- /* TRAFFIC.C: Traffic Light Controller using the C-51 COMPILER */
- char code menu[] =
- "\n"
- "+***** TRAFFIC LIGHT CONTROLLER using C51 and RTX-51 tiny *****+\n"
- "| This program is a simple Traffic Light Controller. Between |\n"
- "| start time and end time the system controls a traffic light |\n"
- "| with pedestrian self-service. Outside of this time range |\n"
- "| the yellow caution lamp is blinking. |\n"
- "+ command -+ syntax -----+ function ---------------------------+\n"
- "| Display | D | display times |\n"
- "| Time | T hh:mm:ss | set clock time |\n"
- "| Start | S hh:mm:ss | set start time |\n"
- "| End | E hh:mm:ss | set end time |\n"
- "+----------+-------------+-------------------------------------+\n";
- #include <reg52.h> /* special function registers 8052 */
- #include <rtx51tny.h> /* RTX-51 tiny functions & defines */
- #include <stdio.h> /* standard I/O .h-file */
- #include <ctype.h> /* character functions */
- #include <string.h> /* string and memory functions */
- extern void getline (char idata *, char); /* external function: input line */
- extern void serial_init (void); /* external function: init serial UART */
- #define INIT 0 /* task number of task: init */
- #define COMMAND 1 /* task number of task: command */
- #define CLOCK 2 /* task number of task: clock */
- #define BLINKING 3 /* task number of task: blinking */
- #define LIGHTS 4 /* task number of task: signal */
- #define KEYREAD 5 /* task number of task: keyread */
- #define GET_ESC 6 /* task number of task: get_escape */
- struct time { /* structure of the time record */
- unsigned char hour; /* hour */
- unsigned char min; /* minute */
- unsigned char sec; /* second */
- #define LAMP_ON 0
- #define LAMP_OFF 1
- struct time ctime = { 12, 0, 0 }; /* storage for clock time values */
- struct time start = { 7, 30, 0 }; /* storage for start time values */
- struct time end = { 18, 30, 0 }; /* storage for end time values */
- sbit red = P1^0; /* I/O Pin: red lamp output */
- sbit yellow = P1^1; /* I/O Pin: yellow lamp output */
- sbit green = P1^2; /* I/O Pin: green lamp output */
- sbit stop = P1^3; /* I/O Pin: stop lamp output */
- sbit walk = P1^4; /* I/O Pin: walk lamp output */
- sbit key = P1^5; /* I/O Pin: self-service key input */
- char idata inline[16]; /* storage for command input line */
- /* Task 0 'init': Initialize */
- void init (void) _task_ INIT { /* program execution starts here */
- serial_init (); /* initialize the serial interface */
- os_create_task (CLOCK); /* start clock task */
- os_create_task (COMMAND); /* start command task */
- os_create_task (LIGHTS); /* start lights task */
- os_create_task (KEYREAD); /* start keyread task */
- os_delete_task (INIT); /* stop init task (no longer needed) */
- bit display_time = 0; /* flag: signal cmd state display_time */
- /* Task 2 'clock' */
- void clock (void) _task_ CLOCK {
- while (1) { /* clock is an endless loop */
- if (++ctime.sec == 60) { /* calculate the second */
- ctime.sec = 0;
- if (++ctime.min == 60) { /* calculate the minute */
- ctime.min = 0;
- if (++ctime.hour == 24) { /* calculate the hour */
- ctime.hour = 0;
- if (display_time) { /* if command_status == display_time */
- os_send_signal (COMMAND); /* signal to task command: time changed */
- os_wait (K_IVL, 100, 0); /* wait interval: 1 second */
- struct time rtime; /* temporary storage for entry time */
- /* readtime: convert line input to time values & store in rtime */
- bit readtime (char idata *buffer) {
- unsigned char args; /* number of arguments */
- rtime.sec = 0; /* preset second */
- args = sscanf (buffer, "%bd:%bd:%bd", /* scan input line for */
- &rtime.hour, /* hour, minute and second */
- &rtime.min,
- &rtime.sec);
- if (rtime.hour > 23 || rtime.min > 59 || /* check for valid inputs */
- rtime.sec > 59 || args < 2 || args == EOF) {
- printf ("\n*** ERROR: INVALID TIME FORMAT\n");
- return (0);
- return (1);
- #define ESC 0x1B /* ESCAPE character code */
- static bit escape; /* flag: mark ESCAPE character entered */
- /* Task 6 'get_escape': check if ESC (escape character) was entered */
- void get_escape (void) _task_ GET_ESC {
- while (1) { /* endless loop */
- if (_getkey () == ESC) escape = 1; /* set flag if ESC entered */
- if (escape) { /* if escape flag send signal */
- os_send_signal (COMMAND); /* to task 'command' */
- /* Task 1 'command': command processor */
- void command (void) _task_ COMMAND {
- unsigned char i;
- printf (menu); /* display command menu */
- printf ("\nCommand: "); /* display prompt */
- getline (&inline, sizeof (inline)); /* get command line input */
- for (i = 0; inline[i] != 0; i++) { /* convert to uppercase */
- inline[i] = toupper(inline[i]);
- for (i = 0; inline[i] == ' '; i++); /* skip blanks */
- switch (inline[i]) { /* proceed to command function */
- case 'D': /* Display Time Command */
- printf ("Start Time: %02bd:%02bd:%02bd "
- "End Time: %02bd:%02bd:%02bd\n",
- start.hour, start.min, start.sec,
- end.hour, end.min, end.sec);
- printf (" type ESC to abort\r");
- os_create_task (GET_ESC); /* ESC check in display loop */
- escape = 0; /* clear escape flag */
- display_time = 1; /* set display time flag */
- os_clear_signal (COMMAND); /* clear pending signals */
- while (!escape) { /* while no ESC entered */
- printf ("Clock Time: %02bd:%02bd:%02bd\x0d", /* display time */
- ctime.hour, ctime.min, ctime.sec);
- os_wait (K_SIG, 0, 0); /* wait for time change or ESC */
- os_delete_task (GET_ESC); /* ESC check not longer needed */
- display_time = 0; /* clear display time flag */
- printf ("\n\n");
- break;
- case 'T': /* Set Time Command */
- if (readtime (&inline[i+1])) { /* read time input and */
- ctime.hour = rtime.hour; /* store in 'ctime' */
- ctime.min = rtime.min;
- ctime.sec = rtime.sec;
- break;
- case 'E': /* Set End Time Command */
- end.hour = rtime.hour; /* store in 'end' */
- end.min = rtime.min;
- end.sec = rtime.sec;
- break;
- case 'S': /* Set Start Time Command */
- start.hour = rtime.hour; /* store in 'start' */
- start.min = rtime.min;
- start.sec = rtime.sec;
- break;
- default: /* Error Handling */
- break;
- /* signalon: check if clock time is between start and end */
- static bit signalon (void) {
- if (memcmp (&start, &end, sizeof (struct time)) < 0) {
- if (memcmp (&start, &ctime, sizeof (struct time)) < 0 &&
- memcmp (&ctime, &end, sizeof (struct time)) < 0) return (1);
- else {
- if (memcmp (&end, &ctime, sizeof (start)) > 0 &&
- memcmp (&ctime, &start, sizeof (start)) > 0) return (1);
- return (0); /* signal off, blinking on */
- /* Task 3 'blinking': runs if current time is outside start & end time */
- void blinking (void) _task_ BLINKING { /* blink yellow light */
- red = LAMP_OFF; /* all lights off */
- yellow = LAMP_OFF;
- green = LAMP_OFF;
- stop = LAMP_OFF;
- walk = LAMP_OFF;
- yellow = LAMP_OFF; /* yellow light on */
- os_wait (K_TMO, 30, 0); /* wait for timeout: 30 ticks */
- yellow = LAMP_ON; /* yellow light off */
- if (signalon ()) { /* if blinking time over */
- os_create_task (LIGHTS); /* start lights */
- os_delete_task (BLINKING); /* and stop blinking */
- /* Task 4 'lights': executes if current time is between start & end time */
- void lights (void) _task_ LIGHTS { /* traffic light operation */
- red = LAMP_ON; /* red & stop lights on */
- green = LAMP_OFF;
- stop = LAMP_ON;
- walk = LAMP_OFF;
- // os_wait (K_TMO, 30, 0); /* wait for timeout: 30 ticks */
- if (!signalon ()) { /* if traffic signal time over */
- os_create_task (BLINKING); /* start blinking */
- os_delete_task (LIGHTS); /* stop lights */
- red = LAMP_OFF;
- yellow = LAMP_ON;
- os_wait (K_TMO, 50, 0); /* wait for timeout: 30 ticks */
- red = LAMP_OFF; /* green light for cars */
- green = LAMP_ON;
- os_clear_signal (LIGHTS);
- os_wait (K_TMO + K_SIG, 250, 0); /* wait for timeout & signal */
- os_wait (K_TMO, 50, 0); /* wait for timeout: 200 ticks */
- yellow = LAMP_ON;
- green = LAMP_OFF;
- red = LAMP_ON; /* red light for cars */
- stop = LAMP_OFF; /* green light for walkers */
- walk = LAMP_ON;
- os_wait (K_TMO, 150, 0); /* wait for timeout: 100 ticks */
- stop = LAMP_ON; /* red light for walkers */
- walk = LAMP_OFF;
- // stop = LAMP_ON; /* red light for walkers */
- // walk = LAMP_OFF;
- // red = LAMP_OFF; /* green light for cars */
- // yellow = LAMP_OFF;
- // green = LAMP_ON;
- //// os_clear_signal (LIGHTS);
- // os_wait1 (K_SIG); /* wait for timeout & signal */
- // os_wait (K_TMO, 250, 0); /* wait for timeout: 200 ticks */
- // yellow = LAMP_ON;
- // green = LAMP_OFF;
- // os_wait (K_TMO, 100, 0); /* wait for timeout: 30 ticks */
- // red = LAMP_ON; /* red light for cars */
- //// os_wait (K_TMO, 30, 0); /* wait for timeout: 30 ticks */
- // stop = LAMP_OFF; /* green light for walkers */
- // walk = LAMP_ON;
- // os_wait (K_TMO, 250, 0); /* wait for timeout: 100 ticks */
- /* Task 5 'keyread': process key stroke from pedestrian push button */
- void keyread (void) _task_ KEYREAD {
- static bit keybuf;
- if (keybuf==1 && key==0) { /* if key pressed */
- os_send_signal (LIGHTS); /* send signal to task lights */
- keybuf = key;
- os_wait (K_TMO, 2, 0); /* wait for timeout: 2 ticks */
RTX51操作系统.rar
(94.18 KB, 下载次数: 29)
