希望可以帮助你们
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define C1 0.045
- uchar code WenDu1[]="数\xfd字万用表 ";
- uchar code WenDu2[]="欢迎使用 ";
- uchar code code_L[]="电感: ";
- uchar code code_R[]="电阻: ";
- uchar code code_C[]="电容: ";
- uchar code code_e[]="错误: ";
- uchar num;
- sbit key1 =P1^0;
- sbit key2 =P1^1;
- sbit key3 =P1^2;
- //unsigned long LZ=0;
- //float f=0;
- float LZ=0;
- float RX=0;
- float CX=0;
- float f=0;
- float temp_f[4];
- unsigned int tt,th1,tl1;
- unsigned int pluse=0;
- bit flag=0;
- unsigned char key_num=0;
- #define L 1
- #define R 2
- #define C 3
- sbit aa1 =P2^0;
- sbit bb1 =P2^1;
- #include<Lcd12864.h>
- void cd4051(unsigned char num)
- switch(num){
- case 1: bb1=0;aa1=0;break;
- case 2: bb1=0;aa1=1; break;
- case 3: bb1=1;aa1=0; break;
- default : aa1=1;aa1=1;break;
- void scan_key()
- if(!key1){
- if(!key1){
- while(!key1);
- key_num=1;
- cd4051(L);
- // aa1=0;bb1=0;
- Lcd_ShowSring(4,0,code_L);
- Lcd_ShowSring(1,15,"L");
- if(!key2){
- if(!key2){
- while(!key2);
- key_num=2;
- cd4051(R);
- //aa1=0;bb1=1;
- Lcd_ShowSring(4,0,code_R);
- Lcd_ShowSring(1,15,"R");
- if(!key3){
- if(!key3){
- while(!key3);
- key_num=3;
- cd4051(C);
- //aa1=1;bb1=0;
- Lcd_ShowSring(4,0,code_C);
- Lcd_ShowSring(1,15,"C");
- //中断初始化
- void init()
- // TMOD=0x11; //定时器0和定时器1都是方式1,16位定时器
- //定时器设置
- TMOD=0x51; //设置定时器0,方式1:16位定时器
- TH1=0x00; //定时器1高位装初值
- TL1=0x00; //定时器1低位装初值
- ET1=1; //定时器1 使能位
- TH0=(65535-50000)/255; //定时器1高位装初值
- TL0=(65535-50000)%255;; //定时器1高位装初值
- ET0=1; ////定时器0 使能位
- TR0=1;
- TR1=1;
- EA=1;// 总中断
- void Measurement_L();//电感测量
- void Measurement_R();//电阻测量
- void Measurement_C();//电容测量
- unsigned char gather_num=0;
- unsigned char m_second=0;
- void main ()
- LCDInit();
- Lcd_ShowSring(1,0,WenDu1);
- Lcd_ShowSring(2,0,WenDu2);
- // Lcd_ShowSring(4,0,code_R);
- init();
- // cd4051(R);
- // key_num=2;
- while(1){
- scan_key();
- if(flag){
- flag=0;
- //在十ms里面记了这么多个脉冲
- // 那么一个脉冲的周期就是 50ms/tt/1000 (s) 化简得到 f 20tt
- if(gather_num<4) {
- temp_f[gather_num]=pluse*65536+256*TH1+TL1; //1000000000000 12 100000000 8
- gather_num++;
- else{
- gather_num=0;
- f=(temp_f[0]+temp_f[1]+temp_f[2]+temp_f[3])/4.0;
- // Lcd_Display(3,0,f);
- switch(key_num) {
- case 1:Measurement_L(); break;
- case 2:Measurement_R(); break;
- case 3:Measurement_C(); break;
- default :break;
- TH1=0; //清零开始重新计数
- TL1=0;
- pluse=0;
- TR0=1;//开定时器计时10ms;//使能位外部中断0 数10内有多少个脉冲
- TR1=1;//进行新一轮的计数
- m_second=0;
- // num++;
- // Lcd_Display(4,4,num);
- void time0()interrupt 1 //定时器0 服务
- // TR1=0;//关掉定时器1
- // TH0=(65535-50000)/255; //定时器1高位装初值
- // TL0=(65535-50000)%255;; //定时器1高位装初值 */
- TH0=60; //定时器1高位装初值
- TL0=235;; //定时器1高位装初值
- m_second++;
- if(m_second==20){
- TR1=0;//关掉定时器1
- TR0=0; // 关掉定时器0
- m_second=0;
- flag=1;
- void time1()interrupt 3 //定时器1 服务
- pluse++;
- TH1=0;
- TL1=0;
- if(f==0){
- LZ=0;
- else {
- LZ=5.63466627*10e10/f/f;
- LZ=LZ/1.0727272727272727272727272727273;
- Lcd_ShowSring(4,0,"电感:");
- Lcd_Display_u(4,4,LZ);
- if(LZ>99999999) {
- // Lcd_ShowSring(4,0,code_e);
- void Measurement_R()//电阻测量
- if(f==0){
- RX=0;
- else if( 0< f&& f<30) { //1M 7
- RX= 14400000.0/f;
- RX= RX-3000;
- RX =RX/2/0.95; //修正
- else if(f <700) { //10k 650
- RX= 14400000.0/f;
- RX= RX-3000;
- else if(f <1500) { //4.7k 1209
- RX= 14400000.0/f;
- RX= RX-3000;
- RX =RX/2/0.94; //修正
- else if(f <3000) { //1k 2983
- RX= 14400000.0/f;
- RX= RX-3000;
- RX =RX/2/0.91; //修正
- //0.91286863270777479892761394101877
- else if(f <4500) {
- RX= 14400000.0/f;
- RX= RX-3000;
- //修正 200 4372
- RX =RX/2/0.74; //修正
- else if(f <5000) {
- RX= 14400000.0/f;
- RX= RX-3000;
- //修正 100
- RX =RX/2/0.50; //修正
- if(RX==0){
- } else{
- Lcd_ShowSring(4,0,"电阻:");
- Value_to_ASCII1(4,3, RX);
- if(RX>99999999) {
- void Measurement_C()//C测量
- if(f==0){
- CX=0;
- else if(f>5000){
- CX=0;
- else {
- CX=48100.00/f/1.0276595744680851063829787234043;//修正
- Lcd_ShowSring(4,0,"电容:");
- Value_to_ASCIIC(4,3,CX);
- // Lcd_ShowSring(4,0,"电容:");
- // Value_to_ASCIIC(4,3,CX);
- if(CX>99999999) {
程序.7z
(1.16 MB, 下载次数: 145)
