查看: 1531|回复: 7
想让蜂鸣器唱歌,但现在我实在是不知道我定时器延时这块逻辑哪出问题了 求各位赐教
ID:442241 发表于 2019-10-18 00:10 | 显示全部楼层 |阅读模式
想让蜂鸣器唱歌,但现在我实在是不知道我逻辑在哪出问题了,感觉是定时器这块 求各位赐教
  1. #include<reg52.h>
  2. sbit sound=P1^5;
  3. unsigned int p, k,j,z;unsigned        int c=0;
  4. unsigned int f=0;
  5. unsigned int sound_high;unsigned int sound_low;
  6. unsigned int pace;
  7. unsigned char code MUSICHIGH[3][8]={{0xff,0xf9,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc},//di
  8.                          {0xff,0xfc,0xfc,0xfd,0xfd,0xfd,0xfd,0xfe},
  9.                          {0xff,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xff}
  10.                                     };//三个音阶高电位
  11. unsigned char code MUSICLOW[3][8]={{0xff,0x21,0xe1,0x8c,0xd8,0x68,0xe9,0x5b},
  12.                         {0xff,0x8f,0xef,0x45,0x6c,0xb4,0xf4,0x2e},
  13.                          {0xff,0x47,0x78,0xa2,0xb6,0xda,0xfa,0x17}};//三个音阶低电位
  14. unsigned char code MUSIC[]={1,1,1,  1,1,1,  1,1,2,  5,0,2,
  15.                     3,1,1,  3,1,1,  3,1,2,  1,1,2,
  16.                     1,1,1,  3,1,1,  5,1,2,  5,1,2,  4,1,1,  3,1,1,  2,1,4,
  17.                     2,1,1,  3,1,1,  4,1,2,  4,1,2,  3,1,1,  2,1,1,  3,1,2,
  18.                         1,1,2,  1,1,1,  3,1,1,  2,1,2,
  19.                     5,0,2,  7,0,1,  2,1,1,  1,1,3, 9 };//音符,音阶,节拍
  20. void init()
  21. {
  22.           TMOD=0x11; //开两定时器
  23.         TH0=0Xd8;
  24.     TL0=0Xf0;
  25.         EA=1;
  26.         ET0=1;
  27. }
  28. void timer0() interrupt 1//节拍
  29. {
  30. TH0=0Xd8;
  31. TL0=0Xf0;
  32. pace--;
  33. }
  34. void delay(unsigned char x)//延迟毫秒
  35. {
  36.         unsigned int i,h;
  37.         for(i=x;i>0;i--)
  38.         for(h=120;h>0;h--)
  39.         ;
  40. }
  41. void sound_delay(unsigned int sound_high,unsigned int sound_low)//产生音调
  42. {
  43.         TH1=sound_high;
  44.         TL1=sound_low;
  45.         TR1=1;
  46.         while(TF1==0);
  47.         TR1=0;
  48.         TF1=0;
  49. }
  50.         void main()
  51.         {
  52.
  53.                 c=0;
  54.                 init();
  55.                 play:
  56.                 while(1);
  57.    {
  58.          p=MUSIC[c];
  59.                 if(p==9)
  60.                 { c=0, delay(1000); goto play;}
  61.
  62. else
  63.         {
  64.         j=MUSIC[c++];
  65.           k=MUSIC[c++];//取音符和音高
  66.            sound_high=MUSICHIGH[k][j];
  67.          sound_low=MUSICLOW[k][j];//高低电位取数值
  68.         pace=40*MUSIC[c++];
  69.                         TR0=1;
  70.         }
  71.
  72.                          while(pace!=0)
  73.                          {
  74.                                  sound=~sound;
  75.                                  sound_delay(sound_high,sound_low);
  76.                                TR0=0;
  77.                          }
  78.                  }
  79.          }
  80.
  81.
ID:235200 发表于 2019-10-18 01:28 | 显示全部楼层
程序中判断P是否为9,为9则跳出循环,转移到PLAY,我复制你的程序编译后发现while(1)循环根本不没有产生执行代码,因而也就播放不出音乐
ID:442241 发表于 2019-10-18 09:24 来自手机 | 显示全部楼层
csmyldl 发表于 2019-10-18 01:28
程序中判断P是否为9,为9则跳出循环,转移到PLAY,我复制你的程序编译后发现while(1)循环根本不没有产生执行代 ...
非常感谢,我试着改了一下,错误了,能麻烦您教一下怎么改吗
ID:275826 发表于 2019-10-18 10:40 | 显示全部楼层
while(1);把逗号去掉
ID:442241 发表于 2019-10-18 12:26 来自手机 | 显示全部楼层
tyrl800 发表于 2019-10-18 10:40
while(1);把逗号去掉
谢谢谢谢,真的非常感谢,这程序我改了好多天了硬是没发现
ID:442241 发表于 2019-10-18 13:06 来自手机 | 显示全部楼层
while(1);把逗号去掉
能顺便帮忙看下为啥循环转不起来吗,麻烦了
ID:442241 发表于 2019-10-18 13:19 来自手机 | 显示全部楼层
while(1);把逗号去掉
整出来了,谢谢
ID:275826 发表于 2019-10-18 14:50 | 显示全部楼层
yixia 发表于 2019-10-18 13:19
整出来了,谢谢
程序里尽量不要用GOTO 语句
