查看: 3518|回复: 1
单片机电梯控制程序
ID:733618 发表于 2020-4-21 10:13 来自手机 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
单片机源程序:
#include <reg52.h>
#define u8 unsigned char
unsigned char seg_table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
unsigned char run,floor;
bit ud,stop=0;
sbit P06=P0^6;
sbit P07=P0^7;
sbit ulc=P2^0;
sbit dlc=P2^1;
sbit start=P2^2;
sbit alrl=P2^3;
sbit alrb=P2^4;
void input()
        run|=((~P0)&0x3f);
        if((P06==0)&&(ud==1))
        run|=0x02;
        if((P06==0)&&(ud==0))
        run|=0x04;
        if((P07==0)&&(ud==1))
        run|=0x08;
        if((P07==0)&&(ud==0))
        run|=0x10;
void delay(int j)
  int i;
  for(;j>0;j--)
        input();
        for(i=200;i>0;i--)
          if(stop==1)
          break;
        if(stop==1)
        break;
void StepMotor(bit a,u8 b)
  u8 x=0x80,i;
  if(a==1)
        ulc=0;
        dlc=1;
    for(i=0;i<b;i++)
          if(x==0x10)
            x=0x80;
            x=x/2;
          P3|=(x&0xf0);
          delay(100);
         ulc=1;
         dlc=0;
     for(i=0;i<b;i++)
          if(x==0x80)
            x=0x10;
            x=x*2;
          P3|=(x&0xf0);
          delay(100);
void alarm()
  alrl=0;
    alrb = ~alrb;
        delay(200);
        floor=1;
        P1=seg_table[floor];
        P0=0xff;
        ud=1;
        run=0;
        ulc=1;
        dlc=1;
        alrl=1;
    alrb=1;
        TCON=0x01; //打开外部中断0,并设置为下降沿触发
        IE=0x81;   //开总中断
             while(start==1)
                  P1=seg_table[10];
                  ulc=1;
          dlc=1;
                input();
                switch(floor)
                  case 1:                                  //1
                        if((run&0x01)==0x01)
                          delay(600);
                          run&=0xfe;
                    if((run&0x3e)!=0)
                          StepMotor(1,5);
                          floor=2;
                          ud=1;
                          ulc=1;
              dlc=1;
                  }         break;
                  case 2:
                    if(ud==1)                                 //2上
                          if((run&0x02)==0x02)
                            delay(600);
                            run&=0xfd;
                      if((run&0x38)!=0)
                            StepMotor(1,5);
                            floor=3;
                            ud=0;
                                ulc=1;
                dlc=1;
                        else                                            //2下
                          if((run&0x04)==0x04)
                            delay(600);
                            run&=0xfb;
                      if((run&0x01)!=0)
                            StepMotor(0,5);
                            floor=1;
                            ud=1;
                                ulc=1;
                dlc=1;
                  }         break;
                  case 3:
                    if(ud==1)                                 //3上
                          if((run&0x08)==0x08)
                            delay(600);
                            run&=0xf7;
                      if((run&0x20)!=0)
                            StepMotor(1,5);
                            floor=4;
                            ud=0;
                            ulc=1;
                dlc=1;
                        else                                  //3下
                          if((run&0x10)==0x10)
                            delay(600);
                            run&=0xef;
                      if((run&0x07)!=0)
                            StepMotor(0,5);
                            floor=2;
                            ud=1;
                                ulc=1;
                dlc=1;
                  }        break;
                  case 4:
                        if((run&0x20)==0x20)
                            delay(600);
                                  run&=0xdf;
                    if((run&0x1f)!=0)
                          StepMotor(0,5);
                          floor=3;
                          ud=0;
                          ulc=1;
              dlc=1;
                if(stop==1)
                  P1=seg_table[10];
                  ulc=1;
          dlc=1;
                  alarm();
void int0() interrupt 0
  stop=1;
收藏收藏2 分享淘帖 顶 踩
ID:835431 发表于 2020-10-27 21:57 | 只看该作者
有连好的原理图吗?
