查看: 2628|回复: 0
stcw15408as单片机驱动hx1230屏的源程序
两年前买的屏,现在官网下载已经失效,还好在论坛里找到了pdf,对照自己写了驱动完成测试。
测试了三种字体分别是宋体8x8,8x16和黑体16X24加粗。
效果如下:
  1. #include    <reg51.h>
  2. #include <intrins.h>
  3. sbit HX_RST=P1^0;
  4. sbit HX_CE=P3^7;
  5. sbit HX_DIN=P3^6;
  6. sbit HX_CLK=P3^5;
  7. sbit HX_BL=P3^4;
  8. //阴码,逆向,列行式
  9. unsigned char code tab8x8[][8] =
  10. {
  11. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*" ",32*/
  12. {0x00,0x00,0x00,0x4E,0x44,0x00,0x00,0x00},/*"!",33*/
  13. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFE,0x02,0x02,0xFE,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x0F,0x08,0x08,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"",127*/
  14. };
  15. void clr_HX(void);
  16. void delay(unsigned int t)
  17. {
  18.         unsigned int x;
  19.         while (t--)
  20.         {
  21.                 x = 600;
  22.                 while (x--);
  23.         }
  24. }
  25. void write_HX(unsigned char value, bit DC)//写入一个指令或数据
  26. {
  27.         int i;
  28.         HX_CE = 0;
  29.         HX_DIN = DC;
  30.         HX_CLK = 1;
  31.         HX_CLK = 0;
  32.
  33.         for(i=0;i<8;i++)
  34.         {
  35.                 if (value&0x80)
  36.                 {
  37.                         HX_DIN = 1;
  38.                 }
  39.                 else
  40.                 {
  41.                         HX_DIN = 0;
  42.                 }
  43.
  44.                 HX_CLK = 1;
  45.                 value = value<<1;
  46.                 HX_CLK = 0;
  47.         }
  48. }
  49. void init_HX(void)
  50. {
  51.         HX_CLK = 0;
  52.         HX_RST = 0;
  53.         delay(100);
  54.         HX_RST = 1;
  55.         HX_CE = 0;
  56.         delay(10);
  57.         HX_CE = 1;
  58.         delay(10);
  59.
  60.         write_HX(0x2f,0);
  61.         write_HX(0x90,0);
  62.         write_HX(0xa6,0);
  63.         write_HX(0xa4,0);
  64.         write_HX(0xaf,0);
  65.         write_HX(0x40,0);
  66.         write_HX(0xb0,0);
  67.         write_HX(0x10,0);
  68.         write_HX(0x00,0);
  69.
  70.         clr_HX();
  71. }
  72. void set_XY(unsigned char x, unsigned char y)
  73. {
  74.         write_HX(0xb0+y,0);
  75.         write_HX(0x10|((x & 0x7f) >> 4),0);
  76.         write_HX(0x0f&x,0);
  77. }
  78. void clr_HX(void)
  79. {
  80.         unsigned char i,j;
  81.         set_XY(0,0);
  82.         for (i=0;i<9;i++)
  83.         {
  84.                 for (j=0;j<96;j++)
  85.                 {
  86.                   write_HX(0x00,1);
  87.                 }
  88.         }
  89. }
  90. void display_char8x8(unsigned char x, unsigned char y, unsigned char input)
  91. {
  92.         char i,*ch;
  93.         ch=tab8x8[input-32];
  94.         set_XY(x,y);
  95.         for(i=0;i<8;i++)
  96.         {
  97.                 write_HX(*(ch+i),1);
  98.         }
  99. }
  100. void display_string8x8(unsigned char x, unsigned char y, unsigned char *string)
  101. {
  102.         unsigned char i = 0;
  103.         while(*(string+i)!='\0')
  104.         {
  105.                 display_char8x8(x+8*i,y,*(string+i));
  106.                 i++;
  107.         }
  108. }
  109. void display_char8x16(unsigned char x, unsigned char y, unsigned char input)
  110. {
  111.         char i,*ch;
  112.         ch=tab8x16[input-32];
  113.
  114.         /*上半部*/
  115.         set_XY(x,y);
  116.         for(i=0;i<8;i++)
  117.         {
  118.                 write_HX(*(ch+i),1);
  119.         }
  120.
  121.         /*下半部*/
  122.         set_XY(x,y+1);
  123.         for(i=8;i<16;i++)
  124.         {
  125.                 write_HX(*(ch+i),1);
  126.         }
  127. }
  128. void display_string8x16(unsigned char x, unsigned char y, unsigned char *string)
  129. {
  130.         unsigned char i = 0;
  131.         while(*(string+i)!='\0')
  132.         {
  133.                 display_char8x16(x+8*i,y,*(string+i));
  134.                 i++;
  135.         }
  136. }
  137. void display_char16x24(unsigned char x, unsigned char y, unsigned char input)
  138. {
  139.         char i,*ch;
  140.         ch=tab16x24[input-32];
  141.
  142.         /*上半部*/
  143.         set_XY(x,y);
  144.         for(i=0;i<16;i++)
  145.         {
  146.                 write_HX(*(ch+i),1);
  147.         }
  148.
  149.         /*中半部*/
  150.         set_XY(x,y+1);
  151.         for(i=16;i<32;i++)
  152.         {
  153.                 write_HX(*(ch+i),1);
  154.         }
  155.
  156.         /*中半部*/
  157.         set_XY(x,y+2);
  158.         for(i=32;i<48;i++)
  159.         {
  160.                 write_HX(*(ch+i),1);
  161.         }
  162. }
  163. void display_string16x24(unsigned char x, unsigned char y, unsigned char *string)
  164. {
  165.         unsigned char i = 0;
  166.         while(*(string+i)!='\0')
  167.         {
  168.                 display_char16x24(x+16*i,y,*(string+i));
  169.                 i++;
  170.         }
  171. }
  172. int main()
  173. {
  174.         init_HX();
  175.
  176.         display_string8x8(0,0,"Hello");
  177.         display_string8x16(0,1,"Hello");
  178.         display_string16x24(0,3,"Hello");
  179.
  180.         while(1);
  181.         return 0;
  182. }
示例代码已打包,有需要可下载:
lcd_hx1230_demo.rar (51.4 KB, 下载次数: 12)
收藏收藏1 分享淘帖 顶 踩
