查看: 3626|回复: 8
奇怪,搞不懂,求教单片机VFD驱动程序疑惑
宅在家里仿个VFD数字时钟,程序运行后,秒满六十进位到时位,中间间隔分为始终为零。源程序就是这个论坛里的,修改步骤详见注释。请走过路过的帮忙看看,是哪不对?(原程序vfd_wrtime ()里就是秒位进时位)
20200209 修改来自51hei http://www.51hei.com/bbs/dpj-43390-1.html  "基于89S52的16312VFD显示程序"
本人硬件:MCU:STC12C5616AD、
    修改:1.STB、CLK、DIN;
             2.按VFD重新编码0~9;
             3.按PT6312这是显示模式、数据模式设置;
            4.按VFD实际屏蔽G6(是VFD屏下部分汉字,如:多谢惠顾等);
           5.10_8_VFD的G1在右侧端头,G5是左侧端头,在void vfd_wrtime ()里调过来
           6.去掉秒、分个位、十位之间的空格,在分秒之间加一横0x08
           7.屏蔽vfd_wrdata ( g11[ i] );vfd_wrdata ( g12[ ] );
             增加vfd_wrdata ( vfdbuf[2] ); vfd_wrdata ( vfdbuf[3] );
  1. #include"reg51.h"
  2. #include "stdio.h"
  3. #define uint unsigned int
  5. sbit  DIN = P1^4;
  6. sbit  CLK = P3^1;
  7. sbit  STB = P1^7;
  8. void vfd_cmd (unsigned char vfd_cmd0);            /* 写命令*/
  9. void vfd_wrdata (unsigned char vfd_wrdata0);      /*  写数据 */
  10. void vfd_init (void);                             /* PT6312初始化 */
  11. unsigned char vfdbuf[]={0,0,0,0,21,8};
  12. code unsigned char vfdmap[]=
  13. {
  14. 0x77,0x60,0x5d,0x7c,0x6a,0x3e,0x3f,0x70,0x7f,0x7e
  15. }; //原程序:0xf7, 0xa4, 0xeb,0xed, 0xbc, 0xdd, 0xdf, 0xe4, 0xff, 0xfd
  16. unsigned char
  17. g11[]={0x64,0x89,0x32,0x64,0xa9,0x32,0x64,0xa9,0x32};
  18. unsigned char
  19. g12[]={0x26,0x48,0x91,0x26,0x48,0x01,0x02,0x00,0x91};
  20. //unsigned char g21[]={0xff,0x13,0x13,0x13,0x13,0x13,0x13,0x13,0x00};
  21. //unsigned char g22[]={0xff,0x40,0x00,0x00,0x80,0x00,0x00,0x00,0x00};
  22. //unsigned char g31[]={0xff,0x77,0x77,0x77,0x77,0x77,0x77,0x77,0x00};
  23. //unsigned char g32[]={0xff,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x10};
  24. //unsigned char g41[]={0xff,0x7e,0x7e,0x7e,0x7e,0x7e,0x7e,0x7e,0x00};
  25. //unsigned char g42[]={0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  26. //unsigned char g51[]={0xff,0x2f,0x2f,0x2f,0x2f,0x2f,0x2f,0x2f,0x00};
  27. //unsigned char g52[]={0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  28. /***********屏蔽G6****
  29. unsigned char
  30. g61[]={0xff,0x02,0x04,0x08,0x10,0x00,0x00,0x00,0x00};
  31. unsigned char
  32. g62[]={0xff,0x00,0x00,0x00,0x00,0x10,0x20,0x40,0x80};
  33. ***********/
  34. void delay(unsigned char cnt)
  35. {
  36. unsigned char i;
  37. while(cnt--!=0)
  38. for(i=100;i!=0;i--);
  39. }
  40. #define tick 7554
  41. #define T100us (256-134)
  42. unsigned char hour, minute, second;
  43. unsigned int c100us;
  44. void  vfd_cmd ( unsigned char vfd_cmd0 )          /*   写控制命令子程序   */
  45. {
  46. unsigned char i;
  47. STB=1;
  48. CLK=1;
  49. for ( i=0;i<8;i++ )
  50. {
  51.   STB=0;
  52.   CLK=0;
  53.   DIN = vfd_cmd0&0x01;
  54.   CLK=1;
  55.   vfd_cmd0>>=1;
  56. }
  57. STB=1;
  58. CLK=1;
  59. }
  60. void vfd_wrdata (  unsigned char vfd_wrdata0 )    /*   写数据子程序  */
  61. {
  62. unsigned char i;
  63. for(i=0;i<8;i++)
  64. {
  65.   CLK=1;
  66.   STB=0;
  67.   CLK=0;
  68.   DIN=vfd_wrdata0&0x01;
  69.   CLK=1;
  70.   vfd_wrdata0>>=1;
  71. }
  72. STB=0;
  73. CLK=1;
  74. }
  75. void vfd_init(void)
  76. {
  77. vfd_cmd ( 0x02 );                             /*  6digits,16segments显示模式  原程序0x3a */
  78. vfd_cmd ( 0x40 );                             /* 显示正常模式,数据地址递增    原程序0x70*/
  79. vfd_wrdata ( 0xc0 );                          /*    设置地址从00H开始    */
  80. }
  81. void timer0() interrupt 1
  82. {
  83. c100us--;
  84. if(c100us==0)
  85. {
  86.   c100us=tick;
  87.   second++;
  88.   if(second==60)
  89.   {
  90.    second=0;
  91.    minute++;
  92.    if(minute==60);
  93.    {
  94.     minute=0;
  95.     hour++;
  96.     if(hour==24)
  97.     {
  98.     hour=0;
  99.     }
  100.    }
  101.   }
  102. }
  103. }
  104. void vfd_wrtime ()
  105. {
  106. unsigned int i;
  107. vfdbuf[0]=vfdmap[second%10];   //原程序hour/10
  108. vfdbuf[1]=vfdmap[second/10];   //原程序hour%10
  109. vfdbuf[2]=vfdmap[minute%10];   //原程序minute/10
  110. vfdbuf[3]=vfdmap[minute/10];   //原程序minute%10
  111. vfdbuf[4]=vfdmap[hour%10];     //原程序second/10
  112. vfdbuf[5]=vfdmap[hour/10];     //原程序second%10
  113. vfd_init( );
  114. i=0;
  115. //vfd_wrdata ( g11[i] );       //原程序0x64
  116. //vfd_wrdata ( g12[i] );       //原程序0x26
  117. vfd_wrdata ( vfdbuf[0] );   //2G  秒的十位
  118. //vfd_wrdata ( 0x00 );
  119. vfd_wrdata ( vfdbuf[1] );          //3G  秒的个位
  120. //vfd_wrdata ( 0x00 );
  121. vfd_wrdata ( 0x08 );        //新增分秒之间一杠
  122. vfd_wrdata ( vfdbuf[2] );   //一下三句新增
  123. vfd_wrdata ( vfdbuf[3] );
  124. vfd_wrdata ( 0x08 );
  125. vfd_wrdata ( vfdbuf[4] );   //4G  时的个位
  126. //vfd_wrdata ( 0x00 );
  127. vfd_wrdata ( vfdbuf[5] );   //5G 时的十位
  128. //vfd_wrdata ( 0x00 );
  129. //vfd_wrdata ( g61[i] );    //6G   屏蔽G6
  130. //vfd_wrdata ( g62[i] );
  131. i++;
  132. STB=1;
  133. delay(1000);
  134. vfd_cmd ( 0x89 );              /*  显示开,14/16脉宽*/
  135. }
收藏收藏2 分享淘帖 顶顶 踩踩
ID:149451 发表于 2020-2-9 16:07 | 只看该作者
秒位积满60进位到时位,为何?
ID:584814 发表于 2020-2-9 17:56 | 只看该作者
把时和分弄拧巴了
ID:149451 发表于 2020-2-9 21:09 | 只看该作者
w1179benp 发表于 2020-2-9 16:07
秒位积满60进位到时位,为何?
主程序也贴出来
void  main()
        EA=1;  //开总中断
        ET0=1; //开定时器0中断
        TMOD=0x02;//设定定时器0为方式2
        TH0=T100us;
        TL0=T100us;
        hour=0;
        second=0;
        c100us=tick;
        TR0=1; //启动定时器0
                vfd_wrtime();
                delay(1);
ID:149451 发表于 2020-2-9 23:51 | 只看该作者
man1234567 发表于 2020-2-9 17:56
把时和分弄拧巴了
是原程序拧巴了?还是我改拧巴了?
1.  unsigned char vfdbuf[]={0,0,0,0,21,8};这句啥意思没我没搞懂
2. 感觉void timer0() interrupt 1 里c100us--;这句前面没赋值吧,怎么减呢?
ID:149451 发表于 2020-2-10 06:51 | 只看该作者
把时和分弄拧巴了
问题找到了,原程序if(minute==60)后有个“;”.由于这个“;”,导致判断后不能进入其跟随的程序体。
ID:679425 发表于 2020-2-10 16:51 | 只看该作者
有多余的“;”,导致判断后不能进入其跟随的程序
ID:634151 发表于 2020-4-11 17:29 | 只看该作者
这句啥意思啊这是
ID:149451 发表于 2020-6-7 08:34 | 只看该作者
rice001 发表于 2020-4-11 17:29
这句啥意思啊这是
数字编码表。
