查看: 1817|回复: 0
stm8s单片机 SPI驱动一直卡住 调不出来 求助
ID:610433 发表于 2019-10-14 17:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下是我的AD7193 spi主机模式驱动(stm8s)
一直停在RDY口,就是MISO复用,一直不拉低,死循环
我怀疑是spi读写没写好,还有就是spi硬件调试的时候,gpio口需要设置嘛?
求看一看,找出原因
#define MISO_STATE             GPIO_ReadInputPin(GPIOC, GPIO_PIN_7)
#define PMOD1_CS_LOW           GPIO_WriteLow(GPIOE, GPIO_PIN_5)
#define PMOD1_CS_HIGH          GPIO_WriteHigh(GPIOE, GPIO_PIN_5)
unsigned char SPI_Init7193(unsigned char lsbFirst, unsigned long clockFreq, unsigned char clockPol, unsigned char clockEdg)
  SPI_DeInit();
  SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_16, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_HIGH, SPI_CLOCKPHASE_1EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_SOFT, 0x07);
  SPI_Cmd(ENABLE);
  GPIO_Init(GPIOE, GPIO_PIN_5, GPIO_MODE_OUT_PP_LOW_FAST);     //SPI CS/NSS
  GPIO_WriteLow(GPIOE, GPIO_PIN_5);
  return 1;
unsigned char SPI_Write7193(unsigned char slaveDeviceId, unsigned char* data, unsigned char n)
   unsigned char byte = 0;
   unsigned char read = 0;
   for(byte = 0;byte < n;byte++)
     while(SPI_SR_TXE==0);
     SPI_SendData(data[byte]);
     while(SPI_SR_RXNE==0);
     read = SPI_ReceiveData();
   return n;
unsigned char SPI_Read7193(unsigned char slaveDeviceId, unsigned char* data, unsigned char n)
     data[byte] = SPI_ReceiveData();
   return n;
