delay_ms(500);
                        chushui=1;
                        delay_ms(300);
void CPU_init()
        Write_Inst();
        delay_ms(1000);
        P1=P1|0xff;
        P2=P2|0xff;
        IT0=1;//下降沿触发
        IT1=1;
        TMOD=0x01;
        ET0=1;
        TR0=0;
        EX0=1;
        EX1=1;
        EA=1;
        CPU_init();
//        lcd_init();
        while(FLAG_qidong&&(!FLAG_tingzhi))
                LED_FLAG=0;
                while(detecyion_Water()&&(!FLAG_tingzhi));//水位
                while(detecyion_Temp()&&(!FLAG_tingzhi));//温度
                wash_dishes_open();//洗碗开2分钟
                wash_dishes_cue(); //洗碗关
                drainage();//排水
                LED_FLAG=1;
                EA=0;
                Write_Inst();
                EA=1;
                delay_ms(1000);
void T0_50ms() interrupt 1
        Flag_count++;
void INT0_0() interrupt 0
        FLAG_qidong=1;
        FLAG_tingzhi=0;
void INT1_1() interrupt 2
        FLAG_tingzhi=1;
        FLAG_qidong=0;
全部资料51hei下载地址:
面板(共阴)-595.7z (1.83 MB, 下载次数: 46)
一次循环.zip (33.03 KB, 下载次数: 43)
收藏收藏1 分享淘帖 顶 踩
