查看: 3492|回复: 1
ADC0832 ADC0809转换的两种模块的单片机程序+电路
ID:570564 发表于 2019-8-6 10:03 | 显示全部楼层 |阅读模式
AD转换的两种模块程序
AD转换
AD转换
AD转换
AD转换
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned int
  5. #define delay4us() {_nop_();_nop_();_nop_();_nop_();}
  6. sbit RS = P2^0;
  7. sbit RW = P2^1;
  8. sbit E  = P2^2;
  9. sbit CS  = P1^0;
  10. sbit CLK = P1^1;
  11. sbit DIO = P1^2;
  12. uchar Display_Buffer[] = "0.00D";
  13. uchar code Line1[] = "Jiao Du:";
  14. void DelayMS(uint ms)
  15. {
  16.          uchar i;
  17.         while(ms--)
  18.         {
  19.                  for(i=0;i<120;i++);
  20.         }
  21. }
  22. bit LCD_Busy_Check()
  23. {
  24.          bit result;
  25.         RS = 0;
  26.         RW = 1;
  27.         E  = 1;
  28.         delay4us();
  29.         result = (bit)(P0&0x80);
  30.         E  = 0;
  31.         return result;
  32. }
  33. void LCD_Write_Command(uchar cmd)
  34. {
  35.          while(LCD_Busy_Check());
  36.         RS = 0;
  37.         RW = 0;
  38.         E  = 0;
  39.         _nop_();
  40.         _nop_();
  41.         P0 = cmd;
  42.         delay4us();
  43.         E = 1;
  44.         delay4us();
  45.         E = 0;
  46. }
  47. void Set_Disp_Pos(uchar pos)
  48. {
  49.          LCD_Write_Command(pos | 0x80);
  50. }
  51. void LCD_Write_Data(uchar dat)
  52. {
  53.          while(LCD_Busy_Check());
  54.         RS = 1;
  55.         RW = 0;
  56.         E  = 0;
  57.         P0 = dat;
  58.         delay4us();
  59.         E = 1;
  60.         delay4us();
  61.         E = 0;
  62. }
  63. void LCD_Initialise()
  64. {
  65.         LCD_Write_Command(0x38); DelayMS(1);
  66.         LCD_Write_Command(0x0c); DelayMS(1);
  67.         LCD_Write_Command(0x06); DelayMS(1);
  68.         LCD_Write_Command(0x01); DelayMS(1);
  69. }
  70. uchar Get_AD_Result()
  71. {
  72.          uchar i,dat1=0,dat2=0;
  73.         CS  = 0;
  74.         CLK = 0;
  75.         DIO = 1; _nop_(); _nop_();
  76.         CLK = 1; _nop_(); _nop_();
  77.         CLK = 0;DIO = 1; _nop_(); _nop_();
  78.         CLK = 1; _nop_(); _nop_();
  79.         CLK = 0;DIO = 1; _nop_(); _nop_();
  80.         CLK = 1;DIO = 1; _nop_(); _nop_();
  81.         CLK = 0;DIO = 1; _nop_(); _nop_();
  82.         for(i=0;i<8;i++)
  83.         {
  84.                  CLK = 1; _nop_(); _nop_();
  85.                 CLK = 0; _nop_(); _nop_();
  86.                 dat1 = dat1 << 1 | DIO;
  87.         }
  88.         for(i=0;i<8;i++)
  89.         {
  90.                  dat2 = dat2 << ((uchar)(DIO)<<i);
  91.                 CLK = 1; _nop_(); _nop_();
  92.                 CLK = 0; _nop_(); _nop_();
  93.         }
  94.         CS = 1;
  95.         return (dat1 == dat2) ? dat1:0;
  96. }
  97. void main()
  98. {
  99.          uchar i;
  100.         uint d;
  101.         LCD_Initialise();
  102.         DelayMS(10);
  103.         while(1)
  104.         {
  105.                  d = Get_AD_Result()*500.0/254;
  106.                 Display_Buffer[0]=d/100+'0';
  107.                 Display_Buffer[2]=d/10%10+'0';
  108.                 Display_Buffer[3]=d%10+'0';
  109.                 Set_Disp_Pos(0x01);
  110.                 i = 0;
  111.                 while(Line1[i]!='\0')
  112.                 {
  113.                          LCD_Write_Data(Line1[i+1]);
  114.                 }
  115.                 Set_Disp_Pos(0x46);
  116.                 i = 0;
  117.                 while(Display_Buffer[i]!='\0')
  118.                 {
  119.                          LCD_Write_Data(Display_Buffer[i+1]);
  120.                 }
  121.         }
  122. }
ADC0832模数转换与显示.rar (49.82 KB, 下载次数: 36)
ID:528984 发表于 2019-8-8 12:20 | 显示全部楼层
请问为什么我照着图二的仿真连线,然后下载完程序运行时出现 No model specified for U3 。是什么原因呢?
