1、从后台调度中访问或修改全局变量的代码
描述:
在iFIX中使用调度要后台运行的时候需要启动FixBackgroundServer程序,而该程序实际上是启动了独立于Workspace的进程,所以在后台调度中不能直接访问全局变量。下面的例子代码描述了怎样访问的方法:
" First get a pointer to the Application object in the Workspace
Dim WrkSpcApp As Object
Set WrkSpcApp = GetObject("", "Workspace.Application")
" Get a pointer to the Variable object called Variable 1 in the User globals
Dim TargetVar As Object
Set TargetVar = WrkSpcApp.Documents("User").Page.FindObject("Variable1")
" Set the current value in the variable object to a 1
TargetVar.CurrentValue = 1
