#include<reg51.h>
#include<intrins.h>
#define uint unsigned int
#define out P0
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
void lcd_initial();
void check_busy();
void write_command(uchar com);
void write_data(uchar dat);
void string(uchar ad,uchar *s);
void delay(uint);
lcd_initial();
string(0x85,"WLECOME");
string(0xC2,"Harbin CHINA");
delay(100);
write_command(0x01);
delay(100);
void delay(uint j)
uchar i=250;
for(;j>0;j--)
while(--i);
i=249;
while(--i);
i=250;
void check_busy()
uchar dt;
do
dt=0xff;
E=0;
RS=0;
RW=1;
E=1;
dt=out;
}while(dt&0x80);
E=0;
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_();
E=0;
delay(1);
check_busy();
E=0;
RS=1;
RW=0;
out=dat;
E=1;
_nop_();
E=0;
delay(1);
void lcd_initial()
write_command(0x38);
write_command(0x0C);
write_command(0x06);
delay(1);
write_command(ad);
while(*s>0)
write_data(*s++);
delay(100);
(71.01 KB, 下载次数: 18)
LCD.zip
108.97 KB, 下载次数: 50, 下载积分: 黑币 -5
