基于51单片机的二氧化碳、温湿度检测系统设计。采用LCD1602显示,CO2传感器使用MH-Z19B,温湿度传感器使用DHT11,此文件含有代码、原理图、PCB文件。
制作出来的实物图如下:
- /********************************** (C) COPYRIGHT *******************************
- * File Name : main.C
- * Author :
- * License : MIT
- * Version : V1.0
- * Date : 2019/04/12
- * Description : 51温湿度二氧化碳检测
- #include <reg52.h>
- #include "1602.h"
- #include "dht.h"
- #include "2402.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- //定义三个LED灯
- sbit Led_qushi = P1^0; //去湿灯
- sbit Led_jiangwen = P1^1; //降温灯
- sbit led_CO2 = P1^2; //二氧化碳控制灯
- //定义蜂鸣器
- sbit fmq = P2^3; //蜂鸣器
- //定义设置键、调整键
- sbit Key_TH1 = P3^0;//温度上限值调整按键
- sbit Key_TH2 = P3^1;
- sbit Key_HH1 = P3^2;//湿度上限值调整按键
- sbit Key_HH2 = P3^3;
- sbit shezhi = P2^7;//设置键
- sbit Key_CH1 = P2^6;//二氧化碳上限值调整按键
- sbit Key_CH2 = P2^5;
- //二氧化碳发送指令
- uchar code tab[9]={0xff,0x01,0x86,0x00,0x00,0x00,0x00,0x00,0x79};
- uchar date[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- //定义标识
- volatile bit FlagStartRH = 0; //开始温湿度转换标志
- volatile bit FlagKeyPress = 0; //有键按下
- volatile bit fmqt = 0;
- volatile bit fmqh = 0;
- volatile bit fmqc = 0;
- //定义温湿度传感器用外部变量
- extern U8 U8FLAG,k;
- extern U8 U8count,U8temp;
- extern U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
- extern U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
- extern U8 U8comdata;
- extern U8 count, count_r;
- U16 temp;
- S16 temperature, humidity;
- S16 idata TH, HH, ch; //温度上限和湿度上限//二氧化碳上限值
- char * pSave;
- U8 keyvalue, keyTH1, keyTH2, keyHH1, keyHH2, keyCH1, keyCH2;
- unsigned char moshi=0;
- //定义变量
- U16 RHCounter;
- 延时子程序
- 延时时间(xms*1)ms
- void delayms(uint xms)
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- * 功 能 : 串口发送
- * 注意事项 :
- void send(uchar dat) //发送一字节
- SBUF=dat;
- while(!TI);
- TI=0;
- * 功 能 : 数据初始化程序
- * 注意事项 :
- void Data_Init()
- RHCounter = 0;
- Led_qushi = 1;
- Led_jiangwen = 1;
- led_CO2 = 1;
- TH = 40; //温度初始上限值
- HH = 85; //湿度初始上限限制
- ch = 25; //二氧化碳初始上限值
- keyvalue = 0;
- keyTH1 = 1;
- keyTH2 = 1;
- keyHH1 = 1;
- keyHH2 = 1;
- keyCH1 = 1;
- keyCH2 = 1;
- //定时器0初始化
- void Timer0_Init()
- ET0 = 1; //允许定时器0中断
- TMOD = 1; //定时器工作方式选择
- TL0 = 0x06;
- TH0 = 0xf8; //定时器赋予初值
- TR0 = 1; //启动定时器
- //存入设定值、
- void Save_Setting()
- pSave = (char *)&TH; //地址低位对应低8位,高位对应高8位
- wrteeprom(0, *pSave); //存温度上限值TH低8位
- DELAY(300);
- pSave ++;
- wrteeprom(1, *pSave); //存温度上限值TH高8位
- DELAY(300);
- pSave = (char *)&HH;
- wrteeprom(2, *pSave); //存湿度上限值RH低8位
- DELAY(300);
- pSave ++;
- wrteeprom(3, *pSave); //存湿度上限值RH高8位
- DELAY(300);
- pSave = (char *)&ch;
- wrteeprom(4, *pSave); //存CO2上限值RH低8位
- DELAY(300);
- pSave ++;
- wrteeprom(5, *pSave); //存CO2上限值RH高8位
- DELAY(300);
- //载入设定值、
- void Load_Setting()
- *pSave++ = rdeeprom(0);
- *pSave = rdeeprom(1);
- *pSave++ = rdeeprom(2);
- *pSave = rdeeprom(3);
- *pSave++ = rdeeprom(4);
- *pSave = rdeeprom(5);
- if ((TH>99)||(TH<0)) TH = 40;
- if ((HH>99)||(HH<0)) HH = 85;
- if ((ch>50)||(ch<0)) ch = 25;
- //按键扫描程序
- void Key_set_scan()
- if(shezhi==0)
- delayms(10);
- if(shezhi==0)
- while(!shezhi);
- L1602_init(); //初始化液晶
- moshi++;
- if(moshi >= 2)moshi = 0;
- if(moshi == 0)
- L1602_string(1,1,"Te: C ");
- L1602_string(1,9,"Hu: % ");
- L1602_string(2,1,"PPM: ");
- else if(moshi == 1)
- L1602_string(1,1,"TH:");
- L1602_string(1,9,"HH:");
- L1602_string(2,1,"CH:");
- L1602_string(2,8,"0");
- L1602_string(2,9,"0");
- //按键加减设定值
- void KeyProcess(uint num)
- switch (num)
- case 1:
- if (TH<99) TH++;
- L1602_char(1, 5, TH/10+48);
- L1602_char(1, 6, TH%10+48);
- break;
- case 2:
- if (TH>1) TH--;
- break;
- case 3:
- if (HH<99) HH++;
- L1602_char(1, 13, HH/10+48);
- L1602_char(1, 14, HH%10+48);
- break;
- case 4:
- if (HH>1) HH--;
- break;
- case 5:
- if (ch<50) ch++;
- L1602_char(2, 6, ch/10+48);
- L1602_char(2, 7, ch%10+48);
- break;
- case 6:
- if (ch>1) ch--;
- break;
- default:
- break;
- Save_Setting();
- * 函 数 名 : main
- * 函数功能 : 主函数
- * 输 入 : 无
- * 输 出 : 无
- void main()
- U16 testnum;
- uint tmp;
- uchar m;
- EA = 0;
- Timer0_Init(); //定时器0初始化
- Data_Init();
- EA = 1;
- TMOD=0x20; // T1定时方式2
- SCON=0x40;//串行工作 方式1
- PCON=0x00; //不加倍
- TH1=TL1=0xfd; //定时器1赋初值 保证波特率9600
- TR1=1; //开定时器1
- REN=1; //允许串口接收
- delayms(10);
- ES=1; //打开串口中断
- EA=1; //开总中断
- L1602_init();
- Load_Setting();
- while(1)
- for(m=0;m<9;m++) //向co2传感器发送数据
- send(tab[m]);
- delayms(100); //延时0.1s 刷新测得数据
- tmp=date[2]*256+date[3]; //计算出co2浓度值
- //温湿度转换标志检查
- if (FlagStartRH == 1)
- TR0 = 0;
- testnum = RH();
- FlagStartRH = 0;
- TR0 = 1;
- //读出温湿度,只取整数部分
- humidity = U8RH_data_H;
- temperature = U8T_data_H;
- //温湿度控制
- if (temperature > TH)
- Led_jiangwen = 0;
- fmqt=1;
- else
- Led_jiangwen = 1;
- fmqt=0;
- } //降温
- if (humidity > HH)
- Led_qushi = 0;
- fmqh=1;
- else
- Led_qushi = 1;
- fmqh=0;
- } //去湿
- if (tmp/100 > ch)
- led_CO2 = 0;
- fmqc=1;
- else
- led_CO2 = 1;
- fmqc=0;
- } //CO2
- if((fmqt==1)||(fmqh==1)||(fmqc==1))
- fmq=0;
- else
- fmq=1;
- Key_set_scan();//按键扫描
- if(moshi == 0) //设置模式切换
- delayms(50);
- if(tmp>9999)
- tmp=0;
- L1602_int(2,5,tmp);
- if((tmp/1000)>0)
- L1602_int(2,5,tmp/1000);
- //显示温湿度
- L1602_int(1,3, temperature);
- L1602_int(1,11,humidity);
- else if(moshi == 1) //设置上限模式
- //U8 keyvalue, keyTH1, keyTH2, keyHH1, keyHH2, keyCH1, keyCH2;
- //键盘查询,在弹起时响应
- if ((Key_TH1)&&(keyTH1==0)) {FlagKeyPress = 1; keyvalue = 1;}
- else if ((Key_TH2)&&(keyTH2==0)) {FlagKeyPress = 1; keyvalue = 2;}
- else if ((Key_HH1)&&(keyHH1==0)) {FlagKeyPress = 1; keyvalue = 3;}
- else if ((Key_HH2)&&(keyHH2==0)) {FlagKeyPress = 1; keyvalue = 4;}
- else if ((Key_CH1)&&(keyCH1==0)) {FlagKeyPress = 1; keyvalue = 5;}
- else if ((Key_CH2)&&(keyCH2==0)) {FlagKeyPress = 1; keyvalue = 6;}
- if (FlagKeyPress == 1)
- KeyProcess(keyvalue);
- FlagKeyPress = 0;
- if (!Key_TH1) keyTH1 = 0;
- else keyTH1 = 1;
- if (!Key_TH2) keyTH2 = 0;
- else keyTH2 = 1;
- if (!Key_HH1) keyHH1 = 0;
- else keyHH1 = 1;
- if (!Key_HH2) keyHH2 = 0;
- else keyHH2 = 1;
- if (!Key_CH1) keyCH1 = 0;
- else keyCH1 = 1;
- if (!Key_CH2) keyCH2 = 0;
- else keyCH2 = 1;
- //定时器0中断
- void Timer0_ISR (void) interrupt 1
- TL0 = 0x06;
- //每2秒钟启动一次温湿度转换
- RHCounter ++;
- if (RHCounter >= 1000)
- FlagStartRH = 1;
- RHCounter = 0;
- //串口中断服务函数
- void serial()interrupt 4
- static uchar j;
- ES=0; //禁止中断
- if(!RI);
- RI=0; //清楚接收完毕标志
- date[j]=SBUF;
- if(date[0]==0xff) //判断接收到的第一位为传感器所发数据
- j++;
- else
- j=0;
- if(j==9) //接收传感器所发数据9字节
- j=0;
- ES=1; //允许串口中断
51单片机二氧化碳_温湿度检测C程序+原理图+PCB.zip
(1.85 MB, 下载次数: 258)
