查看: 9897|回复: 7
DIY_oled显示屏+ds18b20 显示温度和时间 单片机程序
电路原理图如下:
  1. #include "STC15W.H"
  2. #include "iic.h"
  3. //#include "zifu.h"
  4. #include "delay.h"
  5. #include "stdio.h"
  6. #include "intrins.h"
  7. #include "temp.h"
  8. /*******定义时间变量********************/
  9. unsigned int count=0;
  10. unsigned int count1=9;
  11. unsigned int second0;
  12. unsigned int second1;
  13. unsigned int min0;
  14. unsigned int min1;
  15. unsigned int hour0;
  16. unsigned int hour1;
  17. unsigned char s[3];
  18. unsigned char h1[1],h0[1],m1[1],m0[1],s1[1],s0[1];
  19. /****************************************************/
  20. bit flag = 0; //定义秒针闪烁的标志位
  21. /**********************定义温度的参数变量*****************/
  22. code unsigned char float_tab[16]={0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9};//小数表
  23. unsigned int  Display_Digit[]={0,0,0,0};
  24. unsigned char wendu=0;
  25. unsigned char aa,bb;
  26. unsigned char CurrentT=0;
  27. unsigned char Temp_Value[]={0x00,0x00};
  28. unsigned char DS18B20_IS_OK;
  29. unsigned char bai[1],shi[1],ge[1];
  30. /********************************************************/
  31. /*  定时器0的配置**************************************/
  32. void Timer0Init()                //定时50ms出发一次中断
  33. {
  34.         AUXR &= 0x7F;
  35.         TMOD &= 0xF0;
  36.         TL0 = 0x00;
  37.         TH0 = 0x4C;
  38.         //TF0 = 0;
  39.         TR0 = 1;
  40.         ET0=1;
  41.         EA=1;
  42. }
  43. void TIMER0()  interrupt 1
  44. {
  45.         count++;  //50毫秒触发一次
  46.         if(count==20) //定时为1秒
  47.         {
  48.                 count=0;second0+=1; flag=~flag;
  49.         }
  50.         if(second0>9)
  51.         {
  52.                 second0=0;second1+=1;
  53.         }
  54.         if(second1>5)
  55.         {
  56.                 second1=0;min0+=1;
  57.         }
  58.         if(min0>9)
  59.         {
  60.                 min0=0;min1+=1;
  61.         }
  62.         if(min1>5)
  63.         {
  64.                 min1=0;hour0+=1;
  65.         }
  66.         if(hour1<2)
  67.         {
  68.                 if(hour0>9)
  69.                 {
  70.                         hour0=0;hour1+=1;
  71.                 }
  72.
  73.         }
  74.         if(hour1==2)
  75.         {
  76.                 if(hour0>3)
  77.                 {
  78.                         second0=0;second1=0;
  79.                         min0=0;min1=0;
  80.                         hour0=0;hour1=0;
  81.                 }
  82.         }
  83.
  84.
  85.
  86.
  87.
  88. }
  89. //读取温度
  90. void Read_Temperature()
  91. {
  92.                 if(Init_DS18B20()==1)
  93.                 DS18B20_IS_OK=0;
  94.                 else
  95.                 {
  96.
  97.                 WriteOneByte(0xcc);                          //跳过序列号
  98.                 WriteOneByte(0x44);                           //启动温度转换
  99.                 Init_DS18B20();
  100.                 WriteOneByte(0xcc);
  101.                 WriteOneByte(0xbe);                                //读取温度
  102.                 Temp_Value[0] = ReadOneByte();           //低八位
  103.                 Temp_Value[1] = ReadOneByte();           //高八位
  104.                 DS18B20_IS_OK=1;
  105.
  106.
  107.                 }
  108.
  109. }
  110. void main()
  111. {
  112.
  113.         Timer0Init()        ;
  114.         Initial_M096128x64_ssd1306();
  115.         OLED_CLS();
  116.         Delay_ms(5);
  117.
  118.
  119.         while(1)
  120.         {
  121.
  122.                 Read_Temperature();
  123.         if((Temp_Value[1]&0xf8)==0xf8)                        //判断高5位,如果都为1则是负数
  124.         {
  125.                  Temp_Value[1] = ~Temp_Value[1];                  //如果为负数。高八位需要取反,第八位需要取反后加1.
  126.                 Temp_Value[0] = ~Temp_Value[0]+1;
  127.                 if(Temp_Value[0]==0x00)
  128.                         Temp_Value[1]++;
  129.                 wendu = 1;
  130.
  131.         }
  132.         else{wendu = 0;}
  133.          aa=Temp_Value[0]&0x0f;           //小数点后一位算法
  134.          bb=aa*0.0625*10;
  135.          CurrentT= ((Temp_Value[0]&0xf0)>>4) | ((Temp_Value[1]&0x07)<<4);         //整数值
  136.          Display_Digit[1] = CurrentT/10; //百位          CurrentT%1000/100;
  137.          Display_Digit[2] = CurrentT%10;          //十位          CurrentT%100/10;
  138.          Display_Digit[3] =  bb%10;                  //个位          CurrentT%10;
  139.
  140.
  141.
  142.                 OLED_P8x16Str(0,0,"PARA_SYSTEM-V0");
  143.
  144.
  145.                 OLED_ShowCHinese(0,2,0);   //当
  146.                 OLED_ShowCHinese(16,2,1);  //前
  147.                 OLED_ShowCHinese(32,2,2);  //温
  148.                 OLED_ShowCHinese(48,2,3);  //度
  149.                 OLED_P8x16Str(64,2,":");
  150.
  151.                 //当温度为负数的时候,显示-号
  152.           if(wendu==1)
  153.                 {
  154.                  OLED_P8x16Str(72,2,"-");
  155.
  156.                 }
  157.                 else
  158.                 {
  159.                          OLED_P8x16Str(72,2," ");
  160.                 }
  161.
  162.
  163.                 sprintf(bai,"%d",Display_Digit[1]);
  164.     OLED_P8x16Str(80,2,bai);
  165.           sprintf(shi,"%d",Display_Digit[2]);
  166.     OLED_P8x16Str(88,2,shi);
  167.                 OLED_P8x16Str(96,2,".");
  168.                 sprintf(ge,"%d",Display_Digit[3]);
  169.     OLED_P8x16Str(104,2,ge);
  170.
  171.
  172.
  173.                 OLED_ShowCHinese(0,4,4);   //时
  174.                 OLED_ShowCHinese(16,4,5);  //间
  175.                 OLED_P8x16Str(32,4,":");
  176.
  177.
  178.
  179.
  180.                 sprintf(h1,"%d",hour1);
  181.     OLED_P8x16Str(40,4,h1);
  182.                 sprintf(h0,"%d",hour0);
  183.     OLED_P8x16Str(48,4,h0);
  184.
  185.                 if(flag==1)
  186.                 {
  187.                         OLED_P8x16Str(56,4,":");
  188.                 }
  189.                 else
  190.                 {
  191.                         OLED_P8x16Str(56,4," ");
  192.                 }
  193.
  194.                 sprintf(m1,"%d",min1);
  195.     OLED_P8x16Str(64,4,m1);
  196.                 sprintf(m0,"%d",min0);
  197.     OLED_P8x16Str(72,4,m0);
  198.
  199.                 if(flag==1)
  200.                 {
  201.                         OLED_P8x16Str(80,4,":");
  202.                 }
  203.                 else
  204.                 {
  205.                         OLED_P8x16Str(80,4," ");
  206.                 }
  207.
  208.                 sprintf(s1,"%d",second1);
  209.     OLED_P8x16Str(88,4,s1);
  210.                 sprintf(s0,"%d",second0);
  211.     OLED_P8x16Str(96,4,s0);
  212.
  213.
  214.
  215.
  216.                 Delay_ms(10);
  217.
  218.
  219.         }
  220.
  221.
  222.
  223. }
Sheet2.rar
4.48 KB, 下载次数: 65, 下载积分: 黑币 -5
layout示意图
48bfad32c2118735a4643e2c4bc11d34.rar
1.81 MB, 下载次数: 41, 下载积分: 黑币 -5
视频展示效果
app_测试.rar
77.09 KB, 下载次数: 167, 下载积分: 黑币 -5
程序
收藏收藏8 分享淘帖 顶1 踩
ID:648535 发表于 2019-11-28 10:44 | 只看该作者
这个函数的作用是什么啊?
ID:195752 发表于 2019-12-31 16:31 | 只看该作者
学习,正想显示温度
ID:605938 发表于 2020-3-16 21:46 | 只看该作者
请问12864的驱动程序是怎么写啊,能给我个例成和新手能够看懂的程序吗,谢谢
ID:125616 发表于 2020-7-20 23:23 | 只看该作者
OLED_P8x16Str  大神请问,这个函数是显示小数的吗
ID:401598 发表于 2020-7-22 08:06 | 只看该作者
DIY精神万岁!
ID:856401 发表于 2021-4-11 22:23 来自手机 | 只看该作者
这个是OLED显示字符串的,它第一行就是显示引号里面的字符串
ID:966104 发表于 2021-9-20 08:19 | 只看该作者
正想学习彩屏……。
