查看: 1764|回复: 1
这是追求极致还是死磕?
2019-5-15版本一:https://www.bilibili.com/video/av52557415/
2019-6-2版本二:https://www.bilibili.com/video/av54323283/
废话不多说,源码如下
  1. /*
  2. 2019 © Arduino_Maker
  3. */
  4. #include <TimerOne.h>
  5. byte m = 0;
  6. byte Pvalue = 0;
  7. boolean BreatheFlag = true;
  8. byte ModeNumber = 0;
  9. //byte oldModeNumber = 0;
  10. boolean Touchflag = false;
  11. unsigned int Time1 = 0;
  12. unsigned int timex = 0;
  13. const byte Ring[5][6]={
  14.                 {2,19,13},
  15.                 {9,14,17},
  16.                 {4,8,15,6,10,7},
  17.                 {18,16,12},
  18.                 {11,5,3}
  19.                 };
  20. void setup() {
  21.   Serial.begin(9600);
  22.   for(int i=0;i<5;i++){
  23.     for(int j=0;Ring[i][j]!='\0';j++){
  24.       pinMode(Ring[i][j],OUTPUT);
  25.     }
  26.   }
  27.   Timer1.initialize( 100000 );
  28.   Timer1.attachInterrupt( Timer2Interrupt );
  29. }
  30. void Timer2Interrupt(void){
  31.   if((analogRead(A6) < 100)  && (Touchflag==false)){
  32.     Touchflag = true;
  33.     Time1 = millis();
  34.     ModeNumber = ModeNumber + 1;
  35.     if(ModeNumber == 2) m = 0;
  36.     if(ModeNumber == 7) ModeNumber = 0;
  37.     //Serial.println(ModeNumber);
  38.     }
  39.     else  if((analogRead(A6) > 100)  && (Touchflag==true)){
  40.       Touchflag = false;
  41.       timex = millis() - Time1;
  42.       if(timex > 3000)  ModeNumber = 0;
  43.       }
  44.   }
  45. void loop() {
  46.   switch(ModeNumber){
  47.     case 0:   Mode0();      break;
  48.     case 1:   Mode1(10);    break;
  49.     case 2:   Mode2(100);   break;
  50.     case 3:   Mode3(100);   break;
  51.     case 4:   Mode4(100);   break;
  52.     case 5:   Mode5(10);    break;
  53.     case 6:   Mode6(60);    break;
  54.     default:  break;
  55.     }
  56. }
  57. void Mode0(void)
  58. {
  59.   Ring_Run(0,false);
  60.   Ring_Run(1,false);
  61.   Ring_Run(2,false);
  62.   Ring_Run(3,false);
  63.   Ring_Run(4,false);
  64.   }
  65. void Mode1(int Mytime)
  66. {
  67.   analogWrite(Ring[4][0],Pvalue);
  68.   analogWrite(Ring[4][1],Pvalue);
  69.   analogWrite(Ring[4][2],Pvalue);
  70.   if(BreatheFlag==true){
  71.     Pvalue = Pvalue + 1;
  72.     if(Pvalue == 255) BreatheFlag = false;
  73.     }
  74.   if(BreatheFlag==false){
  75.     Pvalue = Pvalue - 1;
  76.     if(Pvalue == 0) BreatheFlag = true;
  77.     }
  78.   delay(Mytime);
  79.   }
  80. void Mode2(int Mytime)
  81. {
  82.   switch(m){
  83.     case 0:   Ring_Run(0,true); break;
  84.     case 1:   delay(4*Mytime);  break;
  85.     case 2:   Ring_Run(1,true); break;
  86.     case 3:   delay(3*Mytime);  break;
  87.     case 4:   Ring_Run(2,true); break;
  88.     case 5:   delay(2*Mytime);  break;
  89.     case 6:   Ring_Run(3,true); break;
  90.     case 7:   delay(Mytime);    break;
  91.     case 8:   Ring_Run(4,true); break;
  92.     case 9:   delay(4*Mytime);  break;
  93.     case 10:  delay(4*Mytime);  break;
  94.     case 11:  Ring_Run(4,false);break;
  95.     case 12:  delay(Mytime);    break;
  96.     case 13:  Ring_Run(3,false);break;
  97.     case 14:  delay(2*Mytime);  break;
  98.     case 15:  Ring_Run(2,false);break;
  99.     case 16:  delay(3*Mytime);  break;
  100.     case 17:  Ring_Run(1,false);break;
  101.     case 18:  delay(4*Mytime);  break;
  102.     case 19:  Ring_Run(0,false);break;
  103.     case 20:  delay(4*Mytime);  break;
  104.     case 21:  delay(4*Mytime);  break;
  105.     default: break;
  106.     }
  107.     m = m + 1;
  108.     if(m == 22) m = 0;
  109.   }
  110. void Mode3(int Mytime)
  111. {
  112.   Ring_Run(0,true);
  113.   Ring_Run(1,true);
  114.   Ring_Run(2,true);
  115.   Ring_Run(3,true);
  116.   Ring_Run(4,true);
  117.   delay(Mytime);
  118.   Ring_Run(0,false);
  119.   Ring_Run(1,false);
  120.   Ring_Run(2,false);
  121.   Ring_Run(3,false);
  122.   Ring_Run(4,false);
  123.   delay(Mytime);
  124.   }
  125. void Mode4(int Mytime)
  126. {
  127.   Leaf_Run(2,false);Leaf_Run(0,true);delay(Mytime);
  128.   Leaf_Run(0,false);Leaf_Run(1,true);delay(Mytime);
  129.   Leaf_Run(1,false);Leaf_Run(2,true);delay(Mytime);
  130.   }
  131. void Mode5(int Mytime)
  132. {
  133.   digitalWrite(Ring[0][2],LOW);digitalWrite(Ring[0][0],HIGH);delay(Mytime);
  134.   digitalWrite(Ring[0][0],LOW);digitalWrite(Ring[0][1],HIGH);delay(Mytime);
  135.   digitalWrite(Ring[0][1],LOW);digitalWrite(Ring[0][2],HIGH);delay(Mytime);
  136.   digitalWrite(Ring[0][2],LOW);
  137.   digitalWrite(Ring[1][1],LOW);digitalWrite(Ring[1][0],HIGH);delay(Mytime);
  138.   digitalWrite(Ring[1][0],LOW);digitalWrite(Ring[1][2],HIGH);delay(Mytime);
  139.   digitalWrite(Ring[1][2],LOW);digitalWrite(Ring[1][1],HIGH);delay(Mytime);
  140.   digitalWrite(Ring[1][1],LOW);
  141.   digitalWrite(Ring[2][4],LOW);digitalWrite(Ring[2][5],LOW);digitalWrite(Ring[2][2],HIGH);digitalWrite(Ring[2][3],HIGH);delay(Mytime);
  142.   digitalWrite(Ring[2][2],LOW);digitalWrite(Ring[2][3],LOW);digitalWrite(Ring[2][0],HIGH);digitalWrite(Ring[2][1],HIGH);delay(Mytime);
  143.   digitalWrite(Ring[2][0],LOW);digitalWrite(Ring[2][1],LOW);digitalWrite(Ring[2][4],HIGH);digitalWrite(Ring[2][5],HIGH);delay(Mytime);
  144.   digitalWrite(Ring[2][4],LOW);digitalWrite(Ring[2][5],LOW);
  145.   digitalWrite(Ring[3][2],LOW);digitalWrite(Ring[3][0],HIGH);delay(Mytime);
  146.   digitalWrite(Ring[3][0],LOW);digitalWrite(Ring[3][1],HIGH);delay(Mytime);
  147.   digitalWrite(Ring[3][1],LOW);digitalWrite(Ring[3][2],HIGH);delay(Mytime);
  148.   digitalWrite(Ring[3][2],LOW);
  149.   digitalWrite(Ring[4][2],LOW);digitalWrite(Ring[4][0],HIGH);delay(Mytime);
  150.   digitalWrite(Ring[4][0],LOW);digitalWrite(Ring[4][1],HIGH);delay(Mytime);
  151.   digitalWrite(Ring[4][1],LOW);digitalWrite(Ring[4][2],HIGH);delay(Mytime);
  152.   digitalWrite(Ring[4][2],LOW);
  153.   }
  154. void Mode6(int Mytime)
  155. {
  156.   Ring_Run(0,true);
  157.   Ring_Run(4,true);
  158.   digitalWrite(Ring[2][4],LOW);digitalWrite(Ring[2][3],HIGH);delay(Mytime);
  159.   digitalWrite(Ring[2][3],LOW);digitalWrite(Ring[3][1],HIGH);delay(Mytime);
  160.   digitalWrite(Ring[3][1],LOW);digitalWrite(Ring[2][2],HIGH);delay(Mytime);
  161.   digitalWrite(Ring[2][2],LOW);digitalWrite(Ring[2][1],HIGH);delay(Mytime);
  162.   digitalWrite(Ring[2][1],LOW);digitalWrite(Ring[3][0],HIGH);delay(Mytime);
  163.   digitalWrite(Ring[3][0],LOW);digitalWrite(Ring[2][0],HIGH);delay(Mytime);
  164.   digitalWrite(Ring[2][0],LOW);digitalWrite(Ring[2][5],HIGH);delay(Mytime);
  165.   digitalWrite(Ring[2][5],LOW);digitalWrite(Ring[3][2],HIGH);delay(Mytime);
  166.   digitalWrite(Ring[3][2],LOW);digitalWrite(Ring[2][4],HIGH);delay(Mytime);
  167.   }
  168. void Ring_Run(byte n,boolean k)
  169. {
  170.   if(k==true)
  171.     switch(n){
  172.       case 0:
  173.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[0][i],HIGH);  break;
  174.       case 1:
  175.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[1][i],HIGH);  break;
  176.       case 2:
  177.         for(int i = 0;i < 6;i++)  digitalWrite(Ring[2][i],HIGH);  break;
  178.       case 3:
  179.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[3][i],HIGH);  break;
  180.       case 4:
  181.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[4][i],HIGH);  break;
  182.       default : break;
  183.       }
  184.     else  switch(n){
  185.       case 0:
  186.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[0][i],LOW);  break;
  187.       case 1:
  188.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[1][i],LOW);  break;
  189.       case 2:
  190.         for(int i = 0;i < 6;i++)  digitalWrite(Ring[2][i],LOW);  break;
  191.       case 3:
  192.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[3][i],LOW);  break;
  193.       case 4:
  194.         for(int i = 0;i < 3;i++)  digitalWrite(Ring[4][i],LOW);  break;
  195.       default : break;
  196.       }
  197.   }
  198. void Leaf_Run(byte n,boolean k)
  199. {
  200.   if(k==true)
  201.     switch(n){
  202.       case 0:
  203.         digitalWrite(Ring[1][0],HIGH);
  204.         digitalWrite(Ring[2][0],HIGH);
  205.         digitalWrite(Ring[2][1],HIGH);
  206.         digitalWrite(Ring[3][0],HIGH);
  207.         digitalWrite(Ring[4][0],HIGH);
  208.         break;
  209.       case 1:
  210.         digitalWrite(Ring[1][2],HIGH);
  211.         digitalWrite(Ring[2][5],HIGH);
  212.         digitalWrite(Ring[2][4],HIGH);
  213.         digitalWrite(Ring[3][2],HIGH);
  214.         digitalWrite(Ring[4][2],HIGH);
  215.         break;
  216.       case 2:
  217.         digitalWrite(Ring[1][1],HIGH);
  218.         digitalWrite(Ring[2][2],HIGH);
  219.         digitalWrite(Ring[2][3],HIGH);
  220.         digitalWrite(Ring[3][1],HIGH);
  221.         digitalWrite(Ring[4][1],HIGH);
  222.         break;
  223.       default: break;
  224.       }
  225.     else switch(n){
  226.       case 0:
  227.         digitalWrite(Ring[1][0],LOW);
  228.         digitalWrite(Ring[2][0],LOW);
  229.         digitalWrite(Ring[2][1],LOW);
  230.         digitalWrite(Ring[3][0],LOW);
  231.         digitalWrite(Ring[4][0],LOW);
  232.         break;
  233.       case 1:
  234.         digitalWrite(Ring[1][2],LOW);
  235.         digitalWrite(Ring[2][5],LOW);
  236.         digitalWrite(Ring[2][4],LOW);
  237.         digitalWrite(Ring[3][2],LOW);
  238.         digitalWrite(Ring[4][2],LOW);
  239.         break;
  240.       case 2:
  241.         digitalWrite(Ring[1][1],LOW);
  242.         digitalWrite(Ring[2][2],LOW);
  243.         digitalWrite(Ring[2][3],LOW);
  244.         digitalWrite(Ring[3][1],LOW);
  245.         digitalWrite(Ring[4][1],LOW);
  246.         break;
  247.       default: break;
  248.       }
  249.   }
ID:102963 发表于 2019-6-13 22:41 | 只看该作者
这就是追求极致,艺术创意,很不错的设计
