基于c51单片机,基本功能:按键调节模式,时间,电机转动,led显示,报警等功能
欢迎讨论
- #include<reg52.h>
- #include<intrins.h>
- #include<absacc.h>
- sbit m=P2^0;
- sbit time_set=P2^1;
- sbit mode=P2^2;
- sbit ma=P1^0;
- sbit mb=P1^1;
- sbit waterin=P1^3;
- sbit washing=P1^2;
- sbit waterout=P1^4;
- sbit finish=P1^5;
- sbit tuoshui=P1^6;
- sbit T_key=P1^7;
- sbit SPEAKER=P3^0;
- sbit LCD_E=P3^1;
- sbit Honggan=P3^4;
- sbit motor=P3^5;
- sbit LCD_RS=P3^6;
- sbit LCD_RW=P3^7;
- #define LCD_DB P0
- #define daport XBYTE[0x8000] // 0832地址 Y0
- #define uchar unsigned char
- #define uint unsinged int
- void LCD_init(void);
- void LCD_write_command(uchar command);
- void LCD_write_data(uchar dat);
- void LCD_disp_char(uchar x,uchar y,uchar dat);
- void delay_n40us(int n);
- int time[3]={0,0,0};
- int time1=0,t1,t2,t3;
- unsigned char pos[6]={0x01,0x02,0x08,0x10,0x40,0x80};
- unsigned char DSY_CODE[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
- unsigned char code work_order[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
- int count=0,time_wash=1,time_total=100,model=0,mo_shi=0;moshi_set=0,flag=9500,inte_wrong=0;
- int z=0,begin=0,minute=0,second=0,hour=0,minute1=0,second1=0,hour1=0;
- int water[2]={0,0};
- sbit led=P0^0;
- void delay1(unsigned char i1)
- unsigned char ii;
- unsigned int jj;
- for (ii=0;ii<i1;ii++)
- for (jj=0;jj<0x10;jj++);
- void motor1()
- char hight,low;
- bit updown;
- updown=1;
- hight=0xff;
- low=0x00;
- while( time_total==7||time_total==6||time_total==5)
- daport=0xff; // 输出5V
- delay1(hight);
- daport=0x00; // -5V
- delay1(low);
- if (updown)
- { ma=1;
- mb=0; //改变占空比
- hight++;
- low--;
- if (hight==0xff) updown=0;
- else
- { mb=0;
- ma=1;
- hight--;
- low++;
- if (hight==0x0) updown=1;
- void delay()
- unsigned char i;
- for(i=0;i<20;i++);
- void Delayms(int t)
- int x,y;
- for(x=t;x>0;x--)
- for(y=120;y>0;y--);
- void sound()
- int i=0;
- for(i=0;i<=10;i++)
- SPEAKER=1;
- for(i=0;i<=5;i++)
- SPEAKER=0;
- LCD_write_command(0x38);
- LCD_write_command(0x0c);
- LCD_write_command(0x06);
- LCD_write_command(0x01);
- LCD_write_command(0x02);
- delay_n40us(100);
- void LCD_write_command(uchar dat)
- LCD_DB=dat;
- LCD_RS=0;
- LCD_RW=0;
- LCD_E=1;
- LCD_E=0;
- delay_n40us(1);
- LCD_DB=dat;
- LCD_RS=1;
- LCD_RW=0;
- LCD_E=1;
- LCD_E=0;
- delay_n40us(1);
- uchar address;
- if(y==1)
- address=0x80+x;
- else
- address=0xc0+x;
- LCD_write_command(address);
- LCD_write_data(dat);
- int i;
- uchar j;
- for(i=n;i>0;i--)
- for(j=0;j<2;j++);
- int main()
- int i,d2;
- IE=0x87;
- TCON=0x05;
- TMOD=0x11;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- ET1=1;
- TR0=0;
- LCD_init();
- motor=0;
- while(1)
- int j=0,time_wash_dis;
- //PA=work_order[w];
- while(begin==0)
- { waterout=1;
- finish=1;
- waterin=1;
- tuoshui=1;
- washing=1;
- T_key=1;
- //HEAT1=1;
- //HEAT2=0;
- if(Honggan==0)
- {Delayms(200);
- if(Honggan==0)
- {mo_shi=mo_shi+1;
- if(mo_shi==2)
- {mo_shi=0;}}}
- if(mode==0)
- {Delayms(200);
- if(mode==0)
- {model=model+1;
- if(model==4)
- {model=0;}
- if(time_set==0)
- {Delayms(200);
- if(time_set==0)
- {time_wash=time_wash+1;
- if(time_wash==10)
- {time_wash=1;}}}
- if(m==0)
- {Delayms(200);
- if(m==0&&time_wash>0)
- {time_wash=time_wash-1;
- time_wash_dis=DSY_CODE[time_wash];
- LCD_disp_char(14,1,time_wash_dis);
- LCD_disp_char(15,1,'0');
- if(mo_shi==0)
- LCD_disp_char(0,2,'n');
- LCD_disp_char(1,2,'o');
- LCD_disp_char(2,2,'r');
- LCD_disp_char(3,2,' ');
- if(mo_shi==1)
- LCD_disp_char(0,2,'s');
- LCD_disp_char(2,2,'f');
- LCD_disp_char(3,2,'t');
- time[1]=time_wash;
- //writetlc5615(137);
- //初始启动设置
- while(inte_wrong)
- sound();
- if(time_total==9||time_total==8) //进水
- waterin=0;
- if(time_total==7||time_total==6||time_total==5) //洗涤
- { waterin=1;
- washing=0;
- motor1();
- if(time_total==4||time_total==3) // 排水
- { washing=1;
- ma=0;
- mb=0;
- waterout=0;
- if(time_total==2) //脱水
- { waterout=1;
- tuoshui=0;
- if(time_total==0)
- { sound();
- finish=0;
- tuoshui=1;
- Delayms(200);
- Delayms(200);
- Delayms(200);
- while(1){
- LCD_disp_char(0,2,'f');
- LCD_disp_char(1,2,'i');
- LCD_disp_char(2,2,'n');
- LCD_disp_char(3,2,'i');
- LCD_disp_char(4,2,'s');
- LCD_disp_char(5,2,'h');
- LCD_disp_char(6,2,' ');
- LCD_disp_char(7,2,' ');
- LCD_disp_char(8,2,' ');
- LCD_disp_char(9,2,' ');
- LCD_disp_char(10,2,' ');
- LCD_disp_char(11,2,' ');
- LCD_disp_char(12,2,' ');
- LCD_disp_char(13,2,' ');
- LCD_disp_char(14,2,' ');
- LCD_disp_char(15,2,' ');
- LCD_disp_char(0,1,' ');
- LCD_disp_char(1,1,' ');
- LCD_disp_char(2,1,' ');
- LCD_disp_char(3,1,' ');
- LCD_disp_char(4,1,' ');
- LCD_disp_char(5,1,' ');
- LCD_disp_char(6,1,' ');
- LCD_disp_char(7,1,' ');
- LCD_disp_char(8,1,' ');
- LCD_disp_char(9,1,' ');
- LCD_disp_char(10,1,' ');
- LCD_disp_char(11,1,' ');
- LCD_disp_char(12,1,' ');
- LCD_disp_char(13,1,' ');
- LCD_disp_char(14,1,' ');
- LCD_disp_char(15,1,' ');
- T_key=1;
- TR1=0; }
- // SPEAKER=0;
- /* for(i=0;i<3;i++)
- { t1=DSY_CODE[time[i]/10];
- LCD_disp_char(j,1,t1);
- t2=DSY_CODE[time[i]%10];
- LCD_disp_char(j+1,1,t2);
- j=j+3;
- return 0;
- void time_interrrupt0() interrupt 1 // 定时中断
- if(++count==2)
- { time1+=1;
- t1=DSY_CODE[time1/10];
- LCD_disp_char(0,1,t1);
- t2=DSY_CODE[time1%10];
- LCD_disp_char(1,1,t2);
- if(time1>=60&&second==0)
- {time[1]=time[1]-1;
- time[2]=9;
- if(time1>=60&&second!=0)
- {time[2]=time[2]-1;
- if(time1>=60)
- {time1=0;}
- hour=time[0];
- minute=time[1];
- second=time[2];
- time_total=10*minute+second;
- hour1=DSY_CODE[hour];
- minute1=DSY_CODE[minute];
- second1=DSY_CODE[second];
- LCD_disp_char(13,1,hour1);
- LCD_disp_char(14,1,minute1);
- LCD_disp_char(15,1,second1);
- count=0;
- void begain() interrupt 0 //启动中断
- begin=~begin;
- TR0=1;
- T_key=0;
- void wrong() interrupt 2 //故障中断
- inte_wrong=~inte_wrong;
- TR0=~TR0;
洗衣机final.zip
(242.22 KB, 下载次数: 34)
