查看: 100|回复: 0
单片机外部中断0的应用
ID:591424 发表于 2019-7-30 22:52 | 显示全部楼层 |阅读模式
实验功能:外部中断0,当P3^2有低电平进入外部中断0LED1被点亮
#include<reg51.h>
#define uint unsigned int
sbit duan=P2^6;
sbit wei=P2^7;
sbit led1=P1^0;
uchar num;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint);
EA=1;//开总中断
EX0=1;//外部中断0允许位
IT0=0;//电平触发
wei=1;
P0=0xc0;
wei=0;
  for(num=0;num<16;num++)
  duan=1;
  P0=table[num];
  duan=0;
  delay(500);//0.5s
void delay(uint a)
uint i,j;
for(i=a;i>0;i--)
  for(j=110;j>0;j--);
void exter0() interrupt 0
  led1=0;
