- * 实验说明:
- * 通设置系统主时钟(MCLK=8Mhz ) 、辅助时钟(ACLK=8Mhz )、
- * 子系统时钟(SMCLK=8Mhz )
- #include <MSP430x24x.h>
- #include <string.h>
- #define uchar unsigned char
- #define uint unsigned int
- /**************定义接口************************/
- #define LCDIO P1OUT
- #define LCD1602_RS_1 P2OUT|=1
- #define LCD1602_RS_0 P2OUT&=~1
- #define LCD1602_RW_1 P2OUT|=2
- #define LCD1602_RW_0 P2OUT&=~2
- #define LCD1602_EN_1 P2OUT|=4
- #define LCD1602_EN_0 P2OUT&=~4
- #define PWM_1 P2OUT|=8
- #define PWM_0 P2OUT&=~8
- /**************定义函数************************/
- void LCD_write_command(unsigned char command);//写入指令函数
- void LCD_write_dat( unsigned char dat);//写入数据函数
- void LCD_set_xy( unsigned char x, unsigned char y );//设置显示位置函数
- void LCD_dsp_char( unsigned char x,unsigned char y, char dat);//显示一个字符函数
- void LCD_dsp_string(unsigned char X,unsigned char Y,const char *s);//显示字符串函数
- void LCD_init(void);//初始化函数
- void delay_nms(unsigned int n);//延时函数
- void TCL5615_DAC(unsigned int Data);
- //变量定义
- unsigned char Disbuf[10],flag;
- unsigned int DAC_num = 5;
- //ADC采集函数
- void RefreshDis0(unsigned int Data0)
- Disbuf[0] = 0x30 + Data0/100%10;
- Disbuf[1] = '.';
- Disbuf[2] = 0x30 + Data0/10%10;
- Disbuf[3] = 0x30 + Data0%10;
- Disbuf[4] = 'V';
- //ADC采集函数
- void RefreshDis1(unsigned int Data1)
- Disbuf[5] = 0x30 + Data1/100%10;
- Disbuf[6] = '.';
- Disbuf[7] = 0x30 + Data1/10%10;
- Disbuf[8] = 0x30 + Data1%10;
- Disbuf[9] = 'A';
- void P25_Onclick( void )
- DAC_num = 5;
- TCL5615_DAC( DAC_num ); //205 对应1.0V 410 对应2.0V 5---20mA
- void P26_Onclick( void )
- //20mA
- DAC_num = DAC_num + 10;
- if( DAC_num > 420 )
- DAC_num = 420;
- void P27_Onclick( void )
- DAC_num = DAC_num - 5;
- if( DAC_num < 5 )
- DAC_num = 5;
- //电压显示函数
- void Display( void )
- LCD_write_command( 0x80 );
- LCD_write_dat('V');
- LCD_write_dat(':');
- LCD_write_dat( Disbuf[0] );
- LCD_write_dat( Disbuf[1] );
- LCD_write_dat( Disbuf[2] );
- LCD_write_dat( Disbuf[3] );
- LCD_write_dat( Disbuf[4] );
- LCD_write_dat( ' ' );
- LCD_write_dat('I');
- LCD_write_dat( Disbuf[5] );
- LCD_write_dat( Disbuf[6] );
- LCD_write_dat( Disbuf[7] );
- LCD_write_dat( Disbuf[8] );
- LCD_write_dat( Disbuf[9] );
- void Display_Set( void )
- LCD_write_command( 0x80 + 0x40 );
- LCD_write_dat( 'S' );
- LCD_write_dat( 'e' );
- LCD_write_dat( 't' );
- LCD_write_dat( ':' );
- /*******延时函数************/
- void delayms(uint t)
- uint i;
- while(t--)
- for(i=1330;i>0;i--);//进过参数的调整
- /*******检查忙函数*************/
- void LCD_check_busy() //实践证明,在我的LCD1602上,检查忙指令通过率极低,以
- { //至于不能正常使用LCD。因此我没有再用检查忙函数。而使
- P1DIR=0x00;
- LCDIO=0xff;
- LCD1602_RS_0; //要用200次循环便能完成。
- LCD1602_RW_1;
- LCD1602_EN_1;
- while(P1IN&0x80);
- LCD1602_EN_0;
- P1OUT=0x00;
- P1DIR=0xFF;
- /**************写指令函数********************************/
- LCD1602_RS_0;
- LCDIO=command;
- LCD1602_EN_1;
- LCD1602_EN_0;
- delayms(1);
- /****************写数据函数************************/
- LCD1602_RS_1;
- LCDIO=dat;
- LCD1602_EN_1;
- LCD1602_EN_0;
- delayms(1);
- LCD1602_RS_0;
- /***************设置显示位置**************************/
- unsigned char address;
- if (y == 1)
- address = 0x80+x;
- else if (y == 2)
- address=0x80+0x40+x;
- LCD_write_command(address);
- /****************显示一个字符**********************/
- LCD_set_xy( x, y );
- LCD_write_dat(dat);
- /***************显示字符串函数***************/
- uchar len,List;
- len=strlen(s);
- LCD_set_xy( X, Y );
- for(List=0;List<len;List++)
- LCD_write_dat(s[List]);
- /********** 延时**********************/
- unsigned int i=0,j=0;
- for (i=n;i>0;i--)
- for (j=0;j<1;j++);
- /************初始化函数****************/
- LCD1602_RW_0;
- LCD1602_EN_0;
- //CLEARSCREEN;//clear screen
- LCD_write_command(0x38);//set 8 bit data transmission mode
- delayms(1);
- delayms(1);
- delayms(1);
- LCD_write_command(0x06);//open display (enable lcd display)
- delayms(1);
- LCD_write_command(0x0C);//set lcd first display address
- delayms(1);
- LCD_write_command(0x01);//clear screen
- delayms(1);
- LCD_dsp_string(1,1," LCD TEST ");//在第一行第一列显示"LCD TEST"
- LCD_dsp_string(1,2," SUCCSEEE! ");//在第一行第一列显示"LCD TEST"
- delayms(500);
- delayms(1);
- //ADC
- #define ADCST0 P5OUT &= ~BIT4
- #define ADCST1 P5OUT |= BIT4
- #define ADCALE0 P5OUT &= ~BIT5
- #define ADCALE1 P5OUT |= BIT5
- #define ADCEOC0 P5OUT &= ~BIT6
- #define ADCEOC1 P5OUT |= BIT6
- #define ADCOE0 P5OUT &= ~BIT7
- #define ADCOE1 P5OUT |= BIT7
- #define ADC_Channel0 P5OUT &= ~BIT0
- #define ADC_Channel1 P5OUT |= BIT0
- unsigned int ADC1;
- void ADC_START(void)
- ADCALE1;
- ADCST1;
- delayms(1);
- ADCALE0;
- ADCST0;
- delayms(1);
- char ADC_READ()
- uchar data;
- data=0x00;
- delayms(1);
- ADCOE1;
- ADC_START();
- delayms(5);
- data=P4IN;
- ADCOE0;
- return data;
- // DAC
- #define SET_DIN do{P3OUT |= BIT0;}while(0) //串行数据输入
- #define CLR_DIN do{P3OUT &= ~(BIT0);}while(0) //串行数据输入
- #define SET_SCLK do{P3OUT |= BIT1;}while(0) //串行时钟输入
- #define CLR_SCLK do{P3OUT &= ~(BIT1);}while(0) //串行时钟输入
- #define SET_CS do{P3OUT |= BIT2;}while(0) //低电平有效
- #define CLR_CS do{P3OUT &= ~(BIT2);}while(0) //低电平有效
- /*****************************************软件延时******************************/
- #define CPU_F ((double)16000000)
- #define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
- #define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
- unsigned char i;
- Data <<= 6; //移除高6位,int型数据有16位,该DA是10位
- CLR_SCLK; //在片选有效前,时钟信号要为低
- CLR_CS; //片选有效
- for(i=0;i<12;i++) //每次转换需要10个时钟下降沿
- if(Data&0x8000) //取最高位数据,模拟串行数据
- SET_DIN;
- CLR_SCLK;
- SET_SCLK;
- else
- CLR_DIN; //数据在时钟上升沿到来前准备好
- CLR_SCLK;
- SET_SCLK;
- Data <<= 1; //数据左移,为下一次取数据做准备
- CLR_SCLK;
- SET_CS; //片选失效
- delayms(1);
- void main(void)
- WDTCTL=WDTPW + WDTHOLD; // 关闭看门狗
- P1DIR=0xFF; // 设置方向
- P1SEL=0; // 设置为普通I/O 口
- P2DIR=0x0F; // 设置方向
- // P2SEL=0; // 设置为普通I/O 口
- P3DIR=0xFF; // 设置方向
- //-----配合机械按键,启用内部上拉电阻-----
- P2REN |= BIT5+BIT6+BIT7; //启用P3.5内部上下拉电阻
- P2OUT |= BIT5+BIT6+BIT7; //将电阻设置为上拉
- //-----配置P3.5中断参数-----
- P2DIR &= ~BIT5+BIT6+BIT7; // P3.5设为输入(可省略)
- P2IES |= BIT5+BIT6+BIT7; // P3.5设为下降沿中断
- P2IE |= BIT5+BIT6+BIT7; // 允许P3.5中断
- P1OUT=0x00;
- P5SEL = 0x00;
- P5DIR |= BIT0+BIT4+BIT5+BIT6;
- delayms(200);
- LCD_init(); //LCD1602初始化
- /****设置AD寄存器****/
- ADC12CTL0=ADC12ON+SHT0_2;//打开AD转换内核,参考电压3.3V
- ADC12CTL1=SHP;
- ADC12IE=0X01;//使能中断允许
- ADC12CTL0|=ENC;
- P6SEL|=0x01;//P6.0电压输入
- P6DIR = 0xFE;
- flag=0;
- ADC12CTL0|=ADC12SC;//启动ADC转换器
- _BIS_SR(LPM0_bits+ GIE);//进入低功耗睡眠模式
- while(1)
- ADC1=ADC_READ();
- RefreshDis1(ADC1*2);
- Display();
- Display_Set();
- if(flag == 1)
- flag=0;
- // _BIS_SR(LPM0_bits+ GIE);//进入低功耗睡眠模式
- /****ADC12中断服务****/
- #pragma vector=ADC12_VECTOR
- __interrupt void ADC12_ISR(void)
- RefreshDis0(ADC12MEM0/8);
- flag=1;
- LPM0_EXIT;
- * 名 称:P2_IODect()
- * 功 能:判断具体引发中断的IO,并调用相应IO的中断事件处理函数
- * 说 明:该函数兼容所有8个IO的检测,请根据实际输入IO激活“检测代码”。
- void P2_IODect()
- unsigned int Push_Key=0;
- //-----排除输出IO的干扰后,锁定唯一被触发的中断标志位-----
- Push_Key=P2IFG&(~P2DIR);
- //-----延时一段时间,避开机械抖动区域-----
- delayms(5); //消抖延时
- //----判断按键状态是否与延时前一致-----
- if((P2IN&Push_Key)==0) //如果该次按键确实有效
- //----判断具体哪个IO被按下,调用该IO的事件处理函数-----
- switch(Push_Key)
- case BIT5: P25_Onclick(); break;
- case BIT6: P26_Onclick(); break;
- case BIT7: P27_Onclick(); break;
- default: break; //任何情况下均加上default
- #pragma vector = PORT2_VECTOR
- __interrupt void PORT2_ISR(void)
- //-----启用Port2事件检测函数-----
- P2_IODect(); //检测通过,则会调用事件处理函数
- P2IFG=0; //退出中断前必须手动清除IO口中断标志
恒流源.zip
(370.56 KB, 下载次数: 94)
