查看: 4530|回复: 3
51单片机38译码器16*16LED点阵显示源程序+原理图等资料
可以流动显示汉字,里面有视频讲解怎样使用取字软件,所以文件有点的大。
制作出来的实物图如下:
电路原理图如下:
#include<reg51.h>
#include<intrins.h>
#define uint unsigned int
#define data1 P0
#define data2 P2
sbit s1=P3^6;
sbit s2=P3^7;
bit fangxiang;
uint alt=0,net=0,sl=288;
bit mode;
uchar code tab[]={
//  (0)  (1) 老(2) 师(3) ,(4) 你(5) 辛(6) 苦(7) 了(8) !
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
0x02,0x10,0x22,0x10,0x22,0x20,0x22,0x20,0x22,0x40,0x22,0x7C,0xFE,0x92,0x23,0x12,
0x23,0x22,0x22,0x22,0x26,0x42,0x2A,0x42,0x72,0x02,0x22,0x0E,0x02,0x00,0x00,0x00,/*"老",2*/
0x00,0x02,0x3F,0xE4,0x00,0x08,0x00,0x70,0xFF,0x80,0x00,0x00,0x4F,0xF0,0x48,0x00,
0x48,0x00,0x48,0x00,0x7F,0xFF,0x48,0x00,0x48,0x20,0x48,0x10,0x4F,0xE0,0x00,0x00,/*"师",3*/
0x00,0x00,0x00,0x00,0x00,0x1A,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*",",4*/
0x01,0x00,0x02,0x04,0x0C,0x1C,0x3F,0xC0,0xC0,0x1C,0x09,0x02,0x16,0x02,0x60,0x92,
0x20,0x4A,0x2F,0x82,0x20,0x02,0x24,0x0E,0x22,0x00,0x31,0x90,0x20,0x0C,0x00,0x00,/*"您",5*/
0x01,0x00,0x21,0x20,0x21,0x20,0x29,0x20,0x25,0x20,0x23,0x20,0xA1,0x20,0x61,0xFF,
0x21,0x20,0x23,0x20,0x25,0x20,0x29,0x20,0x21,0x20,0x21,0x00,0x01,0x00,0x00,0x00,/*"辛",6*/
0x02,0x00,0x22,0x00,0x22,0x00,0x22,0x7E,0x22,0x44,0xFA,0x44,0x22,0x44,0x2F,0xC4,
0x22,0x44,0x22,0x44,0xFA,0x44,0x22,0x7E,0x22,0x00,0x22,0x00,0x22,0x00,0x00,0x00,/*"苦",7*/
0x00,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x02,0x40,0x01,0x4F,0xFE,
0x48,0x00,0x50,0x00,0x50,0x00,0x60,0x00,0x60,0x00,0x40,0x00,0x00,0x00,0x00,0x00,/*"了",8*/
0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFA,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",14*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",15*/
};void delay(uint z)           //延时子函数{
   uchar x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void xianshi()                        //显示
        uchar aa,i;
        for(i=0;i<16;i++)
                P1=i; //列扫描
                data1=tab[net+aa]; //取出上8行数据输出
                aa++;
                data2=tab[net+aa]; //取出下8行数据输出
                aa++;
                delay(5);        //延时
                data1=0;  //清屏
                data2=0;  //清屏
                P1=0x00;  //消除余辉
                if(aa>30) aa=0;  //字模地址
void main()         //主函数
   ET1=1;         //使能定时器0
   EA=1;         //开启总中断
   TR1=1;        //开始计数
   while(1)         //无限循环
           xianshi();  //显示
           if(s1==0)   //检测按键
              delay(30);  //延时消抖
                  TR1=~TR1;          //按下暂停  ,暂按继续
                  while(!s1)xianshi();
                  delay(30);
           if(s2==0)        //检测按键
               delay(30);                        //延时消抖
                   fangxiang=~fangxiang;  //方向取反
                   while(!s2)xianshi();
                   delay(30);
红色部分是你取的字的代码,这是部分程序。
全部资料51hei下载地址:
138LED点阵.7z (17.25 MB, 下载次数: 102)
收藏收藏6 分享淘帖 顶 踩
ID:997397 发表于 2022-1-5 14:25 来自手机 | 只看该作者
大佬有没有可以用按键切换显示程序的呀
ID:1012795 发表于 2022-3-24 16:44 | 只看该作者
这个只能用按键来搞么 直接仿真的能不能用
ID:1026001 发表于 2022-7-5 20:26 | 只看该作者
很好很详细,如果点阵屏增长该如何修改。
