查看: 1347|回复: 2
stm32 f1 超声波程序
ID:555922 发表于 2019-6-5 19:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "led.h"
#include "key.h"
硬件连接
串口1:RX PA10  TX PA9
超声波:Trig PB11    ECHG PB10
备注:以下代码非原创,只是经过修改适配成STM32F103C8T6
若侵权,请告知。
//超声波硬件接口定义
#define HCSR04_PORT     GPIOB
#define HCSR04_CLK      RCC_APB2Periph_GPIOB
#define HCSR04_TRIG     GPIO_Pin_11
#define HCSR04_ECHO     GPIO_Pin_10
//超声波计数
u16 msHcCount = 0;
//定时器4设置
void hcsr04_NVIC()
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
//IO口初始化 及其他初始化
void Hcsr04Init()
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
    GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
    GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
    GPIO_InitStructure.GPIO_Pin =   HCSR04_ECHO;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
    TIM_DeInit(TIM2);
    TIM_TimeBaseStructure.TIM_Period = (1000-1);
    TIM_TimeBaseStructure.TIM_Prescaler =(72-1);
    TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
    TIM_ClearFlag(TIM4, TIM_FLAG_Update);
    TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
    hcsr04_NVIC();
    TIM_Cmd(TIM4,DISABLE);
//打开定时器4
static void OpenTimerForHc()
   TIM_SetCounter(TIM4,0);
   msHcCount = 0;
   TIM_Cmd(TIM4, ENABLE);
//关闭定时器4
static void CloseTimerForHc()
   TIM_Cmd(TIM4, DISABLE);
//定时器4终中断
void TIM4_IRQHandler(void)
   if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
       TIM_ClearITPendingBit(TIM4, TIM_IT_Update  );
       msHcCount++;
//获取定时器4计数器值
u32 GetEchoTimer(void)
   u32 t = 0;
   t = msHcCount*1000;
   t += TIM_GetCounter(TIM4);
   TIM4->CNT = 0;
   delay_ms(50);
   return t;
//通过定时器4计数器值推算距离
float Hcsr04GetLength(void )
   u32 t = 0;
   int i = 0;
   float lengthTemp = 0;
   float sum = 0;
   while(i!=5)
      TRIG_Send = 1;
      delay_us(20);
      TRIG_Send = 0;
      while(ECHO_Reci == 0);
      OpenTimerForHc();
      i = i + 1;
      while(ECHO_Reci == 1);
      CloseTimerForHc();
      t = GetEchoTimer();
      lengthTemp = ((float)t/58.0);//cm
      sum = lengthTemp + sum ;
    lengthTemp = sum/5.0;
    return lengthTemp;
//测试主函数
int main(void)
         float length;
         delay_init();                     //延时函数初始化
         NVIC_Configuration();          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
         uart_init(9600);                 //串口初始化为9600
         Hcsr04Init();
         printf("大海电子串口测试\r\n");
   Hcsr04Init();
   printf("超声波初始化成功!\n");
     length = Hcsr04GetLength();
     printf("距离为:%.3fcm\n",length);
                 delay_ms(1000);
ID:496481 发表于 2019-6-14 21:51 | 只看该作者
能问下你这些的主函数是不是少了一些 ,打开定时器和关闭定时器能不用外部中断吗,就IO口判断行吗?定时器4的终端是干什么用的
ID:588621 发表于 2019-8-2 18:50 来自手机 | 只看该作者
704597517 发表于 2019-6-14 21:51
能问下你这些的主函数是不是少了一些 ,打开定时器和关闭定时器能不用外部中断吗,就IO口判断行吗?定时器4 ...
你有好的实现方案程序吗,可不可以参考下
