查看: 946|回复: 0
为什么单片机+LCD1602无法显示?并且P0.5端口有问题,怎么解决?
ID:697573 发表于 2020-3-24 13:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #define LCD_DB P0
  2. sbit LCD_E=P2^0;
  3. sbit LCD_RW=P2^1;
  4. sbit LCD_RS=P2^2;
  5. u8 disp[]=" dripping speed ";
  6. void LCD_init()
  7. {
  8. LCD_write_command(0x38);
  9. LCD_write_command(0x0c);
  10. LCD_write_command(0x06);
  11. LCD_write_command(0x01);
  12. LCD_write_command(0x80);
  13. }
  14. void LCD_write_command(unsigned char com)
  15. {
  16. LCD_E=0;
  17. LCD_RS=0;
  18. [color=#007000][backcolor=rgb(255, 255, 255)][font=Tahoma,] LCD[/font][/backcolor][/color]_RW=0;
  19. LCD_DB=com;
  20. delay(1000);
  21. LCD_E=1;
  22. delay(5000)
  23. LCD_E=0;
  24. }
  25. void LCD_write_data(unsigned char dat)
  26. {
  27. LCD_E=0;
  28. LCD_RS=1;
  29. LCD_RW=0;
  30. LCD_DB=dat
  31. delay(1000);
  32. LCD_E=1
  33. delay(5000)
  34. LCD_E=0;
  35. }
  36.
  37. void main()
  38. {
  39. u8 i;
  40. LCD_init();
  41. for(i=0;i<16;i++)
  42. {
  43.   LCD_write_data(disp[i]);
  44. }
  45. while(1);
  46. }
