查看: 1419|回复: 0
vb上位机怎么不能同时显示两个温度的值呢?
ID:703703 发表于 2020-3-29 14:53 | 显示全部楼层 |阅读模式
我想做个vb上位机能与51单片机进行无线通信,vb上位机怎么不能同时显示两个温度的值呢?
希望哪位大佬帮我看看。(我菜鸟一枚)
Private Sub Form_Load()
On Error GoTo skip
Winsock1.LocalPort = 6000
Winsock1.Listen
Exit Sub
skip:
If Err.Number = 10048 Then
MsgBox "端口冲突,退出!", vbOKOnly, "注意!"
End
End If
End Sub
Private Sub Text1_Change()
Text1.Text = dd
End Sub
Private Sub Text2_Change()
Text2.Text = mystr
End Sub
Private Sub Winsock1_Close()
If winxock1.State <> sckClosed Then Winsock1.Close
Winsock1.Listen
End Sub
Private Sub Winsock1_ConnectionRequest(ByVal requestID As Long)
If Winsock1.State <> sckClosed Then Winsock1.Close
Winsock1.Accept requestID
End Sub
Private Sub Winsock1_DataArrival(ByValbytestotal As Long)
Dim mystr As String
Dim dd As String
Winsock1.GetData mystr
Winsock1.GetData dd
Text1.Text = dd
Text2.Text = mystr
End Sub
