查看: 2351|回复: 1
单片机超声波循迹小车源代码(PWM版)程序错误 求帮助
ID:508291 发表于 2019-7-29 15:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Trig -------  P2^1;
Echo -------  P2^0;
VCC  -------- +5v
GND  -------- GND
请在上电之前,检查好接线是否正确。
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #include "lcd.h"
  4. sbit Trig = P2^1;
  5. sbit Echo = P2^0;
  6. sbit IN1 = P1^0;
  7. sbit IN2 = P1^1;
  8. sbit IN3 = P1^3;
  9. sbit IN4 = P1^4;
  10. sbit EN1 = P1^2;
  11. sbit EN2 = P1^5;
  12. unsigned char PuZh[]=" Pechin Science ";
  13. unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
  14. static unsigned char DisNum = 0; //显示用指针
  15.        unsigned int  time=0;
  16.            unsigned long S=0;
  17.            bit      flag =0;
  18.            unsigned char disbuff[4]           ={ 0,0,0,0,};
  19. /*******************************************************************************
  20. * 函 数 名         : main
  21. * 函数功能                   : 主函数
  22. * 输    入         : 无
  23. * 输    出         : 无
  24. *******************************************************************************/
  25. void delay(int In,int Out)
  26. {
  27. int i,j;
  28. for(i=0;i<In;i++)
  29. {
  30.   for(j=0;j<Out;j++)
  31.   {;}
  32. }
  33. }
  34. void forward(void)                                                 //前进
  35. {
  36.   EN1 = 1;
  37.         EN2 = 1;
  38.   IN1 = 1;
  39.   IN2 = 0;                                      //左车轮的正转
  40.   IN3 = 1;
  41.   IN4 = 0;
  42. }                                              //右车轮的正转
  43. void backward(void)                                                 //前进
  44. {
  45.         EN1 = 1;
  46.         EN2 = 1;
  47.   IN1 = 0;
  48.   IN2 = 1;         //左车轮的正转
  49.   IN3 = 0;
  50.   IN4 = 1;
  51. }                                              //右车轮的正转
  52. void stop(void)                                            //停车
  53. {
  54.           EN1 = 1;
  55.         EN2 = 1;
  56. IN1 = 0;
  57. IN2 = 0;                                       //左电机不动
  58. IN3 = 0;
  59. IN4 = 0;
  60. }
  61. void right(void)                                        //向右
  62. {
  63.   EN1 = 1;
  64.         EN2 = 1;
  65.   IN1 = 1;
  66.   IN2 = 0;                                     //智能小车左车轮正转
  67.
  68.   IN3 = 0;
  69.   IN4 = 1;                                     //智能小车右车轮反转
  70. }
  71.                  void Conut(void)
  72.         {
  73.          time=TH0*256+TL0;
  74.          TH0=0;
  75.          TL0=0;
  76.
  77.          S=(time*1.7)/100;     //算出来是CM
  78.          if((S>=700)||flag==1) //超出测量范围显示“-”
  79.          {
  80.           flag=0;
  81.
  82.           DisplayOneChar(0, 1, ASCII[11]);
  83.           DisplayOneChar(1, 1, ASCII[10]);        //显示点
  84.           DisplayOneChar(2, 1, ASCII[11]);
  85.           DisplayOneChar(3, 1, ASCII[11]);
  86.           DisplayOneChar(4, 1, ASCII[12]);        //显示M
  87.          }
  88.          else
  89.          {
  90.           disbuff[0]=S%1000/100;
  91.           disbuff[1]=S%1000%100/10;
  92.           disbuff[2]=S%1000%10 %10;
  93.           DisplayOneChar(0, 1, ASCII[disbuff[0]]);
  94.           DisplayOneChar(1, 1, ASCII[10]);        //显示点
  95.           DisplayOneChar(2, 1, ASCII[disbuff[1]]);
  96.           DisplayOneChar(3, 1, ASCII[disbuff[2]]);
  97.           DisplayOneChar(4, 1, ASCII[12]);        //显示M
  98.          }
  99. }
  100.         void gogogo()
  101.         {
  102.                           if(S>35&&S<1000)
  103.                                 {
  104.                 backward();
  105.        delay(200,200);
  106.                 stop();
  107.                                 }
  108.
  109.      else if(S<35&&S>=15)
  110.         {
  111.            right();
  112.                                         delay(200,200);
  113.                                         stop();
  114.         }
  115.                                    else if(S<15&&S>10)
  116.        {
  117.        forward();
  118.        delay(200,200);
  119.        stop();
  120.        }
  121.
  122.        else
  123.        {
  124.        stop();
  125.        }
  126.         }
  127. void zd0() interrupt 1                  //T0中断用来计数器溢出,超过测距范围
  128.   {
  129.     flag=1;                                                         //中断溢出标志
  130.   }
  131. void  StartModule()                          //启动模块
  132.   {
  133.           Trig=1;                                             //启动一次模块
  134.           _nop_();
  135.           _nop_();
  136.           _nop_();
  137.           _nop_();
  138.           _nop_();
  139.           _nop_();
  140.           _nop_();
  141.           _nop_();
  142.           _nop_();
  143.           _nop_();
  144.           _nop_();
  145.           _nop_();
  146.           _nop_();
  147.           _nop_();
  148.           _nop_();
  149.           _nop_();
  150.           _nop_();
  151.           _nop_();
  152.           _nop_();
  153.           _nop_();
  154.           _nop_();
  155.           Trig=0;
  156.   }
  157. void delayms(unsigned int ms)
  158. {
  159.         unsigned char i=100,j;
  160.         for(;ms;ms--)
  161.         {
  162.                 while(--i)
  163.                 {
  164.                         j=10;
  165.                         while(--j);
  166.                 }
  167.         }
  168. }
  169. void main(void)
  170. {
  171.          TMOD=0x01;                   //设T0为方式1,GATE=1;
  172.          TH0=0;
  173.          TL0=0;
  174.          ET0=1;             //允许T0中断
  175.          EA=1;                           //开启总中断
  176.         InitLcd1602();
  177.         LcdShowStr(0,0,PuZh);
  178.         while(1)
  179.         {
  180.                  StartModule();
  181.              while(!Echo);                //当RX为零时等待
  182.              TR0=1;                            //开启计数
  183.              while(Echo);                        //当RX为1计数并等待
  184.              TR0=0;                                //关闭计数
  185.          Conut();                        //计算
  186.                 delayms(80);
  187.                 gogogo();
  188.                  delayms(80);
  189.                  delayms(80);
  190.
  191.         }
  192.
  193. }
  194. void zd0() interrupt 3                  //T0中断用来计数器溢出,超过测距范围
  195.   {
  196.
  197.
  198.   }
超声波循迹小车(PWM版).7z (20.35 KB, 下载次数: 16)
收藏收藏1 分享淘帖 顶顶 踩踩
ID:927341 发表于 2021-7-28 14:18 | 只看该作者
程序错误
