查看: 6301|回复: 11
基于单片机+mfrc522 RFID+LCD12864射频门禁系统程序
射频识别门禁系统
  1. #include "reg52.h"
  2. #include "mfrc522.h"
  3. #include <string.h>
  4. #include <12864.h>
  5. #include <i2c.h>
  6. #include <waishe.h>
  7. #include <key.h>
  8. unsigned char aaddrr,addr;
  9. unsigned char eepromreadnum[4];
  10. char returnkey=1;
  11. void Timer0Init()                //定时器0初始化
  12. {
  13.         EA=0;//打开总中断
  14.         ET0=1;//打开定时器0中断允许
  15.         TR0=1;//打开定时器
  16.         TMOD|=0X01;//选择为定时器0模式,工作方式1,仅用TR0打开启动。
  17.         TH0=0XFC;        //给定时器赋初值,定时1ms
  18.         TL0=0X18;
  19. }
  20.   void main( )
  21. {
  22.    int failflag,y,successflag;
  23.          int KeyValue=12;
  24.    beep=0;
  25.    RFID_Init();
  26.    LCDInit();
  27.    Timer0Init();
  28.          if(At24c02Read(255)!=0x65)                //eeprom初次上电初始化
  29.          {
  30.                   delay(1000);
  31.                   ShowQQChar(0x82,"初次上电",4);
  32.                   ShowQQChar(0x91,"初始化中...",6);
  33.                   ShowQQChar(0x8a,"请稍等",3);
  34.                   for(y=0;y<255;y++)
  35.                   {
  36.                                  At24c02Write(y,0xff);                //eeprom区全部清零
  37.                                  delay(1000);
  38.                         }
  39.                   At24c02Write(255,0x65);
  40.                   delay(1000);
  41.                         At24c02Write(248,0x25);
  42.                   delay(1000);
  43.                         At24c02Write(249,0x28);
  44.                   delay(1000);
  45.                         At24c02Write(250,0xa5);
  46.                   delay(1000);
  47.                         At24c02Write(251,0x51);
  48.                   delay(1000);
  49.          }
  50. while(1)
  51. {
  52.          unsigned char status,i,k;
  53.          k=0;
  54.          LCD_show();
  55.          status = PcdRequest(PICC_REQIDL, g_ucTempbuf);//寻天线区内未进入休眠状态的卡
  56.          if (status != MI_OK)
  57.    {
  58.                         PcdReset();
  59.                   PcdAntennaOff();
  60.                         PcdAntennaOn();
  61.             continue;
  62.    }
  63.          status = PcdAnticoll(g_ucTempbuf);      //防冲撞,此时g_ucTempbuf的值为卡号
  64.    if(status != MI_OK)
  65.          continue;
  66.           ////////卡号打印////////////////////////
  67.          led1=0;
  68.          WRCommand(0x01); //清除显示 DDRAM
  69.          ShowQQChar(0x90,"卡号:",3);
  70.   while(aaddrr<252)                         //卡号比对程序段
  71.   {
  72.           k=0;
  73.                 for(i=0;i<4;i++)                       //卡号占用四个地址,比对四次
  74.                 {
  75.                 eepromreadnum[i]=At24c02Read(aaddrr);                     //读取EEPROM地址1内的数据保存在        g_ucTempbuf[]中
  76.                 aaddrr++;
  77.                 ShowNUMChar(0x93+i,g_ucTempbuf[i]);    //显示卡号
  78.                 if(eepromreadnum[i]==g_ucTempbuf[i])               //卡号开始进行比对
  79.                 {
  80.                         k=k+i;                               //四次比对成功0+1+2+3
  81.                   delay(1000);
  82.                 }
  83.                 else k=0;                        //比对失败
  84.                 if(k==6)
  85.                   {
  86.                          failflag=0;
  87.                      aaddrr=252;
  88.               }
  89.                 }
  90.   }
  91. aaddrr=0;                    //地址回到首位,以便下次比较
  92.   if(k==6)                    //卡号对比成功
  93.         {
  94.                 relay=0;
  95.                 ShowQQChar(0x8a,"请通过\xfd",3);
  96.                 beep_Init(1);
  97.         }
  98.         if(k!=6)                    //卡号对比失败
  99.         {
  100.                  beep_Init(0);
  101.                  delay(50000);
  102.                  WRCommand(0x01);
  103.                  failflag=1;                  //卡号对比失败标志位
  104.         }
  105.   if(failflag==1)
  106.   {
  107.                 ShowQQChar(0x91,"是否输入密码",6);
  108.                 ShowQQChar(0x8a,"添加卡号",4);
  109.                 delay(500);
  110.    while(returnkey)
  111.          {
  112.             EA=0;
  113.                 KeyValue=KeyDown();
  114.                 if(KeyValue==11)
  115.                 {
  116.                  WRCommand(0x01);
  117.                  delay(10000);
  118.                  successflag=inputmima();                 //密码输入函数
  119.                  delay(10000);
  120.                  WRCommand(0x01);
  121.                  delay(1000);
  122.                  if(successflag==1)
  123.                  {
  124.                   for(i=0;i<4;i++)             //显示卡号   g_ucTempbuf[]  所刷卡的卡号
  125.             {
  126.                                 ShowNUMChar(0x92+i,g_ucTempbuf[i]);
  127.                                 At24c02Write(addr,g_ucTempbuf[i]);         //将卡号存入eeprom中,addr为存入地址
  128.                                 addr++;
  129.                                 delay(1000);
  130.             }
  131.                  delay(10000);
  132.                  WRCommand(0x01);
  133.                  ShowQQChar(0x92,"存储成功",4);
  134.                  delay(10000);
  135.                  }
  136.                  returnkey=0;
  137.                 }
  138.      else if(KeyValue==10)
  139.                  returnkey=0;
  140.          else
  141.          EA=1;
  142.          }
  143.   }
  144. returnkey=1;
  145.
  146. delay(70000);    //延时等待
  147. WRCommand(0x01); //清除显示 DDRAM
  148. led1=1;
  149. relay=1;
  150.
  151. }
  152. }
  153. void Timer0() interrupt 1
  154. {
  155.         static u16 i;
  156.         TH0=0XFC;        //给定时器赋初值,定时1ms
  157.         TL0=0X18;
  158.         i++;
  159.         if(i==5000)
  160.         {
  161.                 i=0;
  162.         returnkey=0;
  163.         }
  164. }
以上程序51hei提供下载  (无仿真工程):
门禁系统.rar (115.9 KB, 下载次数: 306)
收藏收藏10 分享淘帖 顶1 踩
ID:523305 发表于 2020-5-13 20:56 | 只看该作者
没仿真
ID:756620 发表于 2020-5-22 14:48 | 只看该作者
楼主有没有具体的原理图和仿真图啊
ID:730070 发表于 2020-6-13 08:21 | 只看该作者
正在做433MHZ射频相关的,论坛上逛逛学习
ID:114068 发表于 2020-6-20 18:55 | 只看该作者
拿走了,谢谢!
ID:114068 发表于 2020-6-20 18:56 | 只看该作者
谢谢楼主咯
ID:784145 发表于 2020-6-23 21:34 | 只看该作者
没得原理图啊
ID:445876 发表于 2021-4-13 16:50 | 只看该作者
老哥你的定时器EA=0咋工作的啊,是不是不用定时器啊
ID:985761 发表于 2021-11-29 00:07 | 只看该作者
楼主,怎么编写管理员密码还有增加删减普通密码
ID:941265 发表于 2021-11-29 08:21 | 只看该作者
51黑,有你更精彩
ID:985761 发表于 2021-12-2 12:44 | 只看该作者
有没有器件清单
ID:864837 发表于 2023-6-6 09:30 | 只看该作者
谢谢 大佬,正在做433MHZ射频相关的,论坛上逛逛学习
