查看: 2376|回复: 0
pid循迹小车 为什么我程序在主函数里只运行了一次,当传感器再次检测到时没反应
ID:500189 发表于 2019-12-23 20:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为什么我程序在主函数里只运行了一次,当传感器再次检测到时,没有任何反应      灰度传感器的位置是  前排 5个构成了一排
以下是主函数和pid程序
int main(void)
    delay_init(168);  //初始化延时函数
    uart_init(115200);//初始化串口波特率为115200
    TIM3_PWM_Init(999,84-1);      //   PWM频率=72M/((2*(arr+1)*(psc+1))
    EXTIX_Init();              //分频系数 84 / 84 =1Mhz    1Mhz/1000=1Khz。
  motor_init();
        //read_sensor_value_1();
        read_sensor_value_2();
        calc_pid();
        motor_control();
void read_sensor_value_2()
        if(PDin(8) == 1)
       error=2;
        else if(PDin(9) == 1)
      error=1;
        else if(PDin(10) == 1)
     forward_min();
        else if(PDin(11) == 1)
       error=-1;
        else if (PDin(12) == 1)
       error=-2;
        else if ((PDin(12) == 0)|(PDin(11) == 0)|(PDin(10) == 0)|(PDin(9) == 0)|(PDin(8) == 0))
            if(error==-2)
                error=-3;
                error=3;
        //return 0;
float P=0,I=0,D=0,PID_value=0;
float previous_error = 0, previous_I = 0;     //误差值
float Kp=50,Ki=0,Kd=0;
void calc_pid()
    P=error;
    I=I+error;
    D=error-previous_error;
    PID_value = (Kp * P) + (Ki * I) + (Kd * D);
  previous_error = error;
static float initial_motor_speed = 0;          //初始速度
//限幅(-305,305)
void motor_control()
    float left_motor_speed  = initial_motor_speed - PID_value;
  float right_motor_speed = initial_motor_speed + PID_value;
//  if(left_motor_speed < -305){
//    left_motor_speed = -305;
//  if(left_motor_speed > 305){
//    left_motor_speed = 305;
//    if(right_motor_speed < -305){
//    right_motor_speed = -305;
//  if(right_motor_speed > 305){
//   right_motor_speed = 305;
    motorsWrite(left_motor_speed,right_motor_speed);
void motorsWrite(int speedL, int speedR)
  if (speedR > 0)
        TIM_SetCompare3(TIM3,350+speedR);    //B0
        TIM_SetCompare4(TIM3,0);      //   右正转
         TIM_SetCompare3(TIM4,360);    //B8
        TIM_SetCompare4(TIM4,0);    //B9
      TIM_SetCompare1(TIM3,360);    //A6
        TIM_SetCompare2(TIM3,0); //A7
  } else {
    TIM_SetCompare3(TIM3,0);    //B0
        TIM_SetCompare4(TIM3,350+abs(speedR));    //倒转
  if (speedL > 0)
        TIM_SetCompare1(TIM4,350+speedL);
        TIM_SetCompare2(TIM4,0);            //       左正转
  } else {
    TIM_SetCompare1(TIM4,0);
        TIM_SetCompare2(TIM4,350+abs(speedL));
