查看: 6682|回复: 5
Arduino控制LCD12864
ID:718016 发表于 2020-4-4 07:54 | 显示全部楼层 |阅读模式
Arduino控制LCD12864 有兴趣的看看
  1. /*
  2. LCD  Arduino
  3. PIN1 = GND
  4. PIN2 = 5V
  5. RS(CS) = 8;
  6. RW(SID)= 9;
  7. EN(CLK) = 3;
  8. PIN15 PSB = GND;
  9. 行:汉字:8个 字母16个
  10. 列:4列
  11. */
  12. #include <LCD12864RSPI.h>
  13. #define AR_SIZE( a ) sizeof( a ) / sizeof( a[0] )
  14. unsigned char show1[]={0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4A,0x4B,0x4C,0x4D,0x4E,0x4F,0x50};
  15. unsigned char show2[]={0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6A,0x6B,0x6C,0x6D,0x6E,0x6F,0x70};
  16. unsigned char show3[]={0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5A};
  17. unsigned char show4[]={0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7A};
  18. void setup()
  19. {
  20. LCDA.Initialise(); // 屏幕初始化
  21. delay(100);
  22. }
  23. void loop()
  24. {
  25. LCDA.CLEAR();//清屏
  26. delay(100);
  27. LCDA.DisplayString(0,0,show1,AR_SIZE(show1));
  28. LCDA.DisplayString(1,0,show2,AR_SIZE(show2));
  29. LCDA.DisplayString(2,0,show3,AR_SIZE(show3));
  30. LCDA.DisplayString(3,0,show4,AR_SIZE(show4));
  31. while(1);
  32. //LCDA.CLEAR();//清屏
  33. }
以上资料51hei下载地址:
Arduino_LCD12864.zip (2.76 KB, 下载次数: 114)
ID:55085 发表于 2020-6-14 12:09 | 显示全部楼层
学习了,谢谢楼主!
ID:783907 发表于 2020-6-19 10:39 | 显示全部楼层
感谢分享~
ID:530600 发表于 2020-7-8 10:57 | 显示全部楼层
接上那种大体积的LCD12864只有背光却没显示  不知道是什么原因   楼主用的是0.96寸的那种液晶屏幕么
ID:755396 发表于 2020-7-16 16:28 | 显示全部楼层
各位,及LZ,    先要说清楚,LCD12864硬件是用的哪种主控,主控不同,操作不同,程序代码不同
ID:804156 发表于 2020-7-21 10:25 | 显示全部楼层
这种接线方式是SPI吗?
