使用内部flash保存数据,不知道楼主是使用的什么单片机,但是如果使用stc89c52rc 或者是STM32F103c8t6这两个都是可以的,不需要外加什么东西,代码就可以实现.
51如下
sfr ISP_DATA = 0xe2;
sfr ISP_ADDRH = 0xe3;
sfr ISP_ADDRL = 0xe4;
sfr ISP_CMD = 0xe5;
sfr ISP_TRIG = 0xe6;
sfr ISP_CONTR = 0xe7;
/*--------------------空停顿--------------------*/
void Nop(){}
/*--------------------开ISP,IAP--------------------*/
void ISP_IAP_enable()
//EA = 0;
ISP_CONTR = ISP_CONTR & 0x18;
ISP_CONTR = ISP_CONTR | 0x01;
ISP_CONTR = ISP_CONTR | 0x80;
/*--------------------关ISP,IAP--------------------*/
void ISP_IAP_disable()
ISP_CONTR = ISP_CONTR & 0x7F;
ISP_TRIG = 0x00;
//EA = 1;
/*--------------------触发代码--------------------*/
void ISPgoon()
ISP_IAP_enable();
ISP_TRIG = 0x46;
ISP_TRIG = 0xB9;
Nop();
/*--------------------扇区擦除--------------------*/
void ISP_erase(uchar sector) //扇区号(0~7)
ISP_ADDRL = 0;
ISP_ADDRH = (8192 + 512*(uint)sector)>>8;
ISP_CMD = ISP_CMD & 0xF8;
ISP_CMD = ISP_CMD | 0x03;
ISPgoon();
ISP_IAP_disable();
/*--------------------字节写(强制操作)--------------------*/ //必须确认,目标区域的bin值已置11111111,否则在写入前应先擦除该扇区
void ISP_write(uchar sector,uint offset,uchar ByteData) //扇区号(0~7),地址偏移量(0~511),8位数据
offset = 8192 + 512*(uint)sector + offset;
ISP_ADDRL = offset;
ISP_ADDRH = offset>>8;
ISP_CMD = ISP_CMD | 0x02;
ISP_DATA = ByteData;
ISPgoon();
ISP_IAP_disable();
/*--------------------字节读(强制操作)--------------------*/
uchar ISP_read(uchar sector,uint offset) //扇区号(0~7) ,地址偏移量(0~511)
ISP_ADDRL = offset;
ISP_CMD = ISP_CMD | 0x01;
ISPgoon();
ISP_IAP_disable();
return (ISP_DATA);
/*--------------------空白地址定位--------------------*/
uint ISP_locat(uchar sector) //扇区号0~7
uint offset;
for(offset=0;offset<512&&ISP_read(sector,offset)!=255;offset++);
return (offset); //返回512说明扇区已满
/*--------------------整型写(自动管理扇区空间)--------------------*/
void ISP_UintWrite(uchar sector,uint UintData) //扇区号(0~7),16位数据(0~65534,系统定义65535为空)
uint offset;
offset=ISP_locat(sector); //低位
if(offset==512) //扇区已满
ISP_erase(sector); //擦除扇区
offset=0;
ISP_write(sector,offset,UintData);
ISP_write(sector,offset+1,UintData>>8);
/*--------------------整型读(自动管理扇区空间)--------------------*/
uint ISP_UintRead(uchar sector) //扇区号(0~7)
uint offset;
offset=ISP_locat(sector); //比高字节大1
if(offset<2) //这种情况说明整个扇区是空的
offset=2; //取第扇区上2个地址,即将第1和第0个地址位作为读取区,防止报错
return (((uint)ISP_read(sector,offset-1)<<8)+ISP_read(sector,offset-2));
对于STM32F103我就上传到附件了
希望能帮到你吧 |
