查看: 1952|回复: 1
ADXL335+超声波 LCD显示
ID:521503 发表于 2019-8-3 09:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "usart.h"
#include "timer.h"
#include "LCD_Display.h"
#include "dht11.h"
#include "ADC.h"
#include  <math.h>
extern u8  TIM2CH2_CAPTURE_STA;                //输入捕获状态
extern u16        TIM2CH2_CAPTURE_VAL;
extern u8 time;
int main(void)
        u8 temperature = 0;
        u8  humidity = 0;
        u8 ch_Ultrasonic[15]=" ";       //转换显示数组
        u8 ch_Temperature[15]=" ";
        u8 ch_Humidity[15]=" ";
        u8 ch_Roll[15]=" ";
        u8 ch_Pitch[15]=" ";
        u8 ch_Yaw[15]=" ";
        float Roll = 0;            //ADXL三个参数
        float Pitch = 0;
        float Yaw = 0;
  float Ultrasonic_Data=0;
        float X = 0;
        float Y = 0;
        float Z = 0;
        delay_init();
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        uart_init(115200);
         LED_Init();
  DHT11_Init();
        ADC1_MultiChannel_Configuration();
         //TIM3_PWM_Init(899,0);
         TIM2_Cap_Init(0XFFFF,72-1);
        TIM3_Int_Init(5000,71);
        Stm32_Clock_Init();
        STM3210F_LCD_Init();
        LCD_Clear(White);
                 delay_ms(10);
                LCD_SetTextColor(Black);
                LCD_DisplayStringLine(Line1,ch_Ultrasonic);
    LCD_DisplayStringLine(Line2,ch_Temperature);
                LCD_DisplayStringLine(Line3,ch_Humidity);
                Roll = Read_ADC1_MultiChannel(12);
                Pitch = Read_ADC1_MultiChannel(13);
                Yaw = Read_ADC1_MultiChannel(15);
    //Roll=(float)(((atan2(Y,X)*180)/3.14159265)+180);
                sprintf(ch_Roll,"X = %.3lf",Roll);
                LCD_DisplayStringLine(Line4,ch_Roll);
//Pitch=(float)(((atan2(Y,Z)*180)/3.14159265)+180);
                sprintf(ch_Pitch,"Y = %.3lf ",Pitch);
                LCD_DisplayStringLine(Line5,ch_Pitch);
//Yaw=(float)(((atan2(X,Z)*180)/3.14159265)+180);
                sprintf(ch_Yaw,"Z = %.3lf",Yaw);
                LCD_DisplayStringLine(Line6,ch_Yaw);
                 if(TIM2CH2_CAPTURE_STA&0X80)
                        Ultrasonic_Data=TIM2CH2_CAPTURE_STA&0X3F;
                        Ultrasonic_Data*=65536;
                        Ultrasonic_Data+=TIM2CH2_CAPTURE_VAL;
                        Ultrasonic_Data=170*Ultrasonic_Data*1.0/10000;
                        TIM2CH2_CAPTURE_STA=0;
                if(time%5 == 0)
                        UltrasonicWave_StartMeasure();
                if(time%10 == 0)
                        DHT11_Read_Data(&temperature,&humidity);
                        time = 0;
                //printf("%.2lf\r\n",temp);//′òó¡×üμĸßμãÆ½ê±¼ä
                sprintf(ch_Ultrasonic,"U = %.2lf cm",Ultrasonic_Data);
                sprintf(ch_Temperature,"T = %d ",temperature);
                sprintf(ch_Humidity,"H = %d%%",humidity);
ADXL-335.7z
225.68 KB, 下载次数: 11, 下载积分: 黑币 -5
源程序
ID:1 发表于 2019-8-3 15:01 | 只看该作者
