查看: 10528|回复: 2
OLED花样显示之画圆矩形直线STM32源程序
ID:222477 发表于 2019-6-9 21:58 | 显示全部楼层 |阅读模式
用STM32F103C8T6控制0.96寸OLED显示屏显示矩形,直线和圆,动态生成,是移植的正点原子TFT显示屏的程序
制作出来的实物图如下:
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "usart.h"
  6. #include "usmart.h"
  7. #include "OLED_I2C.h"
  8. extern unsigned char BMP1[];
  9. unsigned char BMP2[8192];
  10. //将128*8的数组转为128*64
  11. void Change_to_12864(unsigned char BMP[])
  12. {
  13.         unsigned int j=0;
  14.         unsigned char x,y,n,BMP3[1024];
  15.         for(y=0;y<64;y=y+8)
  16.         {
  17.                 for(x=0;x<128;x++)
  18.                 {
  19.                         BMP3[j]=BMP[j];
  20.                         for(n=0;n<8;n++)
  21.                         {
  22.                                         if(BMP3[j]&0x01)
  23.                                         BMP2[x+(y+n)*128]=1;
  24.                                         BMP3[j]=BMP3[j]>>1;
  25.                         }
  26.                         j++;
  27.                 }
  28.         }
  29. }
  30. //将128*64的数组转为128*8
  31. void Change_to_1288(unsigned char BMP4[])
  32. {
  33.         unsigned int j=0;
  34.         unsigned char x,y,n,temp;
  35.
  36.         for(y=0;y<64;y=y+8)
  37.         {
  38.                 for(x=0;x<128;x++)
  39.                 {
  40.                         for(n=0;n<8;n++)
  41.                         {
  42.                                         temp|=BMP4[x+(y+n)*128]<<7;
  43.                                         if(n<7)
  44.                                         temp=temp>>1;
  45.                         }
  46.                         BMP1[j]=temp;
  47.                         temp=0;
  48.                         j++;
  49.                 }
  50.         }
  51. }
  52. //画线
  53. //x1,y1:起点坐标
  54. //x2,y2:终点坐标
  55. void LCD_DrawLine(u16 x1, u16 y1, u16 x2, u16 y2)
  56. {
  57.         u16 t;
  58.         int xerr=0,yerr=0,delta_x,delta_y,distance;
  59.         int incx,incy,uRow,uCol;
  60.         delta_x=x2-x1; //计算坐标增量
  61.         delta_y=y2-y1;
  62.         uRow=x1;
  63.         uCol=y1;
  64.         if(delta_x>0)incx=1; //设置单步方向
  65.         else if(delta_x==0)incx=0;//垂直线
  66.         else {incx=-1;delta_x=-delta_x;}
  67.         if(delta_y>0)incy=1;
  68.         else if(delta_y==0)incy=0;//水平线
  69.         else{incy=-1;delta_y=-delta_y;}
  70.         if( delta_x>delta_y)distance=delta_x; //选取基本增量坐标轴
  71.         else distance=delta_y;
  72.         for(t=0;t<=distance+1;t++ )//画线输出
  73.         {
  74.                 BMP2[uRow+uCol*128]=1;//画点
  75.                 xerr+=delta_x ;
  76.                 yerr+=delta_y ;
  77.                 if(xerr>distance)
  78.                 {
  79.                         xerr-=distance;
  80.                         uRow+=incx;
  81.                 }
  82.                 if(yerr>distance)
  83.                 {
  84.                         yerr-=distance;
  85.                         uCol+=incy;
  86.                 }
  87.         }
  88. }
  89. //画矩形
  90. //(x1,y1),(x2,y2):矩形的对角坐标
  91. void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2)
  92. {
  93.         LCD_DrawLine(x1,y1,x2,y1);
  94.         LCD_DrawLine(x1,y1,x1,y2);
  95.         LCD_DrawLine(x1,y2,x2,y2);
  96.         LCD_DrawLine(x2,y1,x2,y2);
  97. }
  98. //在指定位置画一个指定大小的圆
  99. //(x,y):中心点
  100. //r    :半径
  101. void LCD_Draw_Circle(u16 x0,u16 y0,u8 r)
  102. {
  103.         int a,b,x,y;
  104.         int di;
  105.         a=0;b=r;
  106.         di=3-(r<<1);             //判断下个点位置的标志
  107.         while(a<=b)
  108.         {
  109.                 BMP2[x0+a+(y0-b)*128]=1;             //5
  110.                  BMP2[x0+b+(y0-a)*128]=1;             //0
  111.                 BMP2[x0+b+(y0+a)*128]=1;             //4
  112.                 BMP2[x0+a+(y0+b)*128]=1;             //6
  113.                 BMP2[x0-a+(y0+b)*128]=1;             //1
  114.                  BMP2[x0-b+(y0+a)*128]=1;
  115.                 BMP2[x0-a+(y0-b)*128]=1;             //2
  116.           BMP2[x0-b+(y0-a)*128]=1;             //7
  117.                 a++;
  118.                 //使用Bresenham算法画圆
  119.                 if(di<0)di +=4*a+6;
  120.                 else
  121.                 {
  122.                         di+=10+4*(a-b);
  123.                         b--;
  124.                 }
  125.         }
  126. }
  127. //显示全屏
  128. void OLED_Fast(unsigned char BMP[])
  129. {
  130.         unsigned int j=0;
  131.         unsigned char x,y;
  132.         for(y=0;y<8;y++)
  133.         {
  134.                 OLED_SetPos(0,y);
  135.     for(x=0;x<128;x++)
  136.                 {
  137.                         WriteDat(BMP[j]);
  138.                         j++;
  139.                 }
  140.         }
  141. }
  142. //LED状态设置函数
  143. void led_set(u8 sta)
  144. {
  145.         LED1=sta;
  146. }
  147. //函数参数调用测试函数
  148. void test_fun()
  149. {
  150.         OLED_DrawBMP(0,0,128,8,(unsigned char *)BMP1);
  151. }
  152. int main(void)
  153. {
  154.          u8 h,y,x,z;
  155.         delay_init();                     //延时函数初始化
  156.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  157.         uart_init(115200);                 //串口初始化为115200
  158.          LED_Init();                             //LED端口初始化
  159.         I2C_Configuration();
  160.         OLED_Init();
  161.         usmart_dev.init(SystemCoreClock/1000000);        //初始化USMART
  162.         OLED_CLS();
  163.         h=12;
  164.           while(1)
  165.         {
  166.                 for(y=0;y<64;y++)
  167.                 {
  168.                         for(x=0;x<128;x++)
  169.                         {
  170.                                 BMP2[x+y*128]=0;
  171.                         }
  172.                 }
  173.                  LCD_Draw_Circle(32+z,32,12);
  174.                 LCD_Draw_Circle(96-z,32,h);
  175.                 LCD_DrawRectangle(56,48,72,56);
  176.                  Change_to_1288((unsigned char *)BMP2);
  177.                  OLED_Fast((unsigned char *)BMP1);
  178.                 if(z<8)
  179.                 z=z+1;
  180.                 else
  181.                 z=z-1;
  182.                 if(z==8)z=16;
  183.                 if(z==10)z=0;
  184.         }
  185. }
OLED-画圆矩形直线.7z (209.67 KB, 下载次数: 204)
ID:75408 发表于 2019-10-15 20:36 | 显示全部楼层
看似有帮助,明天放到STC90单片机中试试。
ID:884042 发表于 2021-7-30 16:01 | 显示全部楼层
请问可以兼容51吗?
